Old 12-16-2020, 11:25 AM   #76
dsraven
Re: Project Fargolet
like this
https://www.summitracing.com/parts/q...BoCq2cQAvD_BwE
https://www.summitracing.com/parts/a...hoCEQEQAvD_BwE
https://www.summitracing.com/parts/s...RoCObcQAvD_BwE
Old 12-16-2020, 11:26 AM   #77
dsraven
personally I wouldn't jump start from the alt terminal. wire gauge isn't sufficient for the draw in my opinion. thats me though.
Old 12-23-2020, 08:20 PM   #78
Father&son56project
Paintman: I did consider your suggestion as well. I have access to tons of old agricultural equipment, including sheet metal with the exact same patina as the truck, so I could have made a box that would have looked like it came with the truck. I am keeping that idea in the back of my head for when I deal with the gas tank filler neck.
Tempest67: I thought that big drive shaft was aluminum. Can those things be shortened?
After playing around a little more, I opted to try the under-fender spot for the battery. My build recipe calls for using everything possible from the S10 and avoiding buying stuff unless absolutely necessary.
With the battery issue decided, it was time to get to work on it. Before I could do that, I had to sort out the inner fenders as the battery would sit near one of them. I thought they were gonna give me problems, but it turns out I just needed to remove the forward lower corner from both. They are not perfect, as they were originally meant for that flat frame of the Fargo, so the lower edges don’t offer as much protection as I’d like. I may add some bolt-on extensions to improve that, and I will add some sort of rubber skirting in the area of the upper control arms.
Once the inners were in place, I could see that there was still bags of room around my new battery spot, so I fabbed up a mount. I oversized the mount and moved it slightly forward to allow for a wider range of battery sizes (I just use wrecking yard batteries). The wiring gods smiled on me here! By snipping just one factory zip tie, the positive lead had just the right length to reach the battery perfectly. The negative lead (which is grounded to the front of the block) was too short, but I found that there was an identical threaded hole at the rear of the block right where the battery sits. After running a tap through it to clear out the crud, the negative cable was installed without having to alter the length at all. There’s still a couple of wires I have to extend, but I’ll do that when I lay out the final routing of wires. Here’s the fabbed up parts (tray, hold downs and protective shield):
And here it sits in place. I can easily reach in to attach booster cables if I ever need to, and the battery can be removed with just a 3/8ths wrench. The tray can also be unbolted. The negative lead is not hooked up as I have wires everywhere and didn’t want a fireworks display:
I also took the time to fab a quick bracket to mount the ECU on the firewall. I think this spot gives me some decent options for running those huge bundles of wire that feed it:
More to follow!
Father&son56project is offline   Reply With Quote
Old 12-31-2020, 07:15 PM   #79
Father&son56project
I spent a day doing little stuff that’s ”under the hood” while access was easy. I cleaned the plugs, disassembled and cleaned the front brakes, and installed new front brake hoses. I then took a close look at the steering shaft routing in order to deal with 3 minor issues that I knew I’d have. Here’s the future path of the steering shaft (the dowel in the pic).
The heat shield around the foremost plug had to be cut down a bit, and the straight boot plug wire was swapped with an angled boot wire from my parts truck. The power steering low pressure line was also in the way, and needed to be bent. It had some rust on it, and I was worried about it cracking or kinking. Joedoh had suggested inserting some kind of rod inside the tube before bending it, in order to prevent kinking. I played around with this a bit and discovered something that works perfectly: a spark plug wire. By cutting off the boot of an old plug wire, I could feed the wire down the low pressure tube as far as I wanted, as these wires are extremely flexible and easily snake through the steel tube. I then was able to put a gentle series of small bends into the tube, which retained it’s round shape perfectly. You can still see the plug wire inside the tube prior to its removal:
With that out of the way I decided to finish off the exhaust system which I had been avoiding as it would involve lying on the concrete. I had to weld in a hanger at the front of the catalytic converter, add some gaskets and tighten a few things up. I had also discovered an interference problem when I mounted the rear passenger fender. The S10 tailpipe ended up inside the fender:
Thank god for that parts truck I have outside. I went out and cut off the end of the exhaust system from the Blazer, and sure enough there was a section that had a nice bend and the exact same diameter that I needed (the right half of the section in the pic):
After cutting off that hanger and making a couple of quick cuts, followed by some welding, I had a tailpipe that was no longer inside the fender:
More to follow!
Old 01-29-2021, 07:26 PM   #80
Father&son56project
I’ve been plugging away at the “to do” list on the truck, it's been mostly little stuff (nothing particularly interesting), but there’s a couple of S10 swap specifics I’ll share here. First is the e-brake cable pass-thru. The S10 rubber pass-thru is designed for a horizontal floor, and not a particularly thick one. The S10 grommet also appears to be placed on the cable prior to forming the ends, as it appears to be non removable/replaceable. My truck floor is angled where the pass-thru goes, and happens to be at a spot where multiple panels overlap, so its far too thick for the S10 grommet. My S10 also had what appeared to be a nearly new cable assembly so I wanted to keep it. I tried to modify an angled grommet to work, but it was frustrating and would not have been great so in the end I just fabbed up an angled mount that allowed the use of the S10 grommet. It snaps right into place and seals nicely:
Next was the S10 shifter cable pass-thru. This thing does a nice job of sealing off the cable, but it’s designed to come through the floor just in front of the bench seat. Not great for these old trucks due to the sudden sharp angle where the floor rises to meet the firewall. The cable however is free to slide in the pass-thru, so the pass-thru can just be slid to wherever it would work best. The floor of the S10 has a nicely molded section of sheet metal that grips the pass-thru securely, so it can be cut out and added to the floor of the project truck.
S10 swap tip: Buy a good one!!!! All kidding aside, if anyone plans on one of these swaps it’s well worth the money to find a good, rust free, well maintained S10 (assuming of course that you are not merely after the frame). The number of reusable parts is unreal if you have a good donour. When I needed the pass-thru for the shifter cable I simply cut it out of the S10 and welded it in. Here’s the underside of that pass-thru:
Mine was completely rust free, just needed to cut & weld. I’m so glad I waited till I found a solid donour S10.
Here it is welded into one of my floor panels (no attempts to make it pretty, it can’t be seen unless you either lift the carpet or lie under the truck).
And here it sits, just waiting to be hooked up to the column when I do my final assembly (there’s no interference with the gas pedal, it’s just the way the pic came out):
Next was horns. Once again, sheer dumb luck helped me out. By simply drilling and tapping a hole in each rad support bracket I was able to bolt on the S10 horns using the brackets they came with. The brackets are mirror images of each other and I now have a matching set of horns that sit perfectly inside the curved front grillwork:
I then took a look at the front bumper, which was a mess. This truck had a hard life, and the front bumper was badly twisted, and bent in sharply on the driver’s side. It also had the nice big buckles in the edges that you get whenever you bend metal out of shape. The metal in these old bumpers is thick (3/16th’s of an inch), so I knew I was in for a chore. One thing I have learned since moving out to the countryside: If you are not sure how to do a heavy chore, ask a farmer! After conferring with my farmer neighbour I managed to save the bumper. It was actually really easy to do. To remove the twist, the bumper was chained down to my heavy steel work table, and a 2nd chain was used to attach a big steel prybar:
Removing the twist with a 6 foot prybar was delightfully easy. All it took was a couple of mild lifts on that huge bar. Next was the bent driver side. This involved a couple of rounds of using both a come-along and a BFH. The bumper was again strapped to that table, and the come-along was used to remove the bend, along with the BFH to flatten out the buckles along the edges:
Here it is now:
I completely forgot to take a “before” pic, which is a shame as this thing was a mess. It ain’t perfect, but it will look just right on this beat up truck. While on the topic of messes, I also had to deal with the front fender braces, which had also been nicely bashed up. I was expecting to fab up a completely new pair, then realized that I could just do some untwisting and modification of the lower end (which no longer had a place to bolt to as a result of the S10 frame swap). All I had to do was chop off the lower section and fab a replacement piece. Here’s one of the original braces:
And here’s the new modified brace:
And here it is in place, bolted to a mount (which is just tacked to the frame for now):
I’d earlier posted about that huge S10 wiring harness, and here is how I dealt with it on the inside of the cab. For now my goal is to get the thing running and spend some time driving it and debugging any problems. I still plan to greatly thin out the harness (both under the hood and inside the cab) but I didn’t want to overdo it right now as I have very limited experience with wiring and zero experience with computers and fuel injected engines. I erred on the side of caution for now, but later on I will spend some time in the winter months making the harness simpler.
For now I have a good idea of how to route that huge wiring harness under the dash, using those rubber lined clamps. Dealing with nuts and bolts up the far end of the dash is however not a ton of fun, so I installed studs wherever possible so that I can affix those wire clamps using only a nut later on. I also made the pass throughs in the 2 spots where the S10 harness goes through the firewall. I plan on sticking the bulk of the harness on the passenger side. The driver’s side gets pretty busy with the brake and steering assemblies that I fabbed up, so routing wires there would not be fun. Other than the firewall, there are really no good spots to affix those rubber lined clamps so I had to make some panel(s) to attach the clamps and to allow for relatively easy servicing of breakers, flashers and fuses. Here it is for now, securely fastened with the bulk of it on the passenger side. It’s not yet taped/loomed as I still have to figure out how to hook up heater, headlights, gauges, etc:
As I continue to plug away at my to-do list, I keep spotting more stuff to do. The darn list is growing rather than shrinking. More to follow!
Old 01-29-2021, 08:41 PM   #81
olcarguy
your doing a super fine job, keep at it
olcarguy is offline   Reply With Quote
Old 02-01-2021, 10:41 AM   #82
Tempest67
Tempest67's Avatar
that wiring looks very neat and clean, nice work. (so does everything else)
keep at it, and thanks for the updates.
Tempest67 is offline   Reply With Quote
Old 02-26-2021, 07:37 PM   #83
Father&son56project
Thanks guys. I have been trying to pick up the pace a bit, but everytime I do something I spot 2 more things I’d forgotten about! Continuing on with my to-do list I tackled the front bumper. My options here were a bit limited due to the grill design of the Fargo. The grill openings limited me to using the inner sides of the S10 frame rails (which had to be shortened a fair bit to sit behind the curved grill). To deal with this I capped off the ends of the rails with some plate steel, and then built brackets to reach the bumper. These trucks didn’t have bumper brackets- the bumpers bolted right onto the front frame rails. I wanted adjustability, so I made 3 inch mounts that sit inside the bumper (which is 4 inches inside). By mounting the bumper at the mid point, I have a half inch adjustability up and down at each mount (I made a bunch of big shim plates to allow me to fool around with levelling things out-I still need to drill the holes in them). Oblonging mounting holes on the mounting brackets if/as required will allow for minor side to side and in/out adjustment. Here’s what I ended up with:
The issue of the gas filler tube was something I had been grappling with for a while. I really like the stock look of the Fargo with the filler cap in the corner of the cab, just behind the driver’s door, and I wanted to keep that original look. In the end, I opted to put the filler in the box, and leave the stock filler mounted in the side of the cab (modified to protect against anyone ever accidentally trying to fill my cab up with gasoline!).
I then got working on the new filler. I decided to come up through the bed, and conceal the filler inside a permanently mounted toolbox. I wanted the new filler to come straight up from the S10 tank and out of the bed at a 90 degree angle. The S10 tube is bent, and after a few measurements I had angle figured out. I ordered a Gates model #24712 45 degree filler hose tube and this gave me a perfect angle. The vent tube also needed to be cut and welded to a new angle, but this was just a quick cut and some mig welding. One thing I noted was that the check ball was missing from my S10 fuel filler. The plastic tabs that prevent it from falling downwards were still in place, so how on earth could this thing be missing? Once again, thank god for that old Blazer in my driveway. After a miserable half hour in rather frigid temps I had removed the Blazer filler and confirmed that the check ball was still in it. Here’s a shot of the S10 filler, the Blazer filler and the check ball that came out of the Blazer filler:
Here’s the S10 filler, with the excess length removed to shorten it up:
[url=https://flic.kr/p/2kE66GA]
By gentle bending of the plastic tabs, you can remove or insert a fresh check ball. A few hours later I had my modified S10 filler done and coated with some paint (and I can now say that I have performed my first ball transplant ) The modified filler is about 5 inches shorter than stock. Here is the finished filler:
Next was the bed. I spent a ton of time getting the correct heights for the bedsides and lining everything up nicely. Actually, “nicely” may be an overstatement. This truck was bashed so badly that it’s simply not possible to line things up perfectly, so I focussed on eliminating things that catch the eye and basically averaged out all the errors. For the bed itself I opted for 14 gauge checkerplate steel. It will quickly rust to blend in with the rest and it keeps me from losing more bed depth. If I ever decide that I want the look of old wood, I can easily get my hands on old barn boards around here, and mount them on the bed. I could even use relatively thin boards as they would just be a veneer over the steel. With the help of an able bodied assistant I was able to cut that sheet of checkerplate to length, trim out the spot for the filler tube, and slide the whole mess into place, sort of…..On our first try it got stuck between the bedsides and we couldn’t figure out why. It turns out that the 48 inch width of the sheet was actually 48 ¼. After a long slice with the angle grinder it slid right in. Angle strips for the bedsides are not something that I can easily pick up around here, so I just used the thinnest angle iron I could find (still a bit thick for my liking, but plenty strong!). Instead of welding the strips to the bedsides I opted to use bolts as I don’t know what the future holds for this truck and I want to be able to make changes easily. The bed rests on a sturdy frame that I made for it. The frame is 100% square and sets the box right into place without the need to measure anything. The supports on the frame will also keep the checkerplate from sagging if I walk in the bed. Realistically the heaviest load this thing will ever see is a person walking on the bed. Now it was just a matter of drilling a bunch of holes and tossing in nuts & bolts.
Hindsight thought: If I ever do this again, I will just reuse the S10 bed and crossmembers. The tiny bit of extra bed depth that I got was not worth the hassle and cost of making the fancy frame. With the bed on it was time to finally finish off the fuel filler. As I’d said earlier, I really wanted to keep the outsides of this thing looking as original as possible, including keeping that cool old filler tube that sticks out of the cab behind the driver’s door. I however had no intention of running fuel through the cab, so here’s what I did to keep “the look”. The original filler tube was left in place, but it was cut off inside the cab and a plate was welded inside:
And now I had that original look, without the possibility of anyone ever sticking a gas nozzle into it and filling up my cab:
Of course I will need to add gas to this thing so I added the modern S10 filler tube but kept it out of sight. My filler tube now comes up out of the bed……...
…...and it lurks inside of an old ammo box…….
I will eventually replace the old ammo box with a larger toolbox that can also hold a jack, flashlight, emergency repair tools, etc. but right now with the covid lockdown in effect I have no swap meets or flea markets to go to in order to hunt down neat old stuff. And here’s the tail end of things now:
That’s enough for this post. More to follow!
Old 02-27-2021, 09:41 PM   #84
olcarguy
I like it....I would keep the ammo box ...It's got a good look and feel to it.....
Old 02-27-2021, 10:03 PM   #85
6DoF
6DoF's Avatar
dude, i might steel the ammo box idea! i have an old school job-box tool lock box i think I'm going to use for enclosed storage in the bed, and would have just enough room left for something like that next to it.
6DoF is offline   Reply With Quote
Old 02-28-2021, 01:55 PM   #86
Rusti
Rusti's Avatar
A lot of grate work on that truck. Grate idea to solve different problems. Keep on that grate work.
So long
Arnd
Rusti is offline   Reply With Quote
Old 03-01-2021, 10:25 AM   #87
Tempest67
Tempest67's Avatar
Good to see more progress.
Looks Great
Old 03-04-2021, 02:46 AM   #88
joedoh
joedoh's Avatar
nice problem solving!
I think the check ball is an anti-siphon device.
Old 03-12-2021, 06:33 PM   #89
Father&son56project
Thanks guys, and you’ve talked me into it. The ammo box stays! I will look at a secure way to store the jack and a few tools in the cab.
And thanks Rusti. I see you are from Wurzburg. My mom is from Arzberg, just down the road from you. Getting parts there must be a lot of fun.
Joedoh: If I’d have known that I would have just ignored it!
I had worked on the front bumper a short while ago, and just needed to drill holes in the shims to finish that job. I did that and then played around with them to get the best fit. I also remembered that I had a bracket that came with the truck, mounted on top of the front bumper. I dug it out and reinstalled it. I have no idea what its purpose was, but it's a million years old and came with the truck so I’m keeping it attached. A side benefit is that it helps hide the fact that I had to use shims to “average out the errors” on the front end of this thing. Here’s a couple of shots of the bumper and that bracket. If anyone knows the purpose of it, feel free to tell me:
I received a parts order from Rockauto and got to work under the hood. First was the lower rad hose. I have been using “The Formula” from Skymangs S10 Swap Thread, and I have the Speedway universal 19x22 rad with the outlet cut and rewelded so that it points outwards rather than inwards. As a result, I now needed a custom hose as the distances and angles were all wrong, plus the Speedway rad outlet is 1 ¾ inch rather than the 1 ½ inch that stock S10’s have. I went through the various manufacturer’s hose charts and lost my mind trying to find something to fit. I eventually came up with a painfully easy solution. First, I bought 2 stock S10 lower rad hoses (1 ½ inch hose with one end flared for 1 ¾). I put one hose on the engine side, just like it's supposed to go, then I grabbed the 2nd hose and spun it 180 degrees so that it attaches to the 1 ¾ inch radiator outlet. Here are the 2 hoses, which actually have a straight stretch where they want to line up with each other:
Now it was just a matter of picking a spot along that straight stretch and cutting both hoses. With the addition of a 1 ½ inch hose coupler I ended up with this. Length and angles are just right:
Once installed, this is what I had. Fits like a glove:
The upper rad hose looked like it was going to be fun, as it’s 33 inches long and shaped like a snake. I fooled around with it for a bit, then discovered that if you loosen the clamp on the thermostat end and twist the hose clockwise, it ends up looking like this:
Now I just had to add a piece of hose with a 90 degree bend that fit the Speedway rad (1 ½ inch). A 1 ½ to 1 ⅜ coupler then joined the 2 hoses.
I’m not sure that I’m fully happy with it, but it will work for now. Before I get rid of my parts truck, I will scavenge the thermostat housing and perhaps fool around with fabbing a new outlet that goes straight up. This would shorten the length of the upper rad hose, and would look a lot neater. But that’s a chore for next winter.
The heater hoses were wonderfully simple. One of them just needed to be shortened by an inch or so and it fit the Mopar heater perfectly. The other S10 heater hose is a larger diameter (why would you use 2 different diameters to plumb the heater?), but I was able to easily connect it by simply adding an adaptor that throttled it down to 5/8ths and then plugging the 5/8ths section into the heater. Again it fit like a glove (dumb luck).
The next item out of the Rockauto box was a wiper arm and blade. I had found plenty of wiper arms and blades on the specialty vendor sites, but then I checked the Rockauto site out of idle curiosity. Sure enough they list a wiper arm and blade for my truck. The arm is an Anco 41-01 and it is supposed to fit most vehicles in the 30’s to 50’s timeframe. The arm comes with adapters to fit common wiper posts (or whatever you call the spots where the arms go on). My kit had an adapter, but it was too tight to fit by about 10 thousands of an inch. My wiper posts were exactly 0.25 inch, and I didn’t want to risk overdoing it by just running a ¼ inch drill bit through the adapter. To remove the small amount needed I simply rolled up some 220 grit sandpaper into a tube shape, stuck it into my drill and ran it through the adapter. It only took a minute or two, and I was able to sand away just enough that I had a nice tight fit. Here is the Custom Inner Bore Enlargement Tool (patent pending):
And here is the adapter, pressed onto the wiper post and secured with 2 tiny set screws:
The arm could now be pressed onto the wiper assembly, and it was time to tackle the next problem. Vacuum motors have a kind of silly charm to them, and I have a pair that work, however I am fully aware of their limitations. One thing I had read about before ordering the Anco conversion arms was the fact that the spring in these arms is hellishly strong. This makes for great wiper to glass contact, but it easily overpowers the ability of vacuum wipers to actually be able to move the blades back and forth.
I tested my wiper arm and I realized right away that it was way too strong for my vacuum wipers. I read a few posts where people looked for softer springs or tried different techniques to change the strength of the springs, and as I was fooling around with the unit I had a flashback to physics class and I remembered Hooke’s Law which states “more stretch equals more force” (or something like that). Deductive reasoning led me to the idea that “less stretch equals less force”, so I grabbed a piece of galvanized page fence wire (strong stuff) and I made a little link that would result in less stretch of the spring. Here’s a shot of the Anco arm as it came:
And here’s a shot with the little link installed. The difference in down-pressure of the arm is night and day, and if I need more or less force I just have to bend up a new link that's either a tad longer or shorter. It takes only seconds to do and hopefully will allow me to individually adjust each side to the strength of each side’s vacuum wiper.
I won’t be able to do anything further until I have the windshield glass installed and the engine running to provide vacuum, but for now it is looking promising.
I had the assistance of my son Brian (we have done a couple of builds together), so I enlisted him to help me disassemble the doors. The doors were in wonderful condition (straight and no rot whatsoever), however they did have some issues. First, I would like to show you my favourite farmer-fix of all time:
Yup, you are seeing that correctly. At some point the door latch mechanism failed, so a household door knob and latch was installed. If I didn’t have to go through a safety check I would be inclined to leave it alone, as I think it's the most charming feature of the truck!
Unfortunately I do have to replace it, and that’s gonna be fun. Those door latch mechanisms are only sold in pairs, they are horribly expensive, and they are currently out of stock at every vendor on earth (I checked). I may go for a set of bear claw latches which are safer and far cheaper (and are actually available). In the meantime I have tons of stuff to do. The windows in the doors had been cranked down to the fully open position, and the regulators were stuck. We managed to get the doors fully disassembled and found some pleasant surprises. First was the glass: I had budgeted for new glass as my windshield glass was yellow and delaminated. The door glass however appears to have been replaced at some point as it was in mint condition in both doors, not even scratched.
The next pleasant surprise was the regulators. A quick check showed that nothing was broken and all the gears were in alignment. The regulators had simply sat too long, and rust had built up and old grease had hardened. A thorough cleaning with hot soapy water, some wire brushing, a few spritzes of brake cleaner into some hidden crevices and some gentle back and forth turning of the cranks got things moving nicely. Once the gears were given a coat of lithium grease and the bushings were oiled, both regulators could be turned effortlessly. Before and after:
The doors were then set aside and I got to work on a tail light bracket. The Fargo came with a single taillight and licence plate bracket, so a 2nd one was needed for the passenger side. They certainly weren’t stingy with metal back in the 40’s, as the original bracket was massive. Recreating the exact shape would be a pain as it tapers down from a thick base, however the licence plate covers most of it from view so I was able to cheat a bit. Here’s the original driver side bracket for light & licence plate:
I found some heavy rod and fabbed a new bracket using the old “slice & dice” method. This rod was heavy enough that I was able to get reasonably close to the size of the original bracket. After bending it to shape and welding up the slices I had a reasonable facsimile of the real thing.
I then added the plate that mounts the light (no idea what the original is like so I just eyeballed the driver side and used that as a guide). I bolted the light plate to the bracket and then got fancy with my welder and grinder, turning the little nuts and bolts into fake rivets to mimic the driver side. It was of course bright and shiny (we can’t have that!) so I stuck it in a plastic sandwich bag, immersed in vinegar, hydrogen peroxide and salt. Here’s the old and the new:
And here they sit with the bright and shiny new taillights that just got delivered:
More to follow!
Old 03-12-2021, 09:16 PM   #90
edgeleycanuck
Pretty sure that bracket was likely for a tow bar....
edgeleycanuck is offline   Reply With Quote
Old 03-12-2021, 09:36 PM   #91
6DoF
6DoF's Avatar
radiator hoses drive me nutz, i like the execution.
Old 03-13-2021, 12:41 AM   #92
G&R's57GMC
G&R's57GMC's Avatar
Yep that bracket is for a tow bar . Probably got the truck home at some point in its life .
BTW there is a gas cap for the S10 that allows you to fill without having to remove the cap . It has a spring loaded trap door the you put the nozzle through , it even works with the vapor recovery nozzles. Do a search for 96 S 10 push through gas cap , I found a Tanks Inc cap at Summit Racing for $ 21.95
I put one on my Caprice it made filling a breeze with the license plate tipped part way open , no more screwing around in the tight space .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 03-15-2021, 10:11 AM   #93
Tempest67
Tempest67's Avatar
Great work.
Fabbing that passenger side light bracket was great, just think how many people will see that and have no idea what was involved to do that.
As always, great work with great pics and explanations, Thanks for sharing.
Old 03-26-2021, 06:29 PM   #94
Father&son56project
Thanks guys, and G&R’s57GMC: Thanks for the tip about those caps, but I am OK here. The photo makes the filler tube look kinda hidden, but in fact I have all the room in the world to take the cap off and place a fuel nozzle in.
The air filter was giving me fits due to the tapered front end of the truck. Space was at a serious premium, and it took a while before I found something that would fit. Thankfully both K&N and Spectre have very good dimensional lookups on their sites which made things a lot easier. I was still having trouble getting the best fit due to the weird size of the S10 MAF inlet (3 ¼ inch), but I found a posting that said to just get a 3 inch filter and hit it with a die grinder (thanks Joedoh!). I found a stubby cone filter (Spectre Model 8168) that fit nicely into the corner where the hood, inner fenders and rad meet. I also noted that these filters are called “racing filters”. As a youth I constantly read magazines like Hotrod and Carcraft, so I just know that filter is good for an extra 25 horsepower at the rear wheels (geez the crap I used to believe!!!!!!). Anyhow, that filter is interesting as it also has an interior cone to provide additional filter surface area (likely to make up for its small overall size):
It also fits 3, 3 ½ and 4 inch inlets by the use of adaptor rings that are included with the filter.
The adaptor rings are rubber, and I discovered that the 3 inch ring can easily be stretched over the 3 ¼ MAF. Then the 3 ½ inch ring can be easily stretched over the 3 inch one. Then the 4 inch ring can easily be stretched over the 3 ½ inch ring. In the end, it all fit without any grinding or fiddling around, just by doing the rings one at a time.
While the new filter assembly did fit, it could not simply be clamped on as it would be rubbing against the inner fender and banging around as I drove, and it also sat exactly where the power steering filler tube was. Some kind of bracket was going to be needed.
The power steering filler tube enters the pump through a grommet, and the top of the tube is held in place by a bracket. This is convenient as you can re-orient the tube by simply unbolting the top bracket, spinning the tube to wherever is convenient, and then fabbing a new bracket.
The air filter and power steering filler tube could share a bracket and I got lucky here. My S10 came with the A/C deleted, so there was a rather convenient mounting pad where the old compressor used to sit. A few hours later I had this:
Everything is firmly held in place with decent clearances to prevent rubbing.
When I had earlier removed the old windshield glass I noticed some rust in the frame. I’m not quite sure how they manufactured this frame, but here is the joint where the upper and lower halves meet:
When I saw the rust inside that weird shape I dreaded tackling that job. However in the end (as usual) I imagined it to be a far nastier job than it actually was. Here’s the lower section of the windshield sitting on my welding table:
My initial concerns with rust centered around the fact that the rust was in a deep channel (the channel where the glass sits), so access would be difficult. I eventually found a way to deal with it. Here’s a shot of the rusty base of the channel, with the lower corner actually rotted through for a distance:
Welding access wasn’t the greatest because the mig nozzle was far too big to fit into the channel:
By playing with the settings, I was able to compensate for the lengthy stick-out of the wire. The metal I was welding to was very thin due to the ravages of the rust, so it was a matter of starting at a thick area, welding a small spot, waiting a couple of seconds for the weld to solidify and cool, then welding another spot that just touched the previous weld spot, then waiting again….it was slow work, but by always touching the previous weld spot I had an area that could take the heat without blowing through.
For grinding down the welds I just used an air cutoff wheel, gently going back and forth in the channel. It fit right down there and worked like a charm (but did require a lot of patience as it was a very slow process):
No, it ain’t the prettiest work, but there is no longer a rusted split in the metal, and given the limited access I was quite happy with it! This corner was the worst spot, as it was missing a lot of metal due to rust:
Again it was just a matter of doing the zap & wait routine, followed by gentle smoothing with the cutoff wheel:
I spent a good 3 hours fixing that lower channel, but it was well worth the time. While in the midst of all these little jobs, I took the time to deliver my driveshaft to a place that does truck repairs to have it shortened. I was a little apprehensive as the driveshaft from my S10 is encased in a weird black tube of some unknown (but very strong) material. The guys at the shop figure it’s some kind of deadener for sound or vibration, and it turns out that underneath it all it’s just an aluminum tube. They shortened it up by 10 inches and balanced it for me as well.
When I went to install the shaft, I found that a little work was needed to get the angles right. Axle shims come in ½ degree increments, and my closest fit was a set of 3 degree shims. When I installed my transmission cross member earlier in the build, I purposely welded it in a tad low (it’s way easier to add a shim than it is to lower a cross member). Being able to play with shims at the transmission mount makes it a snap to match angles. By making a spacer out of 7/16ths aluminum, I was able to get a perfect match of angles (5.3 down at trans, 5.3 up at axle). The driveshaft has a down angle of 6.9 degrees, giving me 1.6 degrees relative to each end, which is smack dab in the middle of the recommended 1 to 3 degree range.
That’s it for now. More to follow!
Old 03-26-2021, 09:02 PM   #95
edgeleycanuck
Excellent work and excellent explanation of your techniques and processes. This is the kind of effort that really helps others with their projects. It is so satisfying when one does tackle a problem and get through it with such good results. These vehicles are such a fun challenge. You're progressing nicely.
Old 03-26-2021, 09:28 PM   #96
olcarguy
What edgeley said ��
Old 03-27-2021, 09:07 AM   #97
8man
Thanks for sharing.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-29-2021, 10:26 AM   #98
Tempest67
Tempest67's Avatar
good work, as always
keep it going, and thanks for sharing
Old 04-03-2021, 12:24 AM   #99
Gregski
Gregski's Avatar
great work
Gregski is offline   Reply With Quote
Old 04-06-2021, 08:21 PM   #100
joedoh
joedoh's Avatar
oh man the windshield.. I did two 41 chevys and the first one, I bought a whole new windshield frame and all, it was like 800 bucks. on the second, I said the og frame wasnt too bad, and spent $500 on new connectors, new center strip, new glass, and THEN spent a week or so welding up the channel. ugh. wasted a week to save $300 and probably didnt save anything. you did a nicer job than I did for sure!
the wrap on your driveshaft is carbon fiber! and they do that because the s10s are so low they can risk dinks on the driveshaft when you run over stuff, which is reeeeallly bad for aluminum and balance both.
crazy good work! keep it up!
