Old 10-31-2020, 12:41 PM   #1
kens65fb
Brake Pedal Question ?
It has been mentioned a few times on this forum, that drilling a hole 1 inch lower, where the master cylinder rod connects, provides a better angle to the firewall booster, when adding power brakes.
My question is :
Is the brake pedal on a truck equipped with power brakes from the factory different than a non-power brake truck ?
Is the hole lower than a non-power brake pedal ?
kens65fb is offline   Reply With Quote
Old 10-31-2020, 02:43 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Brake Pedal Question ?
My question is :
They are different. If you have a "Factory" power brake firewall bracket (wedge) and hinge (mechanism) then no (extra) hole is necessary.
http://67-72chevytrucks.com/vboard/s...52&postcount=9
Old 10-31-2020, 04:44 PM   #3
raylube
raylube's Avatar
Originally Posted by The Rocknrod View Post
They are different. If you have a "Factory" power brake firewall bracket (wedge) and hinge (mechanism) then no hole is necessary.
I don't think this answers kens65fb question because either power or non power brakes a hole for the push rod in the pedal arm is NECESSARY.
raylube is offline   Reply With Quote
Old 10-31-2020, 04:54 PM   #4
The Rocknrod
Moderator
You mean it's not unnecessary?
Old 10-31-2020, 08:48 PM   #5
PGSigns
PGSigns's Avatar
The angle is not what gets improved its the pedal ratio and the stroke of the rod.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-31-2020, 09:57 PM   #6
Captainfab
60-66 Nut
The '63-'66 truck brake pedal has the hole in the same location whether the truck came with manual brakes or factory power brakes. The different ratio for the power brakes was accomplished with the bellcrank assembly on the engine side of the firewall.
Old 06-17-2021, 06:47 PM   #7
kaycee
kaycee's Avatar
I'm guessing to drill 1" lower I would measure center to center correct?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
