#3251 |
Re: PO has me PO'd
![]() Decided to go with the dappled look, since I had a old jar of undercoat that went off and left a somewhat chunky solution, seems to have better effect on filling in the pits left by the rust. Now I can look for a grey paint Sorry for getting my finger in the way
#3252 |
Re: PO has me PO'd
![]() Thinking of mounting some fog lights Opinions welcome I hate clutter so, give me what's on your mind
#3253 |
I miss this truck.
Re: PO has me PO'd
I think I'd have to see it on the truck, and I don't think I'd go with Amber if I did it. Strictly personal preference though.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#3254 |
Too Dumb To Know Better
Re: PO has me PO'd
You have spent too much time, effort, and money to screw it up now.
I vote no. |
#3255 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: PO has me PO'd
I'd pass for now
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#3256 |
Re: PO has me PO'd
![]() Thank you all for your p/c and unbridled opinions. I'm going to go with the nay, for now, but I may revisit it with KC lights in the near future Now onto my front driveshaft, it was rebuilt by a local driveshaft shop. Never really gave it much thought as it never really made any noise, but when they did my transmission they left it out, telling me it was bad. Sure enough, when I took it to the shop, I couldn't believe how sloppy it was, not only twisting at the splines but up and down deflection, so that is my report OSHA said they couldn't paint it, since they didn't have a spray booth
#3257 |
Re: PO has me PO'd
Thank you GMC and Chevrolet for stamping the same part for a fleet side as a blazer Jimmy
#3258 |
Re: PO has me PO'd
Use the 3 o'clock position on the cutoff wheel, or it will tend to kick back, basically cut forward
#3259 |
Re: PO has me PO'd
#3260 |
Re: PO has me PO'd
![]() Got to do a little more clean up on the wheel flange, used the old pry remove resistance and roll method with pliers
#3261 |
Re: PO has me PO'd
![]() The angle of the patch panel is no where near what it has to be to fit up with the inner panel
#3262 |
Re: PO has me PO'd
![]() ![]() Sneaking up on it
#3263 |
Re: PO has me PO'd
#3264 |
Re: PO has me PO'd
Went over to eastwood co. To pick up some of their super strong panel magnets, easier then clamps
Item number20421 ![]()
#3265 |
Re: PO has me PO'd
You have to make slices, and then 2 bends to fit up to the inner panel
#3266 |
Re: PO has me PO'd
This side is getting close
#3267 |
Re: PO has me PO'd
May have gotten a little ahead of myself, should have left the patch panel large. Don't know if I can weld .120 gap
#3268 |
Re: PO has me PO'd
![]() May not be a total waste of time, I maybe able to use some 70/30 lead tin to fill in the gap left after welding
#3269 |
Re: PO has me PO'd
Jinxed by the mid west members
#3270 |
Carpe manana
Re: PO has me PO'd
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 01-03-2021 at 10:17 AM. Reason: Changed to a frown |
#3271 |
Re: PO has me PO'd
can I change that to a frown, you being a Mod. and. All, I have to lug salt with a bad back
Thought one of the rules was not to quote a mod.
#3272 |
Re: PO has me PO'd
Started working on my vent windows, rebuild kit from brothers. Disassembly went ok except a couple of spinning heads, which I took care of with my dremel and a new cut off wheel
#3273 |
Re: PO has me PO'd
![]() If you are drilling the rivets out and you don't see shavings stop, and use a new drill bit, if you continue with a dull bit you will only work harden the rivet, more probems Use a good sharp punch, in the center of the rivet, it will keep your drill from walking, and use a cutting fluid to keep the drill bit sharp
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-07-2021 at 10:15 AM. |
#3274 |
Re: PO has me PO'd
Ordered a new handle with my rebuild kit, used a 3/32 drift pin punch, but you don't have to knock it out all the way, just far enough to get past the groove in the post inthe window
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-07-2021 at 12:19 PM. |
#3275 |
Re: PO has me PO'd
Ordered a new handle with my rebuild kit, knock the pin back with a 3/32 drift pin punch, it doesn’t need to come all the way out, just past 5he groove inthe post
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-07-2021 at 12:24 PM. |
