Old 11-09-2020, 01:16 PM   #301
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
I have a collection of front drivelines now. The top one was on the truck when I got it and has a bad slip joint. The middle one is 'ol bendy. The bottom one is brand new from High Angle Driveline in Paradise, CA.
jimbosprint is offline   Reply With Quote
Old 11-09-2020, 06:37 PM   #302
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Attachment 2059838
The new one looks great. I might need them soon.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-13-2020, 03:12 PM   #303
jimbosprint
Still a long checklist:
Check spark plugs, tune-up
Fix brake lights staying on - pedal not returning all the way!
Improve braking?
Install front driveline
Replace rear driveline u-joints
Install 1" zero rate blocks in rear axle
Fix leaking thermostat housing
Service or rebuild transmission (leaking)
Service transfer case (swap with other one? twin stick?)
Install radio (speakers?)
Replace windshield washer hoses / test washer pump
Install cowl debris screen
Replace valve cover gaskets
Install door panels
Replace headlights and adjust
Repair weld lumber rack
Old 11-18-2020, 06:15 PM   #304
jimbosprint
I took the new u-joints out of the bent front driveline today. I think they are the same as the rear driveline, so I can still use them.
Old 11-19-2020, 02:37 PM   #305
jimbosprint
This morning I made some big jack stand blocks that will make it safer to work under the truck.
Old 11-20-2020, 04:37 PM   #306
jimbosprint
I installed a Kenwood Digital Media Receiver today. I still need to replace the speakers, but I have a working stereo and I can take hands free bluetooth phone calls. I put the microphone in the ash tray so it is hidden.
Link to video: https://youtu.be/23QQ-SY4Y-U
Old 11-21-2020, 07:44 PM   #307
jimbosprint
New door speakers are installed. Some door panels would probably help the sound.
Old 11-21-2020, 10:35 PM   #308
Ol Blue K20
Attachment 2062254
Attachment 2062255
Attachment 2062256
They look good, what are they?
Dale
Old 11-21-2020, 11:08 PM   #309
jimbosprint
Kicker 5.25"
Old 11-21-2020, 11:47 PM   #310
Ol Blue K20
Thanks, I need some for the holes in my doors. The easiest way to fill the holes without welding.
Dale
Old 11-22-2020, 03:40 PM   #311
jimbosprint
I installed 1" zero rate blocks from Offroad Design to get the rake that I want. It was too level for my taste. They sent me the wrong u-bolts (9/16" instead of 5/8"), but these will work until I can get the right ones. I'm going out for a test drive now and I'll try to get a good side view photo.
Old 11-22-2020, 08:39 PM   #312
Ol Blue K20
Looking forward to side pics. Mine sits low in the rear. I may need to do this too.
Dale
Old 11-22-2020, 09:41 PM   #313
jimbosprint
Side view.
I like it. It doesn't look like the back is jacked up or sagging down.
Old 11-22-2020, 09:52 PM   #314
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks good and easier than adding a leaf.
DeadheadNM is online now   Reply With Quote
Old 11-22-2020, 10:02 PM   #315
jimbosprint
Actually, these ORD blocks are a zero rate leaf that bolts to the spring pack. Not too much extra work though.
Old 11-22-2020, 10:33 PM   #316
Ol Blue K20
I like it....a lot!
Dale
Old 11-22-2020, 11:16 PM   #317
cornerstone
cornerstone's Avatar
Nice improvement. It's amazing what 1 inch will do.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-23-2020, 08:47 AM   #318
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good to know. Think about adding new Teflon anti-friction liners to replace the oem examples at the top and bottom of the spring packs when you add the correct U-bolts. Seems minor but I did perceive a quieter ride as if they do provide some dampening.
Old 11-23-2020, 11:05 AM   #319
jimbosprint
Now that I have a radio, all kinds of rattles and noises went away. Lol.
Old 11-23-2020, 06:18 PM   #320
jimbosprint
These visors were very dirty. Much better now.
Old 11-23-2020, 10:20 PM   #321
Ol Blue K20
Attachment 2062775
Attachment 2062776
Attachment 2062777
Attachment 2062778
Keep it up and you'll wind up painting that truck.. It's looking great!
Dale
Old 11-24-2020, 01:19 AM   #322
72 tigger
72 tigger's Avatar
Good progress- looking nice!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 11-24-2020, 05:57 PM   #323
jimbosprint
I got a set of tire chains for playing in the snow. The test fit was long so I removed a cross chain.
Old 11-24-2020, 10:26 PM   #324
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What’s the average snowfall in Chico?
Old 11-25-2020, 10:51 AM   #325
Ol Blue K20
but it's a short drive to find some.
Dale
ochre
