Old 12-05-2020, 06:17 PM   #1626
MAC71Cheyenne
Re: What did you do to your truck today.The 3rd chapter
Not finished but took out the drive shaft and removed the u joints and carrier bearing. Had to special order the replacement parts so be a few days to get it back together. Using Spicer greaseable joints. Carrier bearing was shot and two of the u joints were dry with the needle bearings being dust. Couldn't find the warranty receipt and it's only 50 years old so why not.
MAC71Cheyenne is offline   Reply With Quote
Old 12-05-2020, 07:54 PM   #1627
BigBird05
Originally Posted by pjmoreland View Post
Finished my first restoration of a steering wheel. It is nowhere near perfect, but I think it will look pretty good in my truck. There are definitely things I'd do differently next time, like applying the smallest amount of epoxy possible and doing all epoxy shaping by hand instead of using a pneumatic sander. I found the spots where the spokes meet the hoop to be the most challenging part to shape due to the curves. Where the spokes meet the hub was much easier.
What type or brand of epoxy did you use and where did you get it?
BigBird05 is offline   Reply With Quote
Old 12-05-2020, 10:42 PM   #1628
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Nice wheel and sharp 68.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-05-2020, 10:49 PM   #1629
pjmoreland
pjmoreland's Avatar
I used PC-7 epoxy. Got it from Amazon. I was going to order it from Eastwood along with some other stuff, but they were out of stock on the epoxy.
pjmoreland is offline   Reply With Quote
Old 12-05-2020, 10:52 PM   #1630
pjmoreland
pjmoreland's Avatar
Thank you. Here's a photo of it installed. I had a little Lecarra wheel on there before. I really like the way the original wheel feels when I'm driving. It is also nice to be able to see all of the gauges without having to duck down to see under the wheel.
Old 12-07-2020, 02:50 PM   #1631
BugzC10
BugzC10's Avatar
Finally passed her on to my son. He was thrilled to get it out of my garage into his. He drove her from Green Valley Arizona to Buckeye Arizona with no issues. Thanks to the Forum members who helped me bring her back to life over the years.
Not all is lost....I bought myself replacement, a new 2021 Colorado ZR2.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 12-07-2020, 04:13 PM   #1632
Indyuke
Finally solved my horrible off-idle stumble!
The 2G 2bbl carb in my 68 (307 cu) has always had an off idle stumble. Rebuilding the distributor and the carb didn't do much of anything except make the motor run smoother and accentuate the stumble issue.
I did what any good shade tree mechanic does when they are at loss when hours of internet searching and soliciting opinions from better minds don't turn up anything. Just started throwing parts at it.
A NOS venturi cluster from a chevy Vega, of all things, is what finally solved the issue. I now have quick, snappy throttle response, even on a cold motor. No backfiring into the carb or out the tailpipe. No perceived reduction in power. Motor runs smooth, good vacuum on the gauge. No rich smell in the exhaust.
I'm sure there's a gotcha in there somewhere, but so far the change just blows my mind! The engine now runs nearly as well as a modern fuel injected motor. On a venturi cluster meant for a 4-banger.
Indyuke is offline   Reply With Quote
Old 12-07-2020, 04:53 PM   #1633
zellway
zellway's Avatar
Over the weekend I hooked up my old work truck with some improved gauges.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 12-07-2020, 11:09 PM   #1634
89AKurt
89AKurt's Avatar
All I did was put some Christmas lights on.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 12-11-2020, 02:11 PM   #1635
MAC71Cheyenne
Yesterday was re-install driveshaft with new carrier bearing and u joints, cleaned and painted of course...
Today was install the new speaker for the radio and get the radio back in. Sounds great for am.
Old 12-11-2020, 11:55 PM   #1636
jimijam00
This IS bad ass, man.
jimijam00 is offline   Reply With Quote
Old 12-12-2020, 01:57 AM   #1637
BigBird05
Thanks, I got a trash wheel that I am going to practice on.
Old 12-18-2020, 09:54 PM   #1638
Brocoli Wad
Changed my seat out.
The truck came to me with some shoddily shimmed in ‘93 Silverado seats. Comfy, but didn’t look right (to me). I’ve been looking for a seat and finally saw a ‘69 seat about 1.5 hours drive from me. Fellow wanted $50 for it. Has a duct taped end and it’s red, or used to be. Everything’s there, everything works, the foam is in good condition, springs are all intact. His truck was there, originally bought by his father. He found a nice set of buckets, which is why he ditched this one.
Old seats out, new seat in. Mama and I will run it for a week or so to ensure we want to live with it, then it’s carpet and cover time.
Good thing I got the smaller diameter steering wheel... Not as much belly room with this new seat!
Brocoli Wad is offline   Reply With Quote
Old 12-19-2020, 10:35 AM   #1639
Boog
laying low
Boog's Avatar
turn
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-19-2020, 06:02 PM   #1640
Chevys4life
Your are looking like a Christmas Tree!!!!
Chevys4life is offline   Reply With Quote
Old 12-19-2020, 06:16 PM   #1641
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
Added a couple of GM Chicklet emblems to the Ramp truck and worked on the 71 C-10 mirror mount for the late model mirror.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-19-2020, 09:23 PM   #1642
Brocoli Wad
turn
Can you point me to the instructions for rotating pix? I searched and read but couldn’t find the info.
Old 12-20-2020, 03:39 AM   #1643
pjmoreland
pjmoreland's Avatar
Pulled a 700R4 from a 93 5.0 Caprice at the local Pick-n-Pull today. Picked up a mechanical speedo while I was there. Was not fun lifting it into the back of the car by myself. Thankfully, my daughter was able to help me lift it back out at home. Will be rebuilding it over the next month or two while my truck is at the body shop getting some old damage repaired.
Old 12-20-2020, 11:04 PM   #1644
rechinca
rechinca's Avatar
Finished wiring for aftermarket tach, finished installing radio and replacement speaker for the factory AM (turnswitch.com for the correct ohm speaker), installed PS pump and primed/bled the system, and took a run over to Fremont, CA and met with Bill at Vintage Chevy Trucks for a fan shroud. Ended up with correct bumper brackets, decent outer grill shell and center bracket/hood release along with the shroud. Should be able to have the radiator and support installed and the cooling system filled. Maybe break the motor in on Tuesday or Wednesday finally!!
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-01-2021, 12:56 AM   #1645
allchevy58
allchevy58's Avatar
My friend said it's about ready for paint. Bed ready, cab should be ready tomorrow. Helping him again tomorrow.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 01-01-2021, 01:10 AM   #1646
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Great!! I'm waiting for pics.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-01-2021, 09:58 AM   #1647
MAC71Cheyenne
Changed the lube in the rear end, cleaned and painted the cover...installed the refreshed jack hold down hardware, and did some final sanding on the '67 steering wheel.
...and got the look from the wife for spending the day in the garage!
Old 01-01-2021, 04:44 PM   #1648
MAC71Cheyenne
Working on PJM's look. Haven't swapped it out yet but reconstruction is done.
Old 01-01-2021, 04:45 PM   #1649
pjmoreland
pjmoreland's Avatar
Looks great!
Old 01-01-2021, 06:50 PM   #1650
Andy4639
Old member
Andy4639's Avatar
Did you have to redo any of the handle area. I have a 67 stock wheel I cut down but haven't finished it yet. I'm not sure what to use on doing the handle area that is gone.
