06-02-2020, 11:09 PM | #1 |
Tailgate handle bolts
Does anyone know what years used Phillips heads vs. bolt heads for the tailgate handle? These are on the inside of the gate. What size are the threads and how long are they?
1967 Chevrolet 1/2 ton 4x4 1972 GMC 1/2 ton 4x4 2005 1500 4x4 Suburban 2004 GMC Envoy 4x4 (wife's) |
06-03-2020, 05:20 PM | #2 |
Re: Tailgate handle bolts
pop one out and measure it. You may need an impact driver to remove them. I would replace with stainless steel, no rust
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-03-2020, 10:34 PM | #3 |
06-03-2020, 10:42 PM | #4 |
The problem is I bought a gate with no hardware so I ordered a new handle, rods and latches but it the kit does not include bolts. The attached photo is just an example I was using to refer to. Sorry for the confusion. Thanks.
06-04-2020, 11:08 AM | #5 |
I did the same, bought a new tailgate with new hardware and no screws. Had to reuse mine which are rusty. Need to change them out. Later today I'll pull one of mine and let you know.
06-04-2020, 01:27 PM | #6 |
I believe they are 5/16-18 by 1/2" long. Someone double check this for me. If you use stainless steel...use anti-seize. The affordable grades of SS hardware galls easily and could cause your handle mechanism to be rather permanent. I used SS button heads with SS rubber bonded washers...turned out nice.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
06-04-2020, 03:54 PM | #7 |
Off the top of my head they are 5/16"-18 X 1" but for length I could be wrong and they may only be 3/4" length instead of 1".
Paul Jr @ GMCPauls |
06-04-2020, 06:27 PM | #8 |
Just checked mine, original 5/16 18 thread and the thread length is 3/4". Only unique thing about the screw is it is a fairly large shallow round head called a truss head. (yes I looked it up!)
06-04-2020, 06:47 PM | #9 |
Thanks everyone.
06-08-2020, 06:52 PM | #10 |
Is it just me or are these aftermarket handles cheaply built? I bought one, it came damaged and bent. It was really flimsy where it hinges. Called the company and they sent another one but I'm not even going to take it out of the plastic because I can tell it's as flimsy as the first one. Any suggestions on where to get a good one? I found a really nice OEM gate but someone took the handle and hardware before me.
06-08-2020, 06:58 PM | #11 |
06-10-2020, 09:33 PM | #12 |
Alright, what an I doing wrong? I bought a factory gate with no hardware. So I purchased a new handle assembly. It did not fit. When bolted in, the handle hits the gate. Took it apart and it looks bent. Box was beat up, maybe damage from shipping. Called the company and they sent a replacement. I could tell it looked the same but tried it anyway. Same thing. Hits on the handle opening. It will not lift up. An I just dealing with cheap aftermarket parts? Or am I missing something simple? I have no original to go off. It hits where I'm pointing in the pics.
06-10-2020, 09:40 PM | #13 | |
06-10-2020, 09:53 PM | #14 |
06-10-2020, 09:55 PM | #15 |
06-11-2020, 02:03 AM | #16 |
Besides posting here I also just replied to 1 of your emails to the office. We shipped you both tailgate handles and I myself checked that there were no issues with the 2nd handle before sending it. They work correctly in both OEM and reproduction tailgates and the looking at your photo of outside of tailgate shows the tailgate handle opening to be bent in several locations. In regards to flimsy the tailgate reproduction handle is just as heavily made as the original's. The issue is your OEM tailgate is damaged around the handle opening.
06-11-2020, 12:17 PM | #17 | |
This thread got me thinking, my handle may be bent, though I don't see it. It's too close the molding when I open it, IMO. The handle on my other sits further back and clears easily, but it's bent for sure. Does anyone have a close-up for a properly positioned handle, and can you describe the clearance when you open it?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-13-2020 at 03:49 PM. Reason: Clarification |
06-11-2020, 09:11 PM | #18 |
I should have taken a photo of my friends truck. His is original gate and handle and it clears nicely. If guess about 1/4 inch between top edge of handle and gate. I'm on the hunt for an OEM handle locally.
06-11-2020, 09:49 PM | #19 |
I think if you elongated the holes a bit you can lower the handle
To give you the needed gap Many repop parts need a bit of finish alignment https://m.youtube.com/watch?v=VeRC7TmolnM |
06-11-2020, 10:02 PM | #20 |
I thought about that but the holes have a raised edge inside the gate, plus that could result in a loose handle situation down the road if those bolts have any movement in the hole.
01-18-2021, 07:08 PM | #21 |
Does anyone know if there is a difference in the tailgate latch/handle assembly between a pickup and blazer?
