Old 12-27-2020, 11:36 PM   #476
53Sparky
53Sparky's Avatar
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
There are other ways to affect the way a bass reflex enclosure is tuned that is not directly related to volume. By varying the amount of polyfill that you use within the box, you can simulate a larger enclosure and achieve performance results that match a larger box with less fill.
In other words, while there is absolutely a precision level of science to all of this, which SkinnyG has so proficiently demonstrated, you also have some wiggle room with the size of your enclosure which complements the science with duct tape and bandaids.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 12-28-2020, 12:22 AM   #477
88Stanger
88Stanger's Avatar
I do plan on installing poly fill. Thanks for the comments.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-28-2020, 12:25 AM   #478
88Stanger
88Stanger's Avatar
Here is the box so far
Old 12-28-2020, 03:12 PM   #479
88Stanger
88Stanger's Avatar
So after the great advice from SkinnyG, i redid a few of the dimensions, of course after cutting the front piece and now i need a complete new sheet, but live and learn. After all calculations are in, the box ended at free air (not including the vent) of 1.18 cubic Ft. Then taking the vent at .11 cubic ft from the i ended up with 1.07 cubic ft of air space per sub. I will be adding poly fill also to increase the "air Space" a small amount, but overall i am happy with it.
Old 12-28-2020, 05:18 PM   #480
SkinnyG
SkinnyG's Avatar
Very cool. I have a similar slot port box in my '77 with a single 12".
There is talk that a "slot" port like that will act a little lower than a regular port in an "open" box, as the "walls" the port uses extend the tuning frequency lower than the actual "port wall" itself is cut to. I think you add half the port height/width to the tune length, but I've forgotten exactly.
However,
It's going to thump awesome. It'll work.
I'd stuff some poly fill in there regardless.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 12-28-2020, 07:28 PM   #481
88Stanger
88Stanger's Avatar
However,
Thank you sir, i plan to stuff some poly in it for sure. Just now we are waiting on the subs... hard to get...
Old 01-03-2021, 12:28 PM   #482
88Stanger
88Stanger's Avatar
However,
So I just wanted to give you a big shout out! since talking with you and then i increased the box size, I got a message back from JL Audio. The developer for their boxes emailed me back with what he thought about my dimensions for the entire box including the port. He said that the tuning frequency of the box will be right around 33.15 HZ and the response curve and port velocity should be great. So again, Thanks for your responses especially. I appreciate all the others too, but you really got me back into paying very close attention to dimensions.
Old 01-03-2021, 04:21 PM   #483
SkinnyG
SkinnyG's Avatar
(big.grin)
Old 01-04-2021, 12:23 AM   #484
88Stanger
88Stanger's Avatar
Used a jig to get holes cut.
Old 01-04-2021, 12:24 AM   #485
88Stanger
88Stanger's Avatar
Part done
Old 01-04-2021, 12:25 AM   #486
88Stanger
88Stanger's Avatar
Done
Old 01-04-2021, 12:26 AM   #487
88Stanger
88Stanger's Avatar
Painted
Old 01-04-2021, 12:28 AM   #488
88Stanger
88Stanger's Avatar
Speaker wire connectors
Old 01-04-2021, 12:29 AM   #489
88Stanger
88Stanger's Avatar
Box set into its place, plenty of room, suggestions how to secure it there?
Old 01-04-2021, 12:30 AM   #490
88Stanger
88Stanger's Avatar
2nd pic
Old 01-04-2021, 01:42 AM   #491
SkinnyG
SkinnyG's Avatar
OEM-looking gas tank straps would be cool.
Old 01-04-2021, 10:51 AM   #492
88Stanger
88Stanger's Avatar
hmm.. Interesting thought there, i must look into this.
Old 01-04-2021, 02:56 PM   #493
jlsanborn
jlsanborn's Avatar
Very cool build! Looking forward to catching up on this one.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-04-2021, 04:29 PM   #494
88Stanger
88Stanger's Avatar
Thank you. It has been and continues to be an adventure... lol
Old 01-04-2021, 09:13 PM   #495
88Stanger
88Stanger's Avatar
Ok everyone, i am looking for suggestions for Aluminum Radiator with Electric Fan/Shroud. Please give input. I find them from stock looking replacements to really wide ones. not sure what is best, easy, yada yada... 3 - Row, 4 - Row, 1 large fan, 2 smaller fans.... damn help someone please..
Old 01-04-2021, 09:48 PM   #496
88Stanger
88Stanger's Avatar
I am currently looking at a 4-row with electric fan and shroud by Alloyworks.
Old 01-04-2021, 10:04 PM   #497
88Stanger
88Stanger's Avatar
Well now looking at reviews.... maybe we do Cold Case radiator?
Old 01-04-2021, 10:59 PM   #498
roll_the_dice
roll_the_dice's Avatar
I used RND fabrication...made in the US and are a sponsor. I use a Derale electric fans...2000 CFM...one for cooling one when the A/C kicks on. I think one fan would have been enough...but 2 is more better right? LOL
roll_the_dice is offline   Reply With Quote
Old 01-05-2021, 10:38 AM   #499
88Stanger
88Stanger's Avatar
Sorry for my confusion, but when you say sponsor, you mean a sponsor here on the site? Did you buy the rad. with fans or without?
Old 01-05-2021, 11:11 AM   #500
roll_the_dice
Yes, sorry for the confusion...site sponsor. I bought it with a single fan, but I took my truck to have my A/C finished/charged and they said they recommended a second fan dedicated for the compressor. So I put a new shroud and fan on the radiator (Derale). In hindsight, I don't think I needed it. So now I have an extra fan...ugh! This was before the new fan/shroud with single fan. I don't have a picture yet of the new fans.
