Old 12-09-2020, 11:36 PM   #1426
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 53 Surburban "Family Truckster"
That's nice these are adjustable. That changes my mind a bit.
Ryan
1969 Chevy milk truck
Old 12-10-2020, 09:12 AM   #1427
youngrodder
youngrodder's Avatar
Since my contact where installed I went ahead and installed my 1950 Pontiac LED tail lights. I have 99% of the wires ran to the back. I think I just have license plate light wiring and a rear door jam switch left. I'm trying to concentrate on sections of the wiring. I find it easier to keep it organized.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-15-2020, 12:29 AM   #1428
lower50's
lower50's's Avatar
That looks really cool! That's a good way to do the wiring, less chance of missing something.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-15-2020, 06:11 AM   #1429
Dieselwrencher
Those look really nice and period correct too. Very cool!
Ryan
Old 12-21-2020, 10:15 AM   #1430
youngrodder
One of the final fab items I needed to figure out was creating a cover on the rear suspension notch for the Watts link. When the Suburban is fully laid out the top of the Watts link extends up higher that the notch cover. I was always aware of this but in an effort to keep the size of the notch cover as small as possible I figure it would be best to make a cover that provides enough room to cover the watts link.
I plan to body work and paint this cover the interior color. That way I can cover the rest of the notch with carpet and the bolt on this cover.
Keep in mind that this cover will be covered by the third row seat once in place. The only time it will be seen is when I don't run a third row seat.
The first step was to make a template to figure out where the watts link comes thru the floor at and to help determine the size. I made a template as it was easier than installing the large notch cover.
I think you can figure out the rest of the steps from the pics. I was pleases with how it turned out. Keep in mind this cover is only needed when fully aired out. it is not needed at normal ride height.
Marc
Old 12-21-2020, 10:17 AM   #1431
youngrodder
More pics
Happy Holidays!!
Old 12-21-2020, 10:19 AM   #1432
8man
Very nice work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 12-21-2020, 10:41 AM   #1433
Tempest67
Tempest67's Avatar
you metal work guys amaze me.
well done, looks great
Tempest67 is offline   Reply With Quote
Old 12-21-2020, 11:23 AM   #1434
youngrodder
Originally Posted by 8man View Post
Very nice work.
Thank you, but don't confuse me with one of the metal magicians on this site. I'm not one of those. I did this with only a grinder with a cutoff wheel, straight edge, a welder and the flap disc on a grinder. No metal brake. I scored the folds with a cut off wheel and hand formed in vice. I did massage it with a hammer and dollar. The key is making a paper template.
Marc
Old 12-21-2020, 06:54 PM   #1435
Tempest67
Tempest67's Avatar
from what I see, I consider you one of those 'Metal Magicians' (this site has several)
You have all inspired me to try and make a rear roll pan this winter. It is low and behind the bumper, so if I mess it up, it wont be too noticeable, I hope.
also thinking about a metal piece below the dash to hold the radio
Great work, and thank you for the inspiration
Old 12-21-2020, 08:41 PM   #1436
oldman3
oldman3's Avatar
Marc, nice job on the cover...Jim
oldman3 is offline   Reply With Quote
Old 12-21-2020, 09:01 PM   #1437
lower50's
lower50's's Avatar
I can't figure out where the cover will be compared to the 3rd seat but maybe you could put some cup holders in it, if it works out?
1951 MG TD
Old 12-22-2020, 08:54 AM   #1438
mongocanfly
mongocanfly's Avatar
That turned out great Marc..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-22-2020, 08:58 AM   #1439
youngrodder
Thank you for following along. I will be also making a lower dash to house my AC vents, controls as well as my wiper and light switches. I did that on my last build. That is also why I cut my dash flat across the bottom. For the lower dash, I'm going to enlist the help of one of my fabricator friends as he has better tooling. Mock it up in cardboard fist. That's what I did (covered in a post several pages above). The you can lay it flap and see all of the necessary bends and cuts. Then fold up the metal and weld it up. This applies to anything you are trying to build out of metal.
Thank you Jim
Old 12-22-2020, 09:06 AM   #1440
youngrodder
Here this will help you visualize (pic is before I painted it black). No real room for cup holders as the subfloor structure runs under this notch cover. The small cover runs on the back side of this notch cover. The seat will run over the top of it. This is the only time it will be seen when I don't have a third row in.
Thanks man, I stated body working it last night. I have a handful of parts I need to get painted. This being one of them. The idea is to do them all at the same time.
Marc
Old 12-22-2020, 10:11 AM   #1441
Dieselwrencher
That's looking very nice. Going low sure has it's disadvantages but they look so cool down there.
Ryan
Old 12-22-2020, 10:45 AM   #1442
youngrodder
Thanks Ryan...Going up also has its disadvantages and modifications that are needed. Its just part of the deal.
Marc
Old 12-28-2020, 04:13 AM   #1443
ajgriffin
ajgriffin's Avatar
Hey Marc, did you ever try to fire up the engine again? If so, how did it go?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 12-28-2020, 09:21 AM   #1444
youngrodder
I did and the results were so, so. I decided to move onto other things. I think I contaminated my fuel source by not adequately flushing out the tank sfter several years of fab work. I ended up removing the tank and power washing it out, drying and reinstalling. I also got a new fuel pump and regulator and swapped those out as I didn't trust that they didn't have crud in them. I also blew out my lines. It did run (just not real great) prior to figuring out the fuel issue. I just decided not to add more fresh gas until closer to driving it...
Marc
Old 12-29-2020, 10:00 AM   #1445
youngrodder
I worked on a few odds and end projects. I plan to run LED headlight bulbs and since they extend farther out of the back of the light I modified my stock headlight buckets.
I cut in a hole and then I will epoxy in the rubber boot to cove the hole and to allow for a wire pass thru.
On my 48 truck, the headlights and and poor adjustability (due to the frenched headlight kit) made night time driving a challenge. I set out to correct this on my Suburban. These LED lights should fit the bill..
Thank you
Marc
Old 12-29-2020, 10:03 AM   #1446
8man
I'd like to see the finished product. It looks good so far.
8man-aka Robert
Old 12-29-2020, 10:08 AM   #1447
youngrodder
I also installed my side view mirrors. One of the mirror arms came with the Suburban when I bought it. The other I had to add. I tried to age/distress the new arm to match with the original arm. I was pretty happy that it is not supper obvious which is the new arm.
I also treated the mirror heads to a brushed finish to match the rest of the trim on the Suburban.
Marc
Old 12-29-2020, 05:26 PM   #1448
layinrocker65
layinrocker65's Avatar
Which arm is the new one?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 12-29-2020, 08:50 PM   #1449
youngrodder
Passenger side, or 3rd and 4th pics..
Marc
Old 12-30-2020, 11:27 AM   #1450
layinrocker65
Marc
That's how you know its a good job lol
‘53 GMC COE stock
