Old 11-17-2020, 12:23 PM   #351
Duncan K
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Originally Posted by 88Stanger View Post
Exactly. LOL .... I have been working on the upper windshield outer panel and damn... i got it in, looks good except for 1 small area that decided to be a pain in the cab to weld! Kept blowing through. I got mad and kept trying to add more filler and, well, finally i stopped, laughed and said just cut that little part out and use the extra filler panel i still have that i did not use. LOL But damn was i mad. lol
All in all so far, the outside repair panel is not to bad. Now moving to the inner panel to roof, not excited about this one.....
There is always that one section that just refuses to cooperate!! I have had many days that I just had to walk away
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 11-18-2020, 11:26 AM   #352
88Stanger
88Stanger's Avatar
Yep that is what happened. LOL
Next are pics of progress and a pic of that damn blowout area.
88Stanger is offline   Reply With Quote
Old 11-18-2020, 11:28 AM   #353
88Stanger
88Stanger's Avatar
Ok, so here are pics of the progress so far on the outside Windshield repair panel... and blowout area.. lol
Old 11-18-2020, 11:29 AM   #354
88Stanger
88Stanger's Avatar
and more..
Old 11-18-2020, 11:30 AM   #355
88Stanger
88Stanger's Avatar
few more
Old 11-18-2020, 11:34 AM   #356
SCOTI
SCOTI's Avatar
Lookin' good!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-18-2020, 11:35 AM   #357
88Stanger
88Stanger's Avatar
i have a few areas that i need to still work a bit, but overall the fix is in. Honestly the hardest part is getting the panel to separate, AND anywhere that they would use that damn "bond", that really sucks! It sticks together and is not easy to separate, heck it is almost easier to remove spot weld areas. This is how it was for me at least.
Now i must work the inside area... this is where i get a bit nervous. The outside part i just did is just one cut and match that was short, the inside, well that is a longitudinal cut and i am not happy about that... but quitters never advance .. so .... lol This weekend you may hear alot of screaming from Washington State!!
Old 11-18-2020, 11:35 AM   #358
88Stanger
88Stanger's Avatar
Originally Posted by SCOTI View Post
Lookin' good!
Thank you sir! I appreciate it.
Old 11-18-2020, 11:36 AM   #359
88Stanger
88Stanger's Avatar
i so want to get this rust repair done so i can get to what i like to do..... anything but body work!! LOL
Old 11-21-2020, 12:42 PM   #360
pdxhall
pdxhall's Avatar
The patchwork on the front looks great. I'm glad I didn't have to do that area. It looks difficult. Keep it up.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-21-2020, 02:22 PM   #361
SCOTI
SCOTI's Avatar
x2. Very clean work. Impressive!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2020, 04:55 PM   #362
88Stanger
88Stanger's Avatar
Thank you. It was not really too bad, but he next area has me a bit nervous
Old 11-21-2020, 04:56 PM   #363
88Stanger
88Stanger's Avatar
Ok Here are some updates to the outside part with filler going in
Old 11-21-2020, 04:58 PM   #364
88Stanger
88Stanger's Avatar
Now for the one that has me worried a bit. Any thoughts here are welcome. So i am going to do this patch, but trying to keep the passenger visor area as is because there is a panel behind the small holes that i want to keep.
Old 11-21-2020, 05:01 PM   #365
88Stanger
88Stanger's Avatar
and finally, the firewall. I am trying to figure out what holes must stay and what can go, so i can clean it up.
I am getting vintage air, hyrdolic clutch (Captfab) and Hydroboost. Any help here?
Old 11-21-2020, 09:53 PM   #366
The Rocknrod
Moderator
The Rocknrod's Avatar
Old 11-22-2020, 11:13 AM   #367
88Stanger
88Stanger's Avatar
Originally Posted by The Rocknrod View Post
Awesome! Thank you!!
Old 11-23-2020, 11:04 AM   #368
88Stanger
88Stanger's Avatar
Ok, well so the inside rust repair was not really that bad, just had to make sure i made small adjustments until it fit good, really not bad. Thank goodness! Now it is cleanup time and start the filler part....
Old 11-23-2020, 11:05 AM   #369
88Stanger
88Stanger's Avatar
Can you guess where i bought the patch panel from.... lol
Old 11-25-2020, 05:38 PM   #370
The Rocknrod
Moderator
That's weird, the exact same inner roof area was bad on mine too. Looks great.
Old 11-29-2020, 10:09 PM   #371
30fathoms
30fathoms's Avatar
Fantastic work on the inner (and outer) repairs!
Ours was so far gone we had to do the entire inner/outer panels...from A-post to A-post. The outer was not bad. But I will say for those considering doing the complete inner...stop, measure thrice, then re-consider. I found the inner patch panel to be too short in the A-post area. The original piece reached further down and tucked into the A-post with a complex lip/bend; the patch panel was way short, ended up burning a lot of time cutting and bending small patches out of stock to tie everything in. Another consideration, when you cut across the entire inner roof area (opposite of the window lip), the roof panel will sag making the final fitting a real bear. I'm sure my inexperience played a part in the circus but...just a suggestion.
Cheers,
30f
'64 C20 Step side, 327, Sag 3sp, HO52 4.11
30fathoms is offline   Reply With Quote
Old 11-30-2020, 07:02 PM   #372
88Stanger
88Stanger's Avatar
Strange how that happens... LOL
Honestly it was not as bad to repair as i thought. Here to help if you need any.
Old 11-30-2020, 07:04 PM   #373
88Stanger
88Stanger's Avatar
Cheers,
30f
Damn, sorry you had to the entire thing. I was lucky and only had to about 1/2 of it. I am by no means a body guy, AT ALL. I am trying to get it as nice as i can, but i know i am not a body guy, so as good as i can is what i will get. LOL
Old 11-30-2020, 09:17 PM   #374
30fathoms
30fathoms's Avatar
Well...looks good. Attached is the A-Post areas that were such a bear
Old 12-01-2020, 01:23 PM   #375
88Stanger
88Stanger's Avatar
Looking good sir! I have just a bit of tack welding yet to do then mine is done. Ran out of damn gas again. lol
