02-09-2021, 05:19 PM | #1 |
1991 V3500 hubcap ??
This is on the front of my 91 V3500 and I've never saw another
one like it.Any ideas. |
02-09-2021, 05:24 PM | #2 |
Re: 1991 V3500 hubcap ??
Those are from a ford, not GM.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
02-09-2021, 06:16 PM | #3 |
x2. Looks like a F*#d cap.
02-09-2021, 07:20 PM | #4 |
02-10-2021, 12:11 AM | #5 |
The Chevy version of that would have sat closer to the wheel, and would have had six spokes for the 16" wheel. The 1/2 ton Chevy trucks got 15" wheels with five spoke dog dishes.
On a side note, why do folks consider it distasteful to even say the name "Ford"? Reading it, it looks like a bunch of childish grade school spats about which truck is better. Ford, Chevy, and Dodge were all alike more than they were different. I've got favorites in each of those brands over the decades.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-10-2021, 02:18 AM | #6 |
1991 R/V 2500 and 3500 SRW used the same hubcap the C/K 2500 and 3500 did going back to 1978. 3500 series G vans used the same hubcap up until 1995. 1978-up SRW P chassis also used them.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
02-10-2021, 09:37 PM | #7 |
the V2500 is a different front cap V3500 has a bigger hole and shaped different
