Old 02-19-2021, 08:50 PM   #1
CousinTone
Did I find the correct front crossmember for my C20 to C10 swap
Hi, I’ve been looking for a complete c10 crossmember here in SoCal for over a year that’s not an arm & a leg. Think I’ve found it.
Unfortunately I was not dressed for greasy dirt, so these are best pics I have of the lower a-arms since I believe those are the issue...hope I got the right pics,
Here’s a pic of the left and right where the mount to x-member. Can anyone tell from these pics if I got the correct crossmember identified. FYI, it’s about $180/200 at pick a part since I’m leaving the spindles out behind. I do have an option for a 90 Suburban crossmember, in one piece (discs to disc) for $250 from wrecking yard, bonus is no labor.
What do you all think, is this a c10 from an 86? I never trust pick-a-part, there’re a bunch of arrogant a-holes but they’re the only “deal” around here in so cal.
Let me know. Pick my part or go for the suburban in one piece for $250. Thanks
CousinTone is offline   Reply With Quote
Old 02-19-2021, 08:59 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Did I find the correct front crossmember for my C20 to C10 swap
Looks like the right one to me since it has the later way of mounting the LCA shafts. If you go with the pull a part one, be cautious with the engine. Once you take the whole crossmember out, that engine might want to come down with it.
Are you leaving the spindles because you already have some?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-19-2021, 09:00 PM   #3
notsolo
notsolo's Avatar
If that has disc brakes on it it should be 71- 72....73- 87 had large washers on front and back of control arm rods.
notsolo is offline   Reply With Quote
Old 02-19-2021, 09:10 PM   #4
CousinTone
Spindles are $60 with core, rotors are $30 with core and calipers are $45 with core. That makes it a laughable price versus the suburban option. What’d you think?
Old 02-19-2021, 09:11 PM   #5
CousinTone
Wasn’t focused on brakes, going to go lowering spindles and stock power discs on all 4. Thoughts?
Old 02-19-2021, 11:00 PM   #6
Captainfab
60-66 Nut
That looks to be a '71-'72 C10 front suspension, assuming it is 5 lug. But nonetheless it will work for converting a C20 to a C10. Be aware that either the lower or upper ball joint is specific to those 2 years only. I don't remember which one since I never deal with those.
Old 02-20-2021, 01:11 PM   #7
cwcarpenter98
Yeah, if you're going with drop spindles anyways, I would leave those behind at that price.
Also, I totally missed that you were going 20 to 10. Any crossmember from a 1/2 ton 63-87 truck will work for what you want to do. You'll just need to get the ball joints that match your spindles
Christian Carpenter
Old 02-22-2021, 12:58 AM   #8
CousinTone
Hey CaptianFab, it’s either a 6 or 8lug, don’t remember......does that eliminate the 71/72 only issue “gone”?. I also try to avoid those single/two year configurations. Thanks.
Old 02-22-2021, 12:40 PM   #9
SCOTI
SCOTI's Avatar
71-87 C10 is 5-lug.
What's in those images looks like it has the initial C10 'HD' rubber-lined steel bushing that threads into the a-arm (63-72).
73-87 C10 trucks/Burbs had 'press in' car style bushings.
73-87 C20/C30 had the HD rubber-lined steel bushings that thread into the a-arms like the 63-72 trucks but are 8-lug.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-26-2021, 11:40 PM   #10
CousinTone
Originally Posted by SCOTI View Post
71-87 C10 is 5-lug.
So, wing Captain Obvious ....stay away from this Thx
Old 02-27-2021, 02:14 AM   #11
SCOTI
SCOTI's Avatar
I'd use the early HD bushings before the later style C10 press-in fat rubber pieces if it's a 'sport' truck. If it's being built as a driver, the press-in fat rubber style will offer more cushion.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
