Old 11-24-2020, 08:19 PM   #1
Bullzak_83
Scarebird Conversions
Has anyone used Scarebird.com for brake conversions. Custom10nut told me about them, and they are differently cheaper then going full conversion., The question I have is my 70 cst/10 has a 6x5.5 x 1/2" lug bolt pattern, in the kit from scarebird the rotors you use is from a 1995-98 3/4 Gm, to get the 6x5.5 pattern. My son who happens to work a a parts store picked up a pair of the rotors, but they use what has to be a 7/16 lug.
I am checking on the rotors to make sure they are correct, but if they are, does this mean I have to change out the rear lugs to 7/16" I have email the site and waiting on a response, just curious if anyone has installed this kit and what was the results.
Thanks.
Bullzak_83 is offline   Reply With Quote
Old 11-24-2020, 08:33 PM   #2
gmc684x4
Re: Scarebird Conversions
I think you have the lugnut sizes swapped
All 67 72s I have had 6 bolt where 7/16 and 5 bolt trucks have 1/2 lugnuts
Did you upsize your wheel studs on your truck in the past ?
gmc684x4 is offline   Reply With Quote
Old 11-24-2020, 08:33 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The rear lug studs on your 70 c10 should already be 7/16”.
The 95-98 rotors should be metric.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 11-24-2020, 11:10 PM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
I used this kit on the wife's truck. The front studs are 14mm
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 11-24-2020, 11:46 PM   #5
Bullzak_83
Gmc684x4, Nope I bought the truck back in H.S. and I have never done anything to the brakes other than change pads back in the day. Now that doesn't mean something was done before i bought it. That is why I'm confused on the lug size, but the truck differently has 1/2 x20 lugs.
Old 11-24-2020, 11:50 PM   #6
Bullzak_83
The rear lug it’s on your 70 c10 should already be 7/16”.
Hey Lolife99, Everything around the truck is 1/2". Up to this point I have never thought about the lug nuts on the beast. But I am now!!!
Old 11-24-2020, 11:56 PM   #7
Bullzak_83
67 Twins, are you running 17's for the wheels, that is what my son just bought, and they are sitting in the box at this point because once I mount tires,on them I own them.
Old 11-25-2020, 12:00 AM   #8
Bullzak_83
I had found this lug size on the web,and down under Chevy/Gmc Trucks I found the Pickup (6-Lug) 37-87 1/2" x 20
https://www.floorjackshop.com/lug-nut-sizes/
Old 11-25-2020, 12:05 AM   #9
lolife99
lolife99's Avatar
That’s incorrect
Keith
Old 11-25-2020, 12:14 AM   #10
lolife99
lolife99's Avatar
Correct sizes,...
Keith
Old 11-25-2020, 03:08 AM   #11
67 twins
Yes as a matter of fact I am. 17 inch Vision 55 Raylle wheel is what we are running on that truck
Chris
Old 11-25-2020, 08:15 AM   #12
racerop
racerop's Avatar
That just shows a great example that just because the information is in a table
format doesn’t mean it’s accurate
8 lugs back in the 1960’s definitely were NOT metric
racerop is offline   Reply With Quote
Old 11-25-2020, 10:32 AM   #13
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-25-2020, 11:19 AM   #14
bry593
Correct sizes,...
That is incorrect as well.
For 8x6.5 bolt patterns:
thru 1970 is 1/2"
1971 and 72 are 9/16"
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 11-25-2020, 12:29 PM   #15
dagnabbitt
dagnabbitt's Avatar
thru 1970 is 1/2"
Yeah, I thought so.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 11-25-2020, 04:30 PM   #16
lolife99
lolife99's Avatar
thru 1970 is 1/2"
Sorry about that.
I learned something today.
Keith
Old 11-25-2020, 05:09 PM   #17
SCOTI
SCOTI's Avatar
Sorry about that.
Same ole disc brake related updates.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-26-2020, 12:49 AM   #18
Bullzak_83
Hey Group, to everyone that replied to my post. I apologize looks like I need to go back to school for a little refresher in FRACTIONS. Gmc684X4 wins the prize, yes I had the sizes swapped, I do indeed have 7/16" not 1/2"
And 67 Twins you were correct as well.
With that being said and after a little correspondence with Mark at Scarebird, he recommended changing out to metric Lugs on my new 98 gmc rotors to 1/2"x 20
Which I plan on doing.
My next question is it possible to find a 1/2x20 lug in which I could install in the back to replace the 7/16" x20's without having to do a bunch of re-drilling on my drums.
Thanks again for everyone's feedback, I'm a little rusty on working on the ole truck, but it's coming back day by day..
Everyone have a good Thanksgiving, and thanks again.
Bullzak_83
Old 11-27-2020, 11:47 PM   #19
57larry
is he still in business? contact info please
57larry is offline   Reply With Quote
Old 11-28-2020, 12:28 PM   #20
Bullzak_83
here you go, I have corresponding back and forth to a guy named Mark, he has been pretty quick to answer my questions.
https://scarebird.com
Old 11-28-2020, 12:29 PM   #21
Bullzak_83
Old 11-29-2020, 11:54 PM   #22
57larry
thank you
Old 09-19-2021, 09:54 AM   #23
LagunaGlide
Apologies for raising the dead, but not much else on the boards about this vendor. Looks like you have been running their kit for almost a year. What are your thoughts thus far? I am thinking of going this way for an old beat up long bed.
Any tips, or other parts needed I may unawares of?
LagunaGlide is offline   Reply With Quote
