11-28-2020, 04:53 PM | #1101 |
Moderator
Re: What did you do to your truck today part IV
11-28-2020, 05:52 PM | #1102 | |
power Lumbar on both sides. That Is why I chose them. There is also a center console, not in the pic. The original fabric is glued to the cushing, making the recover my upholsterers nightmare. He made it work, but not cheap, especially with that red leather. We also deleted the headrest. |
11-29-2020, 09:13 PM | #1103 |
After 10+ years my truck and its hood have been reunited!
Just a few more things to do and the exterior will be completed. |
11-29-2020, 10:10 PM | #1104 |
Wow 10 years! It looks vary nice.
12-04-2020, 08:20 PM | #1105 |
I got the 350 dynoed today he changed out the secondary metering rods and it is running better than it even has. He also adjusted my trans cable at the throttle and that helped a lot also. Problem is I got a crazy rear end shake around 4000 rpm. 197 hp at 4493 rpm and 246 ft pounds at 3710 rpm.
12-04-2020, 08:28 PM | #1106 |
Soaked the backing plates for the front brakes on the '66 in Evap-O-Rust, rinsed and dried them. Next time out to the shop I'll bead blast them, then etching primer and then black. One more small step forward!
12-05-2020, 02:10 PM | #1107 |
64-66 CHEVY JUNKIE
Looks Good Porky..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
12-06-2020, 02:06 AM | #1108 | |
12-06-2020, 02:27 AM | #1109 |
Yah I know what you mean. The only reason I knew about this place is because of the tv shows Engine Masters and roadkill. It was an hour from my place.
12-06-2020, 09:51 AM | #1110 |
Made a little fix on the driver side of my hood. This is the most assembled my truck has been in years. Feels good seeing it actually looking like a truck finally. Hopefully my pictures work.
12-06-2020, 11:06 AM | #1111 |
Looks great, Joe! What did you use on there? Obviously NOT just Bondo. I'm going to be dealing with something similar when I get that far.
12-06-2020, 09:45 PM | #1112 |
Thanks! I just cut out the section that was “over-hanging” and made some relief cuts to allow the metal to fall into place a little easier. I ended up making longer relief cuts than are pictured too. No filler on it yet but it will require some in the end.
12-08-2020, 09:24 AM | #1113 |
Finished up installing the rear end, 4" drop springs, shock relocators, brand new innards (3.73 posi). Waiting on the panhard bar, should arrive in a day or so. Going to run brake lines between now & then.
I'd like to propose a toast... to internal combustion and wind in the face. ~Michael Sarrazin "The Gumball Rally" |
12-09-2020, 09:45 PM | #1114 |
Installed Captainfab's Power steering conversion into my 62, and began the process of shortening the frame for a 7' bed. 8"/4" cut.
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 |
12-09-2020, 09:54 PM | #1115 |
Installed my rubber floor mat...Getting closer to being totally finished. Been driving it a little...
12-09-2020, 11:50 PM | #1116 |
Who Changed This?
That's looking good!
12-12-2020, 09:44 PM | #1117 |
Got the grille and inner fenders in place today.
12-13-2020, 12:14 AM | #1118 |
Finished the steering stuff.
12-13-2020, 08:47 AM | #1119 |
53sparky: who’s adapter are you running?
12-13-2020, 10:09 AM | #1120 |
It's CaptainFab's PS adaptor. While I think he designed it originally for the 63-66 chassis, it does work on the earlier X frame chassis. THIS was a helpful thread for me.
12-13-2020, 02:44 PM | #1121 |
Finally painting it yesterday.
12-13-2020, 09:35 PM | #1122 |
I shortened the frame today following a modified version of the method outlined by SkinnyG on his thread.
12-14-2020, 12:37 AM | #1123 |
Being a lurker more than a provider of information unless you need advice on what to do after dropping in a crate motor then having the lower radiator hose come off without knowing it and almost burning it up.....
I love your trucks! I came into an inheritance from my mama that I may use to paint my truck after owning it since 1997! Great jobs and great stories! I actually recently got it started and took for a drive as it's been super cold and dealing with siblings evil ways since moms death as I'm executor of the trust. She ran good after possibly saving the motor with some new fuelie heads (I think), she ran good and a little gun shy as it just was almost toast. I saved the lower end, compression and leak down test passed. Bent two valves as they cooked and stuck in the guides. Other than that, slowly replacing stuff. My truck is in the hello portion a few pages back by now I'm sure. Such artists on this forum. |
12-15-2020, 08:23 PM | #1124 |
Finished up lowering the front 2.5 spindles, 2" springs and rear 5" springs. Picked up new set of wheels andbtires, just waiting for center caps.
1964 C10 Rusto-mod 5.3L - L59 |
12-15-2020, 09:03 PM | #1125 | |
