Old 01-21-2021, 12:13 AM   #1701
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: What did you do to your truck today.The 3rd chapter
well, spent most of the day and night troubling shooting a gremlin that appears to be up in my column for the right turn signal. When the brake was applied and I engaged the right turn signal - Poof goes the fuse that powers the brake lights (and others)... i think I have it "fixed" that will likely not hold.
So if you see a fellow in Texas turning on his dome light in the middle of the day after a right turns, that will be me seeing if I still have brake lights!
...seeing how my luck is going, I bet my fuel line will start leaking again tomorrow (music "They're Coming to Take Me Away, Ha-Haaa!" cues up)
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-22-2021, 03:31 AM   #1702
pjmoreland
pjmoreland's Avatar
Assembled my new seat.
pjmoreland is offline   Reply With Quote
Old 01-22-2021, 10:38 PM   #1703
Peanut74
Worked on the wiring for my truck today. Concentrated on the engine section today. Spent half a day trying to figure out what power wires went where. The PO did give me the Painless Wiring Manual but one of the power wires wasn't listed. FINALLY figured it out. Turns out he neglected to tell me that he also purchased a supplemental wire harness for the high output alternator.
SO, the plan for tomorrow is to get the last of the power leads connected and the fuse box mounted.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 01-23-2021, 10:41 AM   #1704
72c20customcamper
72c20customcamper's Avatar
Nice work . Is the frame new aftermarket?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-23-2021, 11:12 AM   #1705
landarts
landarts
Here is a 71 K20 I am working getting the body back in shape and into some color. Now moving onto the fenders, hood and doors.
Pict 1- this after I got it home and started sanding down areas and getting it ready to do some body work
Pict 2 - is doing body work on back of cab including pulling out several dents and dings with stud gun and replace both cab corner lower sections
Pict 3 - had to remove top roof skin and replace with a donor part. Treated metal and installed new insulation to replace tar paper
Pict 4 - just finishing the spot welding up on roof repair
Pict 5 - this after the finishing the cab body work and spraying 3 coats of single stage.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-23-2021, 12:10 PM   #1706
pjmoreland
pjmoreland's Avatar
The frame is an original 67/68 folding style, but the foam and upholstery are new. It replaced a 69/70 style that was in my truck.
Old 01-24-2021, 07:02 PM   #1707
BC10
BC10's Avatar
New mufflers installed
BC10 is offline   Reply With Quote
Old 01-24-2021, 08:47 PM   #1708
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
The seat is gorgeous!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-24-2021, 08:48 PM   #1709
Ol Blue K20
It's gonna have a nice rumble...
Dale
Old 01-24-2021, 08:52 PM   #1710
pjmoreland
pjmoreland's Avatar
Thanks! It's one of the very rare things that actually turned out the way I planned
Old 01-24-2021, 09:19 PM   #1711
Ol Blue K20
It's always nice when something works out. Especiallywhen it looks so nice!
Dale
Old 01-24-2021, 09:23 PM   #1712
Greasey Harley
Greasey Harley's Avatar
Snow comin' in the morning, but the roads were clear today. I took this opportunity to burn some gas in the country side. Just drove around for like 3 hours. topped off the gas, added some sta-bil and disconnected the battery. The truck is tucked safely back in the shop for it's long winter's nap.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 01-24-2021, 11:46 PM   #1713
Quikshft
Quikshft's Avatar
Today I finished up a project to re-gear my 71 4x4 from 3.07 to 4.10. Did the rear earlier this year, but just now finished the front end. Had a posi carrier in the rear so added one to the Dana 44 so perhaps even improved its off-road capability some. Added some stainless cap screws to the stock diff covers, kind of like the look.
Quikshft is offline   Reply With Quote
Old 01-25-2021, 02:11 AM   #1714
lil hoodlum
lil hoodlum's Avatar
I had to replace my ignition module today. My old one really wasn't old but was the Accel brand made in China. As I was driving the motor would cut out for a few seconds then come back on as normal. New ignition module is the Standard Brand and the best part it is made in the USA.
Now if I can figure out how to rebuild my quadrajet that has been giving me issues, I should be golden.
lil hoodlum is offline   Reply With Quote
Old 01-27-2021, 01:17 AM   #1715
v8truckin
Added some floor mats 🥱
v8truckin is offline   Reply With Quote
Old 01-27-2021, 02:20 PM   #1716
fb111ewo
fb111ewo's Avatar
Installed rear bumper and completed wiring installation. Used AAW classic update kit. So far, issues I had with wiring:
1. Driver's front park lamp not working. Solution: Connector came unplugged. Plugged in and now working.
2. Emergency flashers not working. Solution: Called AAW and they informed me that second flasher had to be plugged in on upper left area of fuse block. Didn't see that in assembly instructions. Plugged in second flasher and issue is resolved.
3. Tail lights/Brake Lights not working. Solution: Tail light assemblies get ground from the bolts where they attach to the bracket. Due to new paint, was not getting a good ground. Made grounding wires to run from assembly bolt down to frame. Tail lights/Brake lights now working.
Also, decided to install side marker lights, even though 1968 should be just the reflectors. Glad I did this!
Everything else works just fine, with the exception of the Windshield Wipers. probably another grounding issue. Overall very pleased with AAW kit!
fb111ewo is offline   Reply With Quote
Old 01-28-2021, 12:27 AM   #1717
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Finished the 7” drop on the rear and then took the 2” blocks off...
Then decided to add them back after putting the shocks on. Lol
Tomorrow they go back on. The 2.5” rake is too much for me.
This pic is taken after the first attempt with 7” drop.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 01-28-2021, 11:50 AM   #1718
Chevys4life
I like those mats very much. They are really nice!!!
Chevys4life is offline   Reply With Quote
Old 01-28-2021, 11:51 AM   #1719
Chevys4life
Nice stance on that boy!!!
Old 01-30-2021, 11:51 PM   #1720
young grasshoppa
young grasshoppa's Avatar
Finished up a couple things this week. Installed a rear sway bar on my ‘72, and replaced the shocks. Two things I should have done a while back, it rides so much nicer now.
Last edited by young grasshoppa; 01-30-2021 at 11:59 PM. Reason: Upsidedown photos
young grasshoppa is offline   Reply With Quote
Old 01-31-2021, 12:59 AM   #1721
Grumpy old man
Grumpy old man's Avatar
Installed Rams horn heat shields / looms from Classic parts and 76 Corvette Hei wires from Summit .
Old 01-31-2021, 10:50 AM   #1722
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I know you probably haven’t driven the truck much if at all but wondering if you notice any difference in handling/cornering with the rear sway bar installed. I have one waiting to go on my truck so curious to see if any noticeable difference.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-31-2021, 11:25 AM   #1723
west9378
west9378's Avatar
I had a good day cleaning every nook and cranny on this 71 frame. The rear crossmember I thought was interesting. I am going to look but I bet it is part of the serial number.
Have a Blessed day
west9378 is offline   Reply With Quote
Old 01-31-2021, 11:37 AM   #1724
west9378
west9378's Avatar
Getting her ready for a LY6 and 6 speed auto swap. Cleaned every nook and cranny only to find that I needed a wire brush and scraper.
Look at the rear crossmember, this is a first for me to see.
Old 01-31-2021, 12:04 PM   #1725
young grasshoppa
The truck is noticeably different in turns, the back end follows the front end so much better now. I have not pushed it hard yet, but it already feels so much better. I put the front sway bar on about 2 years ago, and that was an improvement, I wish I would have done this one at the same time.
