Old 08-14-2020, 09:17 PM   #76
jarrodblake
jarrodblake's Avatar
Re: 1970 C30 Car hauler Buildish thread.
Originally Posted by CG View Post
This is a great build to watch. Im curious what the wheel base is on your truck. I have a 157" wheel base and yours looks longer. Maybe an optical illusion? And if you dont mind can you tell me your bed length is without the dovetail please. I love the idea of the removable dovetail! What length ride can you get up there with the dovetail installed?
The truck was stretched 4 feet it has a wheel base of 205". Before I cut the dovetail off the bed was a total of 17 feet. 12 foot flat and 4 foot of dovetail. I will be adding one foot to the flatbed as the rear of the frame sticks out past the bed 10 inches. When it is all said and done the bed will be 13 feet log and when I add the dove tail it should be 18 feet and maybe a inch or two. With the 17 foot bed I was able to fit a single cab long bed truck on it. Now with the extra foot, 18 feet or so I should just be able to fit a extended cab long bed on it and have a few inches to spare.
Here is what I have so far of the rear extension I am reusing some of the railing on the rear it is welded to a mix of chrome moly and dom tubing from other projects its all 1.75 120 wall. the plan is to use 1.50 inch pins to hold on the dovetail at the top. the bottom will slide into the receiver on the bumper hitch I made.
IMAG3091 by jarrod vanwinkle, on Flickr
IMAG3092 by jarrod vanwinkle, on Flickr
IMAG3093 by jarrod vanwinkle, on Flickr
The outer parts of the extension of the bed is shorter than the 4 inner extensions, I am hoping it will help distribute the load of the dovetail instead of all the weight being on the bumper hitch.
IMAG3094 by jarrod vanwinkle, on Flickr
IMAG3095 by jarrod vanwinkle, on Flickr
I also got a cheap rear view mirror off ebay
IMAG3085 by jarrod vanwinkle, on Flickr
IMAG3086 by jarrod vanwinkle, on Flickr
I also replaced the rear brake line I could not front one the same length one that was on it I ordered 2 but they were too short. I ended up making me own brake line I ended up ordering a 18 inch 3an brake line and a male and female 3an to 7/16-24 adapters and a 7/16-24 t fitting so I could get the correct length line.
IMAG3088 by jarrod vanwinkle, on Flickr
IMAG3089 by jarrod vanwinkle, on Flickr
Current state of the garden
IMAG3075 by jarrod vanwinkle, on Flickr
IMAG3074 by jarrod vanwinkle, on Flickr
IMAG3076 by jarrod vanwinkle, on Flickr
IMAG3077 by jarrod vanwinkle, on Flickr
The forest of tomatoes is taking over
IMAG3078 by jarrod vanwinkle, on Flickr
IMAG3079 by jarrod vanwinkle, on Flickr
IMAG3080 by jarrod vanwinkle, on Flickr
IMAG3081 by jarrod vanwinkle, on Flickr
IMAG3082 by jarrod vanwinkle, on Flickr
IMAG3083 by jarrod vanwinkle, on Flickr
IMG_29451 by jarrod vanwinkle, on Flickr
IMAG3084 by jarrod vanwinkle, on Flickr
jarrodblake is offline   Reply With Quote
Old 08-16-2020, 12:01 AM   #77
jarrodblake
IMAG3097 by jarrod vanwinkle, on Flickr
IMAG3098 by jarrod vanwinkle, on Flickr
IMAG3099 by jarrod vanwinkle, on Flickr
I got the final design done in C.A.D of the rear of the flat bed.
IMAG3100 by jarrod vanwinkle, on Flickr
IMAG3101 by jarrod vanwinkle, on Flickr
IMAG3102 by jarrod vanwinkle, on Flickr
Welded on nuts for the license plate and reverse lights. the brake lights are screwed on.
IMAG3103 by jarrod vanwinkle, on Flickr
I was hoping to make it out of 11 gauge but I ended up getting laid off last month when my work reopened. So I ended up using a piece of 14 gauge. the piece is not very big and the bend at the bottom of the corners should give it enough strength.
IMAG3104 by jarrod vanwinkle, on Flickr
IMAG3105 by jarrod vanwinkle, on Flickr
IMAG3106 by jarrod vanwinkle, on Flickr
IMAG3107 by jarrod vanwinkle, on Flickr
IMAG3109 by jarrod vanwinkle, on Flickr
IMAG3110 by jarrod vanwinkle, on Flickr
IMAG3111 by jarrod vanwinkle, on Flickr
Tomorrow I will finish weld it
Old 08-18-2020, 12:38 AM   #78
jarrodblake
The rear end turned out great now I just need to paint the rest of the bed.
IMAG3113 by jarrod vanwinkle, on Flickr
IMAG3112 by jarrod vanwinkle, on Flickr
IMAG3114 by jarrod vanwinkle, on Flickr
IMAG3115 by jarrod vanwinkle, on Flickr
Old 08-30-2020, 08:26 PM   #79
jarrodblake
Finally installed the grill. I was having a problem with my turn signals I could not get them to flash. It turned out the relay was wired backwards when I wired up the fuse box. thankfully it was an easy fix unfortunately it took me a month of trying different things to figure it out.
IMAG3116 by jarrod vanwinkle, on Flickr
I painted the door panels the other day. When I painted the hood for my brothers jeep.
IMAG3119 by jarrod vanwinkle, on Flickr
IMAG3120 by jarrod vanwinkle, on Flickr
I painted the rest of the bed and frame today
IMAG3124 by jarrod vanwinkle, on Flickr
IMAG3123 by jarrod vanwinkle, on Flickr
IMAG3125 by jarrod vanwinkle, on Flickr
Old 11-03-2020, 12:39 AM   #80
jarrodblake
Work on the truck has been slow I have been having hip problems. I ended up having hip surgery and the beginning of october. So I am just now getting back to working on the truck. But Before we get to the truck I built myself a santa maria grill for our fire pit back at the end of september.
If it makes a difference I used some of the metal from the truck to build the grill.
2020-09-17_01-57-18 by jarrod vanwinkle, on Flickr
2020-09-17_01-58-18 by jarrod vanwinkle, on Flickr
20200915_210450 by jarrod vanwinkle, on Flickr
20200915_210504 by jarrod vanwinkle, on Flickr
20200916_162034 by jarrod vanwinkle, on Flickr
20200919_104830 by jarrod vanwinkle, on Flickr
20200919_104837 by jarrod vanwinkle, on Flickr
20200919_104845 by jarrod vanwinkle, on Flickr
20201022_181251 by jarrod vanwinkle, on Flickr
Now back to the truck.
20200919_182419 by jarrod vanwinkle, on Flickr
I installed a set of under hood lights
IMAG3130 by jarrod vanwinkle, on Flickr
IMAG3131 by jarrod vanwinkle, on Flickr
I also installed a 3rd gen cummins intake horn to clear my brake master cylinder.
20201014_151814 by jarrod vanwinkle, on Flickr
20201014_151823 by jarrod vanwinkle, on Flickr
20201014_170240 by jarrod vanwinkle, on Flickr
I also picked up a 12 gallon air tank as my 3 gallon tank is not enough for my front 5k each bags. I also ordered another 5.65 CFM air compressor, but its on backorder.
20201019_202847 by jarrod vanwinkle, on Flickr
I also picked up a set of new shoes for the front of the truck, they are 19.5x 6 I wanted to run 20s for the tires but they are all ugly. I got a really good deal on one of them it was a return. I also got a decent deal on the second but it's slightly different its the same wheel but newer and the center bore is 1mm bigger and the lug holes are not chamfered. That said they require Flange Nut lug nuts so it doesn't matter. But I am going to have a set of center caps cut to fit them they will be cut out of 3/8 aluminum plate and I will polish them and depending on how close they get to my measurements they should be press fit. I don't like the large center caps that bolt on the out side to the lug nuts and I cant find any they fit a 4.59" Center Bore.
20201020_203314 by jarrod vanwinkle, on Flickr
20201020_203326 by jarrod vanwinkle, on Flickr
I took a gamble on the tires I wanted a set of open shoulder all seasons steer tires for the front of the truck. I could only find 3 that fit that and the other two were more of a mud tire that a all season. But the other two where name brand and I have never heard of Otani. regardless they should be better than the tires they are replacing with a date code of 1993. That said its impressive that tires from 93 hold 80 psi. and hulled a 6500lbs tractor.
20201023_162023 by jarrod vanwinkle, on Flickr
20201023_162031 by jarrod vanwinkle, on Flickr
Well I also decided to delete the factory heater the turbo touches it, and just from driving it around the yard in low gear it has put a hole in the heater box that and I am afraid it will catch fire once I start driving it on the road. I ordered a vintage air 506101 Compact Heater with Defrost. it should be in wednesday. I also ordered a vintage air heater delete plate a while back when I was planning on just ordering the heater/ ac box from vintage air. but realized I would still need to order the controls and the defrost would not work with out the a/c. One day I plan on installing a/c but I dont have the money for that right now. I am selling a few things to save up for a custom set of gauges.
20201028_191359 by jarrod vanwinkle, on Flickr
Hopefully I can install the 506101 Heater using these holes.
20201029_200545 by jarrod vanwinkle, on Flickr
20201029_200656 by jarrod vanwinkle, on Flickr
I also installed a set of bulkhead air line fittings.
20201031_164141 by jarrod vanwinkle, on Flickr
I drilled and tapped the manifold for a egt gauge while I had the turbo off. the other side already had been drilled and taped for a egt gauge but now that I have flipped the manifold I need one on this side because you need the egt gauge to read from the rear 3 cylinders as they run hotter.
20201102_191841 by jarrod vanwinkle, on Flickr
I also made a block off plate for the blower motor hole.
20201102_195332 by jarrod vanwinkle, on Flickr
Old 12-08-2020, 12:27 AM   #81
jarrodblake
Small update.
I painted the block off plate.
20201121_171350 by jarrod vanwinkle, on Flickr
I bought two 5.65 cfm compressors for my air ride/ onboard air.
20201121_173426 by jarrod vanwinkle, on Flickr
I install the vintage air heater.
20201122_170943 by jarrod vanwinkle, on Flickr
20201122_170927 by jarrod vanwinkle, on Flickr
20201122_170921 by jarrod vanwinkle, on Flickr
20201125_201853 by jarrod vanwinkle, on Flickr
I got the tires mounted
20201124_200701 by jarrod vanwinkle, on Flickr
20201124_200710 by jarrod vanwinkle, on Flickr
I finally installed the other intercooler tube.
20201128_142752 by jarrod vanwinkle, on Flickr
I modified the inner fenders to clear the intercooler piping and bedlined the under side.
20201204_200510 by jarrod vanwinkle, on Flickr
20201206_152644 by jarrod vanwinkle, on Flickr
20201206_152647 by jarrod vanwinkle, on Flickr
20201206_164232 by jarrod vanwinkle, on Flickr
My custom gauges came in today! The are NVU New Vintage USA gauges. in order Gps speedo, Coolant temp/ Oil PSI, 4k diesel tachometer. Boost gauge, Battery voltage, Fuel level and a EGT gauge.
50645285613_43ab991d17_o by jarrod vanwinkle, on Flickr
50646126247_1d6416f9ac_o by jarrod vanwinkle, on Flickr
20201207_130525 by jarrod vanwinkle, on Flickr
20201207_130530 by jarrod vanwinkle, on Flickr
20201207_130541 by jarrod vanwinkle, on Flickr
20201207_130538 by jarrod vanwinkle, on Flickr
20201207_130549 by jarrod vanwinkle, on Flickr
20201207_130601 by jarrod vanwinkle, on Flickr
20201207_130604 by jarrod vanwinkle, on Flickr
20201207_130606 by jarrod vanwinkle, on Flickr
20201207_130654 by jarrod vanwinkle, on Flickr
20201207_210641 by jarrod vanwinkle, on Flickr
Old 12-08-2020, 11:24 AM   #82
daddyjeep
daddyjeep's Avatar
The new gauges are great. I am not a diesel guy so this might be a dumb question.... What kind of boost is typical for your set up? The range on the gauge is higher than I expected.
Also, is that a Fiero fastback roof in the corner?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-08-2020, 04:53 PM   #83
jarrodblake
Thanks! I should only be making 36-40 pis of boost on the current turbo but I plan on going compound turbos at some point, but I still will only be making 50 to 70 psi max i just want to leave room to grow if I ever need to.
The roof is for the Porsche 911. I had a 1970 911E rust bucket. But I bought a targa tub to build instead so the roof is going on the targa tub at some point.
Old 12-15-2020, 07:21 AM   #84
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Jarrod, very nice work on your truck! Those gauges are sweet! I wish DD would have done custom gauges when I ordered my VHX cluster in my orange truck. Oh well. You will be able to defrost with out AC. It may just take a little longer. My orange truck has no AC hooked up and on certain wet snowy high humid days it is a pain but I just crack the windows a bit and it helps. I like those wheels too. The bed is taking shape quite nicely as well. Keep up the great work.
Ryan
1969 Chevy milk truck
Old 01-02-2021, 04:13 AM   #85
jarrodblake
Thanks!, I was planning on getting a set of Dakota Digital RTX gauges, however after months of thinking about it and what it would cost. I decided to go with custom gauges as I would have had to buy different BIM Expansion modules to add boost and diesel tachometer signal converter. and I would still have to buy a standalone egt gauge. That and I could not get past the 8k tachometer. The cost ended up being the same as if I went with the DD gauges. One day I will have a/c but for know this will work for me. I'm really happy with the wheels but I will be a while before I can afford the rears. That and I plan to swap the rear axle to a dana s111 axle out of a dodge 4500/5500, its rated at 14,500lbs it uses a 10 lug bolt pattern. So I have to wait until I can afford the axle swap and the wheels and tires. I just hope my current set of rear tire last until then.
I am finally able to start on the exhaust. I ordered the tubing V bands a stuff before I had my hip sugary I am just now getting to where I can get down and back up that I am able to install the exhaust. I'm using 4 inch stainless tubing.
20201209_164159 by jarrod vanwinkle, on Flickr
20201211_163114 by jarrod vanwinkle, on Flickr
I have super low ceilings just over 8 feet.
20201211_163131 by jarrod vanwinkle, on Flickr
20201211_163026 by jarrod vanwinkle, on Flickr
20201211_203416 by jarrod vanwinkle, on Flickr
using a WIX Filter - 42790
20201211_203405 by jarrod vanwinkle, on Flickr
20201211_203432 by jarrod vanwinkle, on Flickr
20201226_202923 by jarrod vanwinkle, on Flickr
I started milling a heater control bezel. I scored for cheap on ebay.
20201211_214440_001 by jarrod vanwinkle, on Flickr
Test fit.
20201211_221859 by jarrod vanwinkle, on Flickr
20201222_210043 by jarrod vanwinkle, on Flickr
20201222_234705 by jarrod vanwinkle, on Flickr
20201222_234701 by jarrod vanwinkle, on Flickr
I used an steel/ aluminum epoxy
20201226_151931 by jarrod vanwinkle, on Flickr
20201226_154943 by jarrod vanwinkle, on Flickr
20201226_202516 by jarrod vanwinkle, on Flickr
20201226_211056 by jarrod vanwinkle, on Flickr
I'm still wait on some switches the one I have I bought off amazon but I ordered some from billet automotive buttons I did not realize until after I placed the order they are coming from australia so its going to be a while before I can get them wired up.
20210101_202048 by jarrod vanwinkle, on Flickr
Old 01-08-2021, 07:25 AM   #86
Dieselwrencher
Very nice! I've been making a similar gauge/switch mounting panel for my orange truck. I need to finish it but there just isn't the time. Your heater control mount turned out sweet! Keep up the great work!
Ryan
Old 01-09-2021, 08:00 PM   #87
Richard2112
Richard2112's Avatar
Very nice work.
Richard2112 is offline   Reply With Quote
Old 01-10-2021, 01:30 AM   #88
jarrodblake
Thanks, I have been considering having some one make a cnc overlay for the gauge/switch panel. That way I can easily change it up if I ever need to add something or reagange it. I'm happy with how the heater control panel turned out.
Originally Posted by Richard2112 View Post
Very nice work.
Thanks!
I started wiring the gauge cluster.
20210102_201122 by jarrod vanwinkle, on Flickr
20210102_165220 by jarrod vanwinkle, on Flickr
I tested the lights
20210105_205801 by jarrod vanwinkle, on Flickr
I installed a coolant overflow and prefilter.
20210104_203222 by jarrod vanwinkle, on Flickr
20210109_164206 by jarrod vanwinkle, on Flickr
I had to install an aftermarket washer bottle.
20210104_203210 by jarrod vanwinkle, on Flickr
20210104_203330 by jarrod vanwinkle, on Flickr
I cooked my old battery so I upgraded to this monster. I was considering going with dual batteries. But I believe it will be sufficient. It's 15.5 inches wide.
20210107_201107 by jarrod vanwinkle, on Flickr
20210107_201044 by jarrod vanwinkle, on Flickr
I bought a new under bed box off ebay. I know you get what you pay for. But I was not expecting it to be so thin. it's made of 18 gauge aluminum. Its 48W,17T,16D the battery fits in it perfectly.
20210109_160419 by jarrod vanwinkle, on Flickr
20210109_160446 by jarrod vanwinkle, on Flickr
20210109_160809 by jarrod vanwinkle, on Flickr
I plan to install the compressors in the box as well.
20210109_173200 by jarrod vanwinkle, on Flickr
Old 01-13-2021, 10:24 AM   #89
daddyjeep
daddyjeep's Avatar
Those compressors can really generate some heat. I would keep an eye on how hot it gets in that sealed box.
04 1500 crew cab
Old 01-31-2021, 05:09 AM   #90
LT7A
Very interesting thread. You've done a lot of nice work on this rig and it's going to be very useful. I'm envious.
Old 02-11-2021, 01:25 AM   #91
jarrodblake
I don't think they should get too hot between the three of them they make a little over 13 cfm and it's only a 12 gallon tank. So day to day they won't run long enough to get hot. The only time the should ever have to run very long is if I ever end up needing to use a air tool. But I will keep an eye on them.
Thanks! I want it to be able to do a little bit of everything.
Well I started on the box I layed out everything I was planning on installing the box behind the cab on the driver side. So I drilled all my holes installed rive nuts and started mounting and wiring everything up. Then I thought I need to install the new gas tank as I need to put a hole in the back of the cab as I wand to use the stock fuel fill. I was planning on using the 40 gallon suburban tank and have it in the middle of the frame behind the cab but I wrote the measurements down wrong. the tank was to tall to fit where I was planning on putting it. And as big as my truck is I had nowhere else to put it as the only other place it would have fit was where I was putting the air tank. So I had to find a new fuel tank. I started looking at semi tanks I was hoping to find a 40-50 gallon tank. But all the 40 to 50 gallon tanks had a diameter of 25-26 inches but my bed from the out side of the frame to the outer edge of the bed was only 26 inches and from the underside of the bed to the bottom of the frame rail is only 21 inches so I had to settle on a smaller tank I ended up getting a really good deal on as 33 gallon tank with brackets its from a 2006 Nissan UD2000. its 16x40.
Now to the bad news I drilled 30 some holes in the box to mound the battery and compressors and everything else I needed for it but Now I need to mound the box on the passenger side and I needed to move the battery to the other side of the box as the battery cable would be to long but now I have to move everything to the other side of the box so I can still have space to store stuff in it.
Before
20210112_163616 by jarrod vanwinkle, on Flickr
20210112_184516 by jarrod vanwinkle, on Flickr
After
20210121_202232 by jarrod vanwinkle, on Flickr
20210121_210801 by jarrod vanwinkle, on Flickr
20210121_203737 by jarrod vanwinkle, on Flickr
20210121_210914 by jarrod vanwinkle, on Flickr
20210123_190438 by jarrod vanwinkle, on Flickr
I also started on my switch panel
20210115_204535 by jarrod vanwinkle, on Flickr
20210112_155330 by jarrod vanwinkle, on Flickr
I also redid the manual fuel shut off.
20210116_173216 by jarrod vanwinkle, on Flickr
20210116_173316 by jarrod vanwinkle, on Flickr
20210116_173328 by jarrod vanwinkle, on Flickr
20210116_173250 by jarrod vanwinkle, on Flickr
I got more of the exhaust installed
20210118_171740 by jarrod vanwinkle, on Flickr
Since I was not installing the side box on the driver side anymore I installed a side ladder.
20210124_142031 by jarrod vanwinkle, on Flickr
20210124_142138 by jarrod vanwinkle, on Flickr
20210124_143954 by jarrod vanwinkle, on Flickr
20210124_193234 by jarrod vanwinkle, on Flickr
The new tank!
20210124_195415 by jarrod vanwinkle, on Flickr
20210124_195731 by jarrod vanwinkle, on Flickr
Making some brackets for the tank brackets
20210130_212551 by jarrod vanwinkle, on Flickr
20210130_212555 by jarrod vanwinkle, on Flickr
20210210_153603 by jarrod vanwinkle, on Flickr
20210210_162500 by jarrod vanwinkle, on Flickr
20210210_162006 by jarrod vanwinkle, on Flickr
20210210_162435 by jarrod vanwinkle, on Flickr
20210210_190920 by jarrod vanwinkle, on Flickr
20210210_190911 by jarrod vanwinkle, on Flickr
I started making a flange for the fuel fill neck to pass through the cab to fill the tank.
20210210_201926 by jarrod vanwinkle, on Flickr
20210211_002026 by jarrod vanwinkle, on Flickr
Here is another truck doing what I plan on doing.
filler neck by jarrod vanwinkle, on Flickr
filler neck1 by jarrod vanwinkle, on Flickr
Old 03-03-2021, 02:57 PM   #92
68 TT
Still plays with trucks
68 TT's Avatar
Looks like the project is coming along nicely.
Just a side note, I used to fabricate trailers professionally and those short rails you removed from the sides of the bed are usually added to give the outer bed rails extra strength to resist bending under load.
With yours being home built it may be over built with larger tubing than needed and not need these secondary rails.
If you do need them you may run into some deflection caused stress cracking of the tubing adjacent to the welds where the outriggers attach back to the main rails over the truck frame. Watch out for this.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-05-2021, 08:46 PM   #93
jarrodblake
Thanks, Are you talking about the side rails? I will keep an eye on them. But I don't think the guy that build the bed intended the side rails to distribute the load. The rails may have especially where the bead meets the dove tail, but the guy that built the bed said him and one of his buddy built it in his backyard. They did not do a very good job. its straight and the inner and outer rails are almost square but the side supports and cross rails are not square, and the frame slopes up in the rear where they extended it just over an inch. That said the bed is made out of 1.5x3 3/16 wall tubing. I have considered adding a side rail back to it but it would be attached directly to the bed rails turning the 1.5x3 into the 1.5x4.5 I have also thought about adding another set of outriggers as well but i'm in the middle of adding more weight to the bed I don't know how heavy it will get.
Back to the build.
fuel filler neck bulkhead
20210211_204106 by jarrod vanwinkle, on Flickr
20210211_205234 by jarrod vanwinkle, on Flickr
20210211_210103 by jarrod vanwinkle, on Flickr
20210213_155703 by jarrod vanwinkle, on Flickr
20210213_194908 by jarrod vanwinkle, on Flickr
20210213_194921 by jarrod vanwinkle, on Flickr
20210213_194914 by jarrod vanwinkle, on Flickr
20210223_153840 by jarrod vanwinkle, on Flickr
20210223_154614 by jarrod vanwinkle, on Flickr
20210223_161128 by jarrod vanwinkle, on Flickr
20210223_203814 by jarrod vanwinkle, on Flickr
20210223_203810 by jarrod vanwinkle, on Flickr
New fuel sending unit to match the gauge.
20210223_203806 by jarrod vanwinkle, on Flickr
20210223_204454 by jarrod vanwinkle, on Flickr
20210223_204640 by jarrod vanwinkle, on Flickr
20210224_140800 by jarrod vanwinkle, on Flickr
I started on the side skirts they will sit flush with the cab they sit 5 inches in and have will have a two inch lip. they will hide the tank and side boxes.
20210224_203639 by jarrod vanwinkle, on Flickr
20210224_203703 by jarrod vanwinkle, on Flickr
20210224_203718 by jarrod vanwinkle, on Flickr
20210224_204419 by jarrod vanwinkle, on Flickr
20210224_203729 by jarrod vanwinkle, on Flickr
20210225_204353 by jarrod vanwinkle, on Flickr
20210225_211407 by jarrod vanwinkle, on Flickr
20210301_151009 by jarrod vanwinkle, on Flickr
20210301_152010 by jarrod vanwinkle, on Flickr
50994304837_1e06363588_kmsp by jarrod vanwinkle, on Flickr
Old 03-08-2021, 11:49 AM   #94
daddyjeep
daddyjeep's Avatar
I like the side skirt idea. Looks good
04 1500 crew cab
Old 03-08-2021, 08:34 PM   #95
SkidmoreGarage
I'm enjoying your build! It probably wasn't on your radar, but the side skirts are great for pedestrian and bicyclist safety. If something were to occur, however unlikely, you are less likely to have someone's kid get sucked under the rear tires and die.
Another side benefit is improved mileage (small percentage).
SkidmoreGarage is offline   Reply With Quote
Old 03-09-2021, 07:35 AM   #96
regan wilson
regan wilson's Avatar
I never thought about side skirts about safety. I thought that it needed them for looks. I just kept hoping he would build some. Good work
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-25-2021, 10:42 PM   #97
jarrodblake
Thanks!
I did consider the possible gas mileage benefit and wanted to protect the gas tank. But I had not thought about things getting sucked under the truck.
I always planned on making side skirts but I could never decide on how they would look.
Bought some more cheap aluminum boxes,
20210306_154356 by jarrod vanwinkle, on Flickr
20210306_161046 by jarrod vanwinkle, on Flickr
Got the grill out of storage!
20210310_184026 by jarrod vanwinkle, on Flickr
20210310_174641 by jarrod vanwinkle, on Flickr
20210316_175740 by jarrod vanwinkle, on Flickr
20210316_185115 by jarrod vanwinkle, on Flickr
Made a bracket and installed a pre pump fuel filter.
20210313_162342 by jarrod vanwinkle, on Flickr
20210313_162337 by jarrod vanwinkle, on Flickr
20210317_165952 by jarrod vanwinkle, on Flickr
20210317_165945 by jarrod vanwinkle, on Flickr
20210317_165957 by jarrod vanwinkle, on Flickr
20210317_174153 by jarrod vanwinkle, on Flickr
20210317_174201 by jarrod vanwinkle, on Flickr
20210318_203956 by jarrod vanwinkle, on Flickr
20210318_203950 by jarrod vanwinkle, on Flickr
20210319_162824 by jarrod vanwinkle, on Flickr
20210319_163218 by jarrod vanwinkle, on Flickr
20210319_162820 by jarrod vanwinkle, on Flickr
20210320_145626 by jarrod vanwinkle, on Flickr
20210320_145909 by jarrod vanwinkle, on Flickr
20210320_151643 by jarrod vanwinkle, on Flickr
20210320_151824 by jarrod vanwinkle, on Flickr
20210320_151839 by jarrod vanwinkle, on Flickr
The front bumper was in the way so I decided to install it, I don't know if i'm going to get a new one or not. I thought about painting it white as the chrome is peeling off but it matches the look. I bought a set of fog lights as its a 71-72 bumper. They look ok but I hate how the mount.
20210320_202100 by jarrod vanwinkle, on Flickr
I wire wheeled and por15ed where they touch the frame
20210320_204706 by jarrod vanwinkle, on Flickr
20210324_162600 by jarrod vanwinkle, on Flickr
20210324_162632 by jarrod vanwinkle, on Flickr
20210324_170003 by jarrod vanwinkle, on Flickr
Also installed jumper terminals
20210322_202955 by jarrod vanwinkle, on Flickr
20210322_203007 by jarrod vanwinkle, on Flickr
20210322_205232 by jarrod vanwinkle, on Flickr
20210322_205244 by jarrod vanwinkle, on Flickr
Made a door for the gas tank it has a cut out for the pull out ladder.
20210323_165408 by jarrod vanwinkle, on Flickr
20210323_165411 by jarrod vanwinkle, on Flickr
20210323_174952 by jarrod vanwinkle, on Flickr
20210323_175202 by jarrod vanwinkle, on Flickr
20210323_175209 by jarrod vanwinkle, on Flickr
20210323_175151 by jarrod vanwinkle, on Flickr
20210324_202713 by jarrod vanwinkle, on Flickr
20210325_140921 by jarrod vanwinkle, on Flickr
20210325_140911 by jarrod vanwinkle, on Flickr
Its come a long way so far.
IMAG0975 by jarrod vanwinkle, on Flickr
20210325_140949 by jarrod vanwinkle, on Flickr
IMAG0859 by jarrod vanwinkle, on Flickr
20210325_141021 by jarrod vanwinkle, on Flickr
Old 03-26-2021, 01:27 PM   #98
Dieselwrencher
Great work! The lights look pretty good in there. Nice work on the fuel tank and sides. It's amazing how much time these projects will eat up huh?
Ryan
Old 04-03-2021, 09:45 PM   #99
jarrodblake
Thanks, Well if my body would quit falling apart, I would have had it finished by now lol, back surgery 2019, 2020 hip surgery, now getting a full hip replacement in a month or so don't have a date yet, with my luck I'll have to have a knee done next year lol. at the moment I am only able to work 2-3 hours a day at most before I can no longer stand. I will probably be down a few months between the surgery and physical therapy. So i'm hoping to get this side done so I can get started on the other side so I can get the truck out of the garage before my surgery.
I picked up a front plate I was looking for something period correct, it's close but its a 90s remake. I was hoping it was steel but its aluminum. It's a bit to nice I was hoping to scratch it up a little and have it rust and make it match the truck but idk.
20210329_141529 by jarrod vanwinkle, on Flickr
20210329_141532 by jarrod vanwinkle, on Flickr
That said some of the metal showed up for the sides. i'm skinning the sides in 18 gauge aluminum as at the moment its cheaper than 18 gauge steel. metal prices are way up. 2 years ago I bought some 18 gauge steel 24x48 sheet for $28 its now $63.
I was going to use the old side box door skin, but when I striped it all the way down it had a ton of pitting.
20210326_151330 by jarrod vanwinkle, on Flickr
20210329_205914 by jarrod vanwinkle, on Flickr
starting on the door skins
20210402_163153 by jarrod vanwinkle, on Flickr
20210402_164922 by jarrod vanwinkle, on Flickr
20210402_165049 by jarrod vanwinkle, on Flickr
20210402_165831 by jarrod vanwinkle, on Flickr
20210402_165851 by jarrod vanwinkle, on Flickr
20210402_170448 by jarrod vanwinkle, on Flickr
20210402_172907 by jarrod vanwinkle, on Flickr
20210402_174451 by jarrod vanwinkle, on Flickr
20210402_174521 by jarrod vanwinkle, on Flickr
20210402_174620 by jarrod vanwinkle, on Flickr
20210402_174717 by jarrod vanwinkle, on Flickr
The fuel tank access door with the ladder cut out.
20210402_182921 by jarrod vanwinkle, on Flickr
20210402_183714 by jarrod vanwinkle, on Flickr
20210402_184444 by jarrod vanwinkle, on Flickr
20210403_155519 by jarrod vanwinkle, on Flickr
20210403_161733 by jarrod vanwinkle, on Flickr
20210403_155714 by jarrod vanwinkle, on Flickr
Old 04-05-2021, 10:34 PM   #100
jarrodblake
Started on the middle door,
20210405_161009 by jarrod vanwinkle, on Flickr
20210405_164220 by jarrod vanwinkle, on Flickr
20210405_170624 by jarrod vanwinkle, on Flickr
20210405_170743 by jarrod vanwinkle, on Flickr
20210405_171116 by jarrod vanwinkle, on Flickr
20210405_171130 by jarrod vanwinkle, on Flickr
20210405_171317 by jarrod vanwinkle, on Flickr
20210405_203650 by jarrod vanwinkle, on Flickr
20210405_204118 by jarrod vanwinkle, on Flickr
20210405_203654 by jarrod vanwinkle, on Flickr
20210405_203730 by jarrod vanwinkle, on Flickr
air ride, c30, cummins, nv4500, ramp truck
