Old 10-26-2020, 08:41 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Drug home a 67-72 2x4x4 crossbreed.
Actually found one close to home! Sometimes you have to question things... It does have a few parts yet, but not much. And yes there are 15 springs in the back!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-26-2020, 08:44 PM   #2
too much stuff
Roadtrip!
Re: Drug home a 67-72 2x4x4 crossbreed.
Look close and you will understand the title.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-26-2020, 08:57 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
2 wheel drive transmission? Looks like some good parts there though for sure.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 10-27-2020, 04:49 AM   #4
RustyPile
RustyPile's Avatar
Good find... But you better hurry and harvest those good parts before the rust worms beat you to them...
RustyPile is online now   Reply With Quote
Old 10-27-2020, 06:07 AM   #5
Just lock the hubs in and you'll have... front wheels locked in
Old 10-27-2020, 09:11 AM   #6
too much stuff
Roadtrip!
Yep, 2wd truck. I don't think it was ever intended to be a 4x4.
13 degrees here right now, hopefully the rust worms are sleeping
I don't even see a yoke on the front diff.
I was a little excited when the guy called and said he had a 4x4 with a plow on it. He also said it looks like a 350 engine in it. (8-350 on the fender) Looks like a late model 305 is my guess. Last plates were 99
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-27-2020, 12:40 PM   #7
gmc684x4
My guess is it was a 4x4 po blew tranny tcase combo installed a 2x4 tranny
Many k20 trucks have a baseplate yoke design that the ujoint goes into a baseplate which gets bolted to the flat yolk on the front diff
You can look at front spring mounts to see if there factory rivited or bolted on
Laatly check your vin whether its a c code or k code truck
gmc684x4 is offline   Reply With Quote
Old 10-27-2020, 02:24 PM   #8
Dr Jekyll
Dr Jekyll's Avatar
“I got it one piece at time, and it didn’t cost me a dime” ...”it’s a 67, 68, 69, 70, 71 automobile “
Dr Jekyll is offline   Reply With Quote
Old 10-27-2020, 06:30 PM   #9
68Gold/white
Johnny Cash???
68Gold/white is offline   Reply With Quote
Old 10-27-2020, 06:33 PM   #10
68Gold/white
I'm guessing the pad in front of the pass head is a short one (1-1/4" wide vs early ones being around 3" wide)?
As far as I know the best way to tell a later 305 from a 350 is to look behind driver side head on block. 5.7 or 5.0 in fairly large print.
Congrats! again
Old 10-27-2020, 07:00 PM   #11
No SPID? Painted over with white paint? I see the clutch pedal is not painted white like the brake pedal and parking brake. Hmmm...
Old 10-28-2020, 11:13 AM   #12
Old_Gold
Old_Gold's Avatar
Talking Re: Drug home a 67-72 2x4x4 crossbreed.
Another interesting find! I don't recognize the bench seat left in the back, must be for a Ford! Lol
Jim
Old_Gold is offline   Reply With Quote
Old 10-28-2020, 05:34 PM   #13
too much stuff
Roadtrip!
As i suspected, a 71 2wd that was born that way.
Congrats! again
Correct, small ID pad. And plenty of vacuum lines like the late 70s-early 80s had.
Good eye. I am not sure why the auto was swapped out and the 3 speed added. The spid has a ton of paint on it and a knife wont even touch it. You can see the thick paint around the VIN i scraped off.
Jim
I pulled the truck out of an abandon homestead. I told the wife she could take the 2 old benches if she unloaded all the rocks and cement that was in the bed of the truck... She really wanted the benches...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-28-2020, 05:37 PM   #14
too much stuff
Roadtrip!
Low hump cab and looks like it had a toolbox at one time.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
