07-05-2020, 01:36 AM | #1 |
Positive Cab Ventilation
A while ago while in the junkyard, I noticed that more modern pickups have oval shaped air check valves in the back of the cab below the bedline. Apparently, they have some kind of a flapper door to let the incoming air from the ventilation system escape thru a grated cover.
Has anyone ever tried installing these on their classic truck? It seems it would go a long way to improve the air flow of the heater and kick panel vents and I surmise it would reduce the wind noise when cruising with the windows up and vents open. |
07-05-2020, 07:42 AM | #2 |
Moderator
Re: Positive Cab Ventilation
Yes about halfway down the page "Rear Cab Air Vents" - https://talk.classicparts.com/thread...p.13928/page-2
07-05-2020, 09:57 AM | #3 |
Moderator
Vents like that are the reason that vent windows disappeared.
07-05-2020, 10:47 AM | #4 |
Who Changed This?
I remember the ads from Chevrolet when "Flow-Thru Ventilation" was introduced. The guy talking showed how cigarette smoke was cleared from the car by that flow.
07-05-2020, 03:56 PM | #5 |
Did Chevy begin doing that on the squarebodies?
07-05-2020, 04:55 PM | #6 |
Who Changed This?
I don't know about the trucks, but the cars got them in '71.
https://www.autoweek.com/car-life/cl...vrolet-impala/
07-05-2020, 11:57 PM | #7 |
My mom had a Grand Am and saw something like what you describe near the frame of rear driver's side door.
On that car I figured it was to let the air push out when shutting door, with window rolled up. Could this thing you describe be to displace air of a closing door? |
07-06-2020, 12:27 AM | #8 |
The squarebody vents out the bottoms of the doors.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-06-2020, 01:21 PM | #9 |
I used to follow LakeRoadster's build years ago and considered doing the same thing after removing my bed and redoing the wood. I think I ran out of time and never did look at it again. I still have the rear cab vents I removed from a couple of different model trucks.
07-13-2020, 05:24 PM | #10 |
I have thought of doing something like that so that I could close my doors more easily. My doors shut great with the windows down but not as easily will them shut
01-20-2021, 01:05 PM | #11 |
I also noticed when I shut my doors I notice that the roof shakes a lot. I wonder it that is because of the air not having anywhere to go.
01-20-2021, 01:14 PM | #12 |
Moderator
That could very well be if your cab is sealed up well.
01-20-2021, 01:33 PM | #13 |
I've always been in the habit of opening the door, roll down window a few cranks, enter cab, close door. Depending on the season, roll all the way up, or down.
01-20-2021, 01:55 PM | #14 |
Moderator
What about when you leave?
01-20-2021, 02:09 PM | #15 |
01-20-2021, 02:34 PM | #16 |
01-20-2021, 04:56 PM | #17 |
The guy that installed my weather stripping on recommended that I leave the section out that runs along the bottom of the door. I wonder if that will help. But then I wonder what problems will run into if I do. Especially wind noise. The only reason I am so concerned is because I keep on having problems with the bondo in the roof cracking.
01-22-2021, 10:20 AM | #18 |
I did this years ago to get the doors to close like a modern vehicle. See this post in my build thread: https://67-72chevytrucks.com/vboard/...&postcount=645
01-22-2021, 12:47 PM | #19 | |
I don't think it would work to put them in the door jams sense the gasket is on the inside of the jamb. |
01-22-2021, 12:50 PM | #20 | |
I didn't go that route, as that is where my speakers are hidden. |
01-22-2021, 12:54 PM | #21 |
Got it. I was thinking of it backwards. So that the air would be pushed inside the cab.
01-23-2021, 02:18 PM | #22 |
I think I need to install something like this or else the bondo in my roof will continue cracking. I can see the roof shake every time I shut the door with the windows up
