#26 | |
Re: 4L60E Trans only shifts 2 and 3
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
#27 |
I have 12.6 volts on the left side of the fuse and 0 on the right.
#28 |
I'm still tracing this pink pin E wire but I've gone past where they split off to go to the fuse block. So this wire has to go to the ecm. It goes to pin 63 on the green ecm plug.
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 Last edited by ewoody625; 10-08-2020 at 04:08 PM. |
#29 |
You've found your problem right there. If you have power on one side of the fuse but not the other, then either the fuse is blown or its not making a good contact in the fusebox. Fix that and you should be good to go.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#30 |
Wow.... I feel like an idiot lol. It looked good when I checked it before. I just looked at it again and it's blown. Well now I need to replace that fuse and get everything hooked back up and see if I'm back in business. Thanks for guiding me along.
#31 |
If you have the harness out, Double check it for any bare wires. You need to find the cause of the blown fuse.
#32 |
It's shifting now. I still have a flashing check engine light but no codes. I'll have to keep an eye on that. Thanks for the help!
#33 | |
#34 |
