Old 07-19-2020, 08:49 PM   #1
sweetk30
sweetk30's Avatar
wheel vintique rally rims whats the deal ?
i searched a bit and see there not available now and no real info why .
i was looking to get 2 or 4 if the deal was good 15x10 5 lug rims .
anyone know the scoop or story on were they went ?
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-20-2020, 02:07 AM   #2
wixthedog
wixthedog's Avatar
Re: wheel vintique rally rims whats the deal ?
Have you tried calling them? I ordered mine from Summit last year.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 07-20-2020, 10:57 AM   #3
sweetk30
sweetk30's Avatar
jegs shows both part #'s but there on back order until end of this month and early next month .
5" backspace is end of aug
4.5" backspace is end of this month .
knowing there is 2 options what is every one running on there 2wd ? my rig is 2wd owered 2.5" and 12 bolt rear .
Old 07-20-2020, 05:33 PM   #4
evan
evan's Avatar
I have Vision American Muscle 55 Rally wheels bookmarked as a possibility. Have you considered those? They have good reviews and seem to fit stock hubcaps too based on what I've read.
Evan B.
evan is offline   Reply With Quote
Old 07-20-2020, 07:58 PM   #5
Loco83
Loco83's Avatar
I wouldn't buy a WV rally rim again, can't get them to balance out, can't send them back, their disclaimer is once the tires are mounted your on your own BS.
Check these guys out instead.
http://davidsrallywheels.com/wheels/4058379
Loco83 is offline   Reply With Quote
Old 07-20-2020, 08:17 PM   #6
sweetk30
sweetk30's Avatar
wrong style for me . i want the 16 hole squared style for the gm trucks .
Old 07-20-2020, 08:20 PM   #7
sweetk30
sweetk30's Avatar
funny you should say that . go look at the part#'s of the truck rally for both places . . . there the exact same .
and i always check my rims on the balancer first . 15+ years i did wheels and tires in a shop . but i wasnt the sale guy just the install guy .
Old 07-20-2020, 08:21 PM   #8
sweetk30
sweetk30's Avatar
i am leaning to the 15x8 i have for the rear and i have atleast 1 good maybe 2 of the G-series van 15x6.5 i can do for the front end . this would get me a good skinny/fat look .
Old 07-21-2020, 06:03 AM   #9
wixthedog
wixthedog's Avatar
I run a 15x8 4” front and a 15x10 5” rear BS.
Mike
Old 07-21-2020, 01:23 PM   #10
ShortHaul
ShortHaul's Avatar
So I've bought from WV a bunch recently, and even when the say they're back ordered they have shipped before their estimated date. I just bought my latest set of 16x8 8 luggers and they said backordered until August. They are set to arrive today. I can confirm that they aren't always the easiest to balance, but my tire/wheel guy said that's not too uncommon for steel wheels... I'm no expert, but I've bought 3 full sets in the past 3 years, plus a set of rears for my impala, and a spare for Sweet Pea and so far no issues whatsoever... (thats 15 wheels if you're counting I guess I'm keeping these guys in business!)
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 07-22-2020, 12:22 AM   #11
Factory Guy
Factory Guy's Avatar
Bought All 5 of my WV from Jegs with no problems last year all balanced fine. All 16 x 8".
Many good reviews on WV from guys I hang with.
Compared to Stockton Wheel they were much more reasonable and you get a new wheel to boot!
I think Stockton wheel wanted $300 a wheel for a similar combo to what I got from WV.
Factory Guy is offline   Reply With Quote
Old 07-22-2020, 06:18 PM   #12
sweetk30
sweetk30's Avatar
well i just ordered 4 cooper cobra tires .
235/70/15 for the front and 255/70/15 for the rear .
plan is test fit a 235 on a 6.5" rim and see if i like the look . if not swap to a 7" rim . the rear will be my 8" rims . i want to get this sucker rolling again and finished . so use what i got and get it done . if i find a deal on some 10" wide later then maybe we can get them and change it up a little .
Old 07-24-2020, 05:15 PM   #13
sweetk30
sweetk30's Avatar
well 2 of the 4 cooper cobra radials g/t showed up today so i went over to a friends shop and test mounted the 235/70/15 on my G-10 van 15x6.5 rally rim . not to bad at all for looks of the sidewall . so i took it back off the rim and set it in the pile for the blast box to strip them down BARE .
going to do them up in solid white to go with the dark blue / white combo the truck will be . but for now here is a few pics to let you enjoy .
2 test fit shots
rim before blast and after blast .
Old 07-25-2020, 08:28 PM   #14
sweetk30
sweetk30's Avatar
got a little bit further today with 1 front and 1 rear . finished blasting and got 3 coats of bright white on them. then the center cap's got tested out to see what i want . i was leaning to the black caps but now i see the chrome i am leaning that direction . using 88-98 center caps and conversion nuts to put them together .
Old 07-27-2020, 07:16 PM   #15
sweetk30
sweetk30's Avatar
looking real good these days .
Old 07-28-2020, 07:11 AM   #16
Very Nice!
Old 08-01-2020, 07:51 AM   #17
JT_Trucks87
Active Member
JT_Trucks87's Avatar
Getting my wheels from them was an absolute nightmare. Mine are 16x10 but they were on national back order. I thought ordering directly from wheel vintiques would speed the process up. I was wrong took almost 9 weeks from ordering them to receiving them. I am happy with the product though.
1987 V30 Silverado SRW 454/400 4x4 104k original paint
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne:
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
Instagram: jt_trucks3500
JT_Trucks87 is offline   Reply With Quote
Old 08-01-2020, 11:09 AM   #18
sweetk30
sweetk30's Avatar
thanks for the info guys .
got my lug nut caps and conversion nuts the other day . here is what i have so far .
Old 12-03-2020, 09:47 PM   #19
SSSilverado
SSSilverado's Avatar
Nice.
SSSilverado is offline   Reply With Quote
Old 12-03-2020, 09:54 PM   #20
SSSilverado
I am also looking for a 15x8 rally for a spare. I tried getting a steel rim, but my drums in rear wouldn't let the wheel all the way on. I thought Summit used to carry Truck Rally wheels, I thought they had 8" and 10" widths, I'll keep searching. I had all my 4 wheels power coated. I sanded & touch sprayed them for years, finally got them powder coated.
