02-19-2021, 08:50 PM | #1 |
Did I find the correct front crossmember for my C20 to C10 swap
Hi, I’ve been looking for a complete c10 crossmember here in SoCal for over a year that’s not an arm & a leg. Think I’ve found it.
Unfortunately I was not dressed for greasy dirt, so these are best pics I have of the lower a-arms since I believe those are the issue...hope I got the right pics, Here’s a pic of the left and right where the mount to x-member. Can anyone tell from these pics if I got the correct crossmember identified. FYI, it’s about $180/200 at pick a part since I’m leaving the spindles out behind. I do have an option for a 90 Suburban crossmember, in one piece (discs to disc) for $250 from wrecking yard, bonus is no labor. What do you all think, is this a c10 from an 86? I never trust pick-a-part, there’re a bunch of arrogant a-holes but they’re the only “deal” around here in so cal. Let me know. Pick my part or go for the suburban in one piece for $250. Thanks |
02-19-2021, 08:59 PM | #2 |
Re: Did I find the correct front crossmember for my C20 to C10 swap
Looks like the right one to me since it has the later way of mounting the LCA shafts. If you go with the pull a part one, be cautious with the engine. Once you take the whole crossmember out, that engine might want to come down with it.
Are you leaving the spindles because you already have some?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-19-2021, 09:00 PM | #3 |
If that has disc brakes on it it should be 71- 72....73- 87 had large washers on front and back of control arm rods.
02-19-2021, 09:10 PM | #4 | |
02-19-2021, 09:11 PM | #5 |
02-19-2021, 11:00 PM | #6 |
60-66 Nut
That looks to be a '71-'72 C10 front suspension, assuming it is 5 lug. But nonetheless it will work for converting a C20 to a C10. Be aware that either the lower or upper ball joint is specific to those 2 years only. I don't remember which one since I never deal with those.
02-20-2021, 01:11 PM | #7 | |
Also, I totally missed that you were going 20 to 10. Any crossmember from a 1/2 ton 63-87 truck will work for what you want to do. You'll just need to get the ball joints that match your spindles
02-22-2021, 12:58 AM | #8 | |
02-22-2021, 12:40 PM | #9 | |
What's in those images looks like it has the initial C10 'HD' rubber-lined steel bushing that threads into the a-arm (63-72). 73-87 C10 trucks/Burbs had 'press in' car style bushings. 73-87 C20/C30 had the HD rubber-lined steel bushings that thread into the a-arms like the 63-72 trucks but are 8-lug.
02-26-2021, 11:40 PM | #10 | |
02-27-2021, 02:14 AM | #11 |
I'd use the early HD bushings before the later style C10 press-in fat rubber pieces if it's a 'sport' truck. If it's being built as a driver, the press-in fat rubber style will offer more cushion.
