Old 03-06-2021, 10:15 AM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Shoulder belts in jimmy
Have a 1972 jimmy with a four wheel camper on it going to use more this and would like to make it safer with newer shoulder belts. I found this but don't no how they will fit or if they will get in the way when getting in on the passenger side.
Thanks Garycontent://com.android.chrome.FileProvider/images/screenshot/16150395691801238289746.jpg
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-06-2021, 10:40 AM   #2
Gary 70 Jimmy
Re: Shoulder belts in jimmy
Has any ever used these in a blazer
https://www.ecklers.com/
Old 03-06-2021, 11:31 AM   #3
60case
I used them in a 1970 blazer I had to make a mounting bracket for the middle belts. They worked out good
60case is offline   Reply With Quote
Old 03-06-2021, 11:34 AM   #4
hemi43
hemi43's Avatar
Mine are similar. You need a roll bar for them to work.
hemi43 is offline   Reply With Quote
Old 03-06-2021, 01:22 PM   #5
Gary 70 Jimmy
Do have any picture Don't have a roll bar in the camper.
Old 03-06-2021, 01:24 PM   #6
Gary 70 Jimmy
I see why you would have to make a bracket they won't be a strait bolt in. Is their enough room to bolt the out side ones to the floor.
Old 03-08-2021, 05:38 PM   #7
hemi43
hemi43's Avatar
The passenger lower belt retractor need to be mounted behind the seat on the box floor right by the "B"pillar. There's not enough room to mount it in the original location on the cab floor because it would be too difficult for passengers to get in the back. On the driver's side, I used the original mounting location on the cab floor.
Old 03-08-2021, 05:56 PM   #8
Gary 70 Jimmy
Thanks for the information. I have to worry about the camper so I won't be able to mount it to the rear bed floor going to go out and look at it to see where it can be mounted.
Old 03-11-2021, 02:31 AM   #9
K5Fan
My 70 Blazer came with a roll bar, but it's not stock, nor do I know if they even came stock with a roll bar. The roll bar that I got with mine is set too far back to put a shoulder belt, so I got seats from a 2001 Tahoe that has the shoulder harness built into the seat. I had to make new mounts to mate with the stock mount configuration, but it wasn't too bad. I guess I will keep the stock seats just in case I ever decide to sell it.
K5Fan is offline   Reply With Quote
