Old 05-02-2011, 10:32 PM   #51
TR65
TR65's Avatar
Re: 65 Power Steering Conversion
thanks TR65
http://www.performanceonline.com/Cou...Joints-c-1112/
that's the link for what i'm looking at...does it look like that would work?
Looks like that would work (the P/S rag joint and the rag joint coupler)
The Dorman rag joint #31015 is $32 at Amazon with free shipping.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-02-2011, 10:35 PM   #52
jbgroby
jbgroby's Avatar
I called NAPA in my town and the same rag joint is $10.99
jbgroby is offline   Reply With Quote
Old 06-27-2012, 12:08 PM   #53
sdcfish
Amazing! Thanks so much for all the tips, and instructions. I definitely can handle this and look forward to jacking the truck up and getting busy! I am loving my truck! Played with it last night and painted the gauge bezel....looks awesome. I will take pictures as well and try to follow up on the thread in the upcoming weeks. Here's how it looks now and as you can see....I need to get busy cleaning
sdcfish is offline   Reply With Quote
Old 12-11-2015, 12:42 AM   #54
Chuck Milton
Is it necessary to change the idler & pittman arms?
Chuck Milton is offline   Reply With Quote
Old 12-11-2015, 01:31 AM   #55
Captainfab
60-66 Nut
Yes you have to change the pitman arm. The original will not fit a '68 and up power steering box.
The idler arm you do not have to change unless it is worn out. Then you can simply replace it with a direct replacement.
When also converting to disc brakes using stock '71-'87 spindles, I recommend changing the entire steering linkage if possible. This keeps the entire front suspension including the steering the same vintage. This makes remembering what you need for replacement parts, years from now. If you do retain your original steering linkage with disc brakes, you will need the aftermarket aluminum tierod adapters and a couple different tierods.
Old 09-06-2016, 03:39 PM   #56
jeromio
Why does the bracket allow for any misalignment between the shaft and the input for the steering box? For a needle bearing U-joint, I could understand, but not for a rag joint. It should just be a straight shot and the rag joint would only need to compensate for movement of the cab relative to the frame.
jeromio is offline   Reply With Quote
Old 09-06-2016, 11:36 PM   #57
Captainfab
60-66 Nut
My steering box adapter plate aligns the steering column shaft with the steering box input shaft.
Old 01-16-2020, 11:33 AM   #58
88Stanger
88Stanger's Avatar
Thank you all for the info here.
88Stanger is offline   Reply With Quote
Old 01-17-2020, 12:14 PM   #59
cookseyb
Just a note of precaution, I put a 1985 front end on my 64 C-10 and it makes this install much easier, I also am installing a LS2 engine and the PS pump is metric so I was able to use factory hoses for the hook up. The area where the bracket is also prone to the frame cracking, I used dye penetrate in the area around the holes and found several cracks that had to be stop drilled and groved out for welding. Just a precaution but was time well spent for safety. Good job on the pics and instructions.
cookseyb is offline   Reply With Quote
Old 01-17-2020, 01:10 PM   #60
vince1
Nice presentation TR65.
FYI for anyone with a 66 truck, a dbl D shaft from a 67 will fit into a 66 column.
Does a PS conversion need to change the length of shaft to keep the steering wheel at the same distance from the floor?
vince1 is offline   Reply With Quote
Old 01-31-2021, 10:00 PM   #61
ywg396
Has anyone used this kit from Borgeson?
Looks like a nice piece, quick ratio too. The box itself is a bolt in for a square body.
https://www.borgeson.com/xcart/produ...&cat=34&page=1
If you look at the 800132 installation drawing, it has some useful dimensions for the DIY crowd
ywg396 is offline   Reply With Quote
