Old 12-02-2020, 09:21 PM   #1
custom10nut
custom10nut's Avatar
Thoughts on a Four 2bbl intake Manifold
I have the opportunity to but an Offenhauser 4-2bbl manifold, complete with the fuel lines and linkage.
This thing pegs out the Cool Meter
For a long time now, I’ve been toying with the idea of building an engine and using a multi carb setup.
My concern is the total CFMs of all the carbs, and how much engine I would have to build to be able to handle them.
Any thoughts from the Old Timers?
Old School Rules!
custom10nut is offline   Reply With Quote
Old 12-02-2020, 09:53 PM   #2
kwmech
Re: Thoughts on a Four 2bbl intake Manifold
You'll have "the cool'' factor going for you, that's about it. Old tech. I think a single 4bbl would be easier to maintain and adjust
Old 12-02-2020, 10:41 PM   #3
Lee H
Lee H's Avatar
I say go for it. That would be so cool at the car shows. I would try it. That being said most folks can’t tune a single carb correctly, let alone 2, 3,........ What’s the worst that can happen? You revert back to a single carb set up. Good luck, and post pics if you go for it. Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-02-2020, 10:49 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Old School Rules!
Cool, if you want cool, because it's zit point **** for performance. I'd rather see a manifold with 6 Stromberg 97s, which were still zit point **** for performance. As for what engine could handle them, you could go look at the Chevy 6-cylinder forums. Good luck with your project. Not meant to be offensive, believe it or not.
~Steven
Simi Valley, CA
Old 12-02-2020, 11:11 PM   #5
truckster
truckster's Avatar
If what you're looking for is something unique for showing, I think it would be really cool. If you're thinking about performance, it's going to disappoint you. Aside from that, it's going to be a chore to keep those four carbs tuned and synchronized.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-03-2020, 01:07 AM   #6
dmjlambert
dmjlambert's Avatar
It sounds outrageous. I like it. I wonder if you could put adapters on it and hook up 4 Quadrajets. It would be fun to custom cut and weld together 4 stock style air cleaner housings to make one massive air cleaner housing with a row of snorkels. That would be style.
Old 12-03-2020, 03:36 AM   #7
Grumpy old man
Grumpy old man's Avatar
Do it .
https://www.youtube.com/watch?v=H-DwOwpk_Nk
Old 12-03-2020, 06:40 AM   #8
A four 2bbl set-up is appropriate for a small block, not a 6 cyl. 2-stage carbs would be cool and perform the best. Those multi-carb set-ups were all about WOT, just like a Torquer intake (straight runner/high-rise). It's style over performance with today's 4bbls available. If that's what you want then go for it. I think of the multi-carb set-ups, other that dual quad, as a '50s-early '60s thing on hot-rods with exposed engine. In one of these trucks it would be something you had to tell people or let them see with raised hood at a show. Dual quad would be period correct and was what I wanted on the 327 in my '67 project that is a period hot truck build. But I backed down once I considered while that is the look I want, the use I want from it is getting out of town... making long trips/touring around. Simple is good and so is using less fuel, so it's a single Quadrajet for that truck
Old 12-03-2020, 08:52 AM   #9
un4gvn!
un4gvn!'s Avatar
Adding all the cfm's together isn't your total cfm. There is a formula to use. Example; if you use two 1000 cfm dominators, the total cfm you would think will be 2000 cfm. That would be a lot of cfm. I can't remember what to divide the total cfm by.
un4gvn! is offline   Reply With Quote
Old 12-03-2020, 09:03 AM   #10
custom10nut
The best aspect of this forum is the seemingly endless wealth of knowledge and experience.
I wholeheartedly agree with all of the input and advice.
For a long time, I’ve been dreaming of building an Old School Hot Rod engine, and then find something to put it in.
If I had a 28-34 Ford Five Window coupe, this would be a slam dunk.Just for the cool factor at shows.
I think the best app would be a Road racer or Dirt track car, and not a Drag Car.
The ultimate goal would be to have this car on an Old School trailer, with my 70 as the Tow vehicle.
Still can’t get my head out of the 70’s
Old 12-03-2020, 09:28 AM   #11
MARKDTN
If you want to show it off and have a cool factor, go for it. If you want to drive it a lot and enjoy it, a single 4BBL will be much better. If you want to drive it and not worry about anything and get better mileage and way less fuel in the oil, fuel injection conversion.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-03-2020, 09:52 AM   #12
AU Doc
First of all, I don't have a clue what I'm talking about. Fortunately, that never stops me from talking
I've wanted to do something similar for a while. I think it would be a much happier install with DBW throttle bodies. That would eliminate the hassle of fiddling with linkages, and it would let you tune each throttle body independently. There are controllers that do a fantastic job of tuning themselves these days. I know there is a cougar running a tunnel ram with dual TBs doing this. It's a street car with a small cube V8. It obviously gives up performance to run that intake, but it sure is cool. Particularly when you consider it has great street manners as well.
There are a lot of ways to slice this problem. At the end of the day, if you like it, go for it!
AU Doc is offline   Reply With Quote
Old 12-03-2020, 10:53 AM   #13
Grumpy old man
Old School Rules!
How much do they want for it ? I see lot's of responses of why not to do it , But not everyone is drinking the LS koolaid . Small block build parts are basically "cheap" every project starts somewhere . If you buy it I'll give you a new engine stand to help get your project going .I have a few extras in the way . I'm not saying you have to drop it in your truck but while your building the engine you can decide what to drop it in .
This one runs fine and who cares about MPG ? It's about Smiles per gallon ! and I have a good Muncie connection , Great now you've got me thinking about another project !
https://www.youtube.com/watch?v=FtVfuWy3-Ts
Old 12-03-2020, 11:31 AM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by Grumpy old man View Post
That setup says, "Feed me, Seymour!".
~Steven
Simi Valley, CA
Old 12-03-2020, 11:47 AM   #15
Grumpy old man
He lives about 1/2 hr away from Pigeon forge / Gatlinburg Tn , Arguably one of the biggest cruise in / car show destinations . Whats a little gas when you could have a bunch of fun ?
Old 12-03-2020, 12:05 PM   #16
Ironhorse
Ironhorse's Avatar
Have never seen or heard of a Offy 4-2BBL intake but have to admit the WOW factor at a car/truck show would peg the meter at top end. Just do not see very many multi-carb set ups anymore at shows. LS and EFI fever has taken over so many engine builds, even a single carb is less and less prominent. Getting a multi-carb set up be it on a BB or a SB engine can be a bit problematic to dial in but really, how often have you seen them at your local car show? Sometimes it's nice to step out of the box and venture forth. I'm running a SBC 283 with dual fours in my 57 Chevy 2 dr sedan and get a LOT of comments about it both in person and on a couple Tri-five boards I am on. Totally old school but then being almost 72 years young so am I, LOL.
Some what local to me board member Elliot949 has a really sweet 67 short bed , 327 with a Tri-power set up under the hood. When was the last time you EVER seen a 67-72 pickup with a Tri-power?
Agree with Grumpy, "Smiles per Gallon" sometimes means more to me than miles per gallon.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 12-03-2020, 12:21 PM   #17
Grumpy old man
Well this might be a hole lotta fun at a car show . :lol
https://www.summitracing.com/parts/ofy-3924
Old 12-03-2020, 01:02 PM   #18
truckster
truckster's Avatar
I think you'd have to fill the tank twice... once just to fill the fuel bowls.
But I agree with you. The classic small block with a carb (or carbs) is still a great setup. I put an L31 in my Blazer, but chose to go with HEI and a Quadrajet.
Where Custom10nut said he plans to use it for a show car, I can't see any reason not to do it.
Old 12-03-2020, 01:15 PM   #19
tommy3horse
tommy3horse's Avatar
Wow Grumpy, thats awesome! The fuel plumbing would need to be like artwork, love to see it hooked up and running on something...
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
Old 12-03-2020, 03:15 PM   #20
72c20customcamper
72c20customcamper's Avatar
Not to hard to set up multible carbs. Hardest part is syncing them but it's just like doing a motorcycle. Also my AMX has dual Carter competition 625 cm 4bbls. Took a while to get the jets dialed in but it runs well. And yes peoples eyes light up seeing multi carb setups
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-03-2020, 04:37 PM   #21
j_cst_10
j_cst_10's Avatar
People with old Japanese motorcycles deal with it all the time. My KZ1000 - 1L 4 cylinder with 4 CV carbs.
Obviously a little different set up but it can be done! pain in the butt...yes
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 12-03-2020, 04:49 PM   #22
custom10nut
See now, that setup just pegs out the Cool Meter, as would the 4x2 that I found.
Then you get the practicality side of the discussion.
I’ve gotten a little more practical in my older age I guess.
BTW, as a kid in the early 80s, I had a 10 second, 2-4bbl 427/4spd powered Nova that I drove around from April to November (In Michigan). I worked on the Family Dairy farm so most of my driving was by choice and Not necessity.
Like I said, part of me can’t seem to let that go.
Grump, the guy want $750 for it, with all the linkages and fuel lines, but the carbs need to be rebuilt.
Old 12-03-2020, 04:56 PM   #23
truckster
truckster's Avatar
What carbs are on it?
Old 12-03-2020, 06:40 PM   #24
custom10nut
In the Movie “American Graffiti”, John Milner’s Yellow ‘32 Deuce Coupe had a 4-2bbl set up on a 327. I know movies are movies, so as far as being super fast, I guess it was written into the script.
Old 12-03-2020, 06:45 PM   #25
custom10nut
Four Rochester 2Gs
