Old 02-23-2021, 10:23 AM   #1
Popcorn W
Popcorn W's Avatar
Pics of 31's stock ride height
Can I get a picture of a square running 31 tires on 8" rally wheels and stock height? Thanks.
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
Old 02-23-2021, 12:44 PM   #2
Popcorn W
Popcorn W's Avatar
Re: Pics of 31's stock ride height
Oh, forgot.... 4x4
My build thread:
Old 02-23-2021, 05:04 PM   #3
72c20customcamper
72c20customcamper's Avatar
Is 30.6 tall enough? 265/70r16 sorry not on rallies added second picture , snow helps the tire stand out better
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-23-2021, 05:42 PM   #4
Not on ralleys, but same size and BS as ralleys. This is what my 81 had when I picked it up.
Sorry, missed the 4WD part. Mine is 2WD.
Old 02-23-2021, 06:49 PM   #5
Popcorn W
Popcorn W's Avatar
Thanks guys. That helps a lot. I didn't really want to do a lift. I like stock ride. And, I've seen 33's with stock ride which looks to big to me. But, hey each to his own.
BTW, both are good lookin' rides.
My build thread:
Old 02-23-2021, 07:12 PM   #6
kipps
I agree with you on the 33"/stock looking overstuffed.
For k10 and k20 trucks, 31"/stock, 33"/2-inch, 35"/4-inch, etc. A k30 sits higher already, so deduct an inch or two from the required lift.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-23-2021, 08:17 PM   #7
72c20customcamper
I dont think I could go bigger even if I wanted . Truck is a light 20 sits lower than the standard.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-23-2021, 08:20 PM   #8
kipps
I figured all the 4wd 20's had the same ride height, regardless of the spring stiffness. My truck in my signature does fit 33 tires on stock springs. The wide tires are the limiting factor, and do rub at full lock.
Old 02-23-2021, 08:44 PM   #9
72c20customcamper
Been told it rides a little lower than the heavier 20s . Haven't had it next to any other 20s so I'm not sure . Guess it would make a difference with a wider tire than the 265
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-24-2021, 08:29 AM   #10
cadillac_al
I just heard recently that ford made low rider 3/4 ton trucks in the mid 70's; for shorter people I suppose. Maybe Chevy did the same thing to keep those customers
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-24-2021, 11:05 AM   #11
Willowrun
Willowrun's Avatar
K10, no lift, 31’s
Old 02-24-2021, 06:58 PM   #12
Popcorn W
Popcorn W's Avatar
Originally Posted by Willowrun View Post
K10, no lift, 31’s
Perfect. Thanks. Exactly what I was looking for. Thank you
My build thread:
Old 02-24-2021, 11:16 PM   #13
farmall
farmall's Avatar
My K5 in the sig.
I think I am going to go 33-10.5s front and 33-12.5s rear.
I think I will do a soft ride add a leaf in the back as well. I hate the rear sag look.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 02-24-2021, 11:30 PM   #14
allchevy58
allchevy58's Avatar
76' my dad bought new.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 02-25-2021, 07:30 PM   #15
Dead Parrot
Adding this in case others search this up later.
A former military CUCV that later was a fire brush rig sitting on 31s. Basically an 84 K30 uprated to 5/4 ton.
Edit Add: The weight data has peeled off the factory sticker but the metal plate the military had put on lists the GVW at 8800lbs and max payload at 2900lbs.
Last edited by Dead Parrot; 02-26-2021 at 04:18 PM. Reason: Answer questions about capacity
Dead Parrot is offline   Reply With Quote
Old 02-25-2021, 07:56 PM   #16
kipps
Off subject; hope it's permissible...
I know the cucv has a deeper axle ratio than the civilian k30 trucks. Is there anything else that increases its weight rating? Or did the military just arbitrarily decide to rate it as a 1-1/4 ton truck?
Old 02-25-2021, 10:14 PM   #17
farmall
farmall's Avatar
84 K30 civy single cab single wheel was rated to carry 3900lbs.
5300 empty, 9200 GVW.
The Army underrates all their equipment for safety.
They also have an on road and off road GVW for most of their equipment
Old 02-26-2021, 01:23 PM   #18
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
this was on an eight lug k20 no lift they did rub on turns if the truck was pitched but never damaged anything
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-26-2021, 08:34 PM   #19
Popcorn W
Popcorn W's Avatar
You didn't mention what size tires. They look bigger than 31's.
My build thread:
Old 02-27-2021, 09:27 PM   #20
Nick_R_23
Nick_R_23's Avatar
K10, no lift, 31’s
Hard to beat that look!
Old 02-27-2021, 11:06 PM   #21
Mike McD
nice
Mike McD is offline   Reply With Quote
Old 02-28-2021, 12:52 AM   #22
SunSoaked
SunSoaked's Avatar
No lift...so the "stinkbug" look is factory?
SunSoaked is offline   Reply With Quote
