03-01-2021, 04:26 PM | #1 |
Fitment question - C10 rotors on a C20 front end
I have a complete cross smember from a 74 C20, and I was wondering if there is any way to install the 5 or 6 lug C10 rotors on the C20 front end?
The only reason I would want to do this, is if I were to install a 3:08 rear end on my 63 C20. Pretty sure there are no C20 rear ends that are geared that high, so, if I wanted to do this it would require a rear end from a C10 or other vehicle.
1963 C20, small window, long bed 292, 4-speed |
03-01-2021, 08:17 PM | #2 |
Re: Fitment question - C10 rotors on a C20 front end
At that point, you're probably better off going with a c10 front cross member. I don't know of a way to put the c10 rotors on the c20 spindles
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-01-2021, 09:04 PM | #3 | |
Oh well... I guess I will stay with 8 lugs. Now I will need to find a T5 trans!
03-01-2021, 10:59 PM | #4 |
But Found Her 25yrs Later!
A 73-87 c10 complete front crossmember should be found for $50 without much effort.
03-01-2021, 11:12 PM | #5 | |
I would love to find one for $50!
03-02-2021, 10:33 AM | #6 |
The x-members are interchangeable. The difference is in the arms & supporting pieces that attach. The upper a-arm shaft will require the correct shaft for the x-member (for the correct sizing).
I have a 1/2 ton x-member under my R30 dually. I simply used the C30 bracing & the C30 dually arms + steering parts. But.... The tire size makes a difference on final drive rpms. What size tires? 3.54 gearing might be possible on the HD 8-lug stuff & would be close to the desired 3.08 (which I feel would not be a good choice for a heavy truck).
03-02-2021, 11:50 AM | #7 |
Upper arms are the same it is the ball joint that is different. The upper bj bolts in. Lower arm is different b'cuz of the hole for the 3/4t Ball Joint that presses in. And of course the spindle itself is different due to the wheel bearing size.
03-02-2021, 11:56 AM | #8 |
OR it is all being scooped up and sold for scrap due to the 'environmental nazis' making the wrecking yards be as clean as hospitals. Everything has to under a roof and everything in the yard concreted. When the steel prices were up about 8-10 years ago there was an unprecedented amount of yard clean up. Everything was crushed and sent to china--didn't matter what it was. It was an opportunity to clean the yard AND clean up money wise at the same time----A LOT of good stuff was eliminated forever
