02-23-2021, 09:11 PM | #1 |
Headliner ideas
Looking for ideas ,pics, of headliner ideas, nothing too fancy, no flames, lol..
02-24-2021, 03:34 AM | #2 |
Re: Headliner ideas
I'll be watching this thread. I need a headliner in my panel truck. I'm looking for something different and inexpensive.
1951 Chevy Panel Truck |
02-24-2021, 08:55 AM | #3 |
Re: Headliner ideas
I glued a piece of pleated vinyl to the roof and trimmed it out with matching pinch weld molding.
02-24-2021, 10:19 AM | #4 |
Re: Headliner ideas
I am hoping to do a 1 piece headliner that goes beyond the spot in the middle. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
02-24-2021, 12:47 PM | #5 |
Re: Headliner ideas
Ive heard that suggestion a few times, i cant use a factory size as i chopped the top and my roof is bigger than an original, i have the abs boards and will make a one piece, but just looking for design ideas
02-24-2021, 02:26 PM | #6 |
Re: Headliner ideas
Classic parts and maybe another outfit sells a one piece plastic headliner. Not for the thin of wallet though. https://www.classicparts.com/1947-53...20group%20%231
Depending on one's skill and patience a person might just use a two piece for a pattern and cut a new one piece out of similar upholstery backer board AKA Panel board. That would probably be a local upholstery supply house thing or see if an upholstery shop would sell you a piece. Or all jokes aside, watch several episodes of *****in Rides and study how the upholstery dude lays the foam on the inside of roofs of cars to glue in those one piece headliners he does. He does most of that with some sort of foam and an adhesive that works like contact cement.
02-25-2021, 11:16 AM | #7 |
Re: Headliner ideas
I am going to try and make something similar to my door panels.
I think it will be 2 panels to allow for installation.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
02-26-2021, 03:06 AM | #8 |
Re: Headliner ideas
Did you use the Weldwood Landau glue? Sticking good still?
02-26-2021, 09:25 AM | #9 |
Re: Headliner ideas
I did, nothing else stands up in the hot sun. Previous attempts with 3M spray adhesive failed miserably.
02-26-2021, 04:02 PM | #10 |
Re: Headliner ideas
I used that glue to adhere material to the 1 piece headliner in my 48 truck. It was an all black interior and could get hot at times. That glue held up great for 5-6 yrs until I sold it.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-04-2021, 10:15 PM | #11 |
Re: Headliner ideas
Mine will look like this in the same color as my bench - though this color is very close. I've waited way too long and need to go visit the upholsterer soon. I've seen this done with LED strip lights around the perimeter but I think it would be too "Artsy-craftsy" for me.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-05-2021, 10:09 AM | #12 | |
Re: Headliner ideas
03-05-2021, 10:31 AM | #13 |
Re: Headliner ideas
We used material similar with press board thin padding, and door edge molding on the outside edge. My wife stitched it and help install it. Bought matching material same as junk yard seat I used.
03-05-2021, 09:30 PM | #14 |
Re: Headliner ideas
I tried that plastic off the shelf one. After it fell in my face while driving it was disposed of and that’s all I have to say about that.
I matched the seat leather and stitch pattern and used the factory boarder rubber. Much happier.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
03-09-2021, 04:01 PM | #15 |
Re: Headliner ideas
Here is my 51 done with 2 panels
03-10-2021, 12:39 PM | #16 | |
Re: Headliner ideas
Noticed too the factory speaker box and I think I see a couple of speakers in it. What did you use? Any tips on running the wiring? Is that a GPS there too? |
03-10-2021, 08:17 PM | #17 | |
Re: Headliner ideas
The speakers came mounted to a plate that went into the stock speaker box, I believe they were kicker brand (there are several out there). I just run those on the stereo front so I can fade them out. Because of their location you need to tone them down and let the other bigger speakers fill the volume. I used some welding rod and went in from the bottom up in the “A” pillar driver side. I had the visor out so I could feel the rod when it came through. Then I pulled a string in, then the wire. Patients it can be a pain. No it is not a GPS, it’s the microphone for the radio phone interface. Does it work, not all that well do to the background noise. On the visor might be a better choice but the install could be uglier. John
03-11-2021, 02:29 PM | #18 |
Re: Headliner ideas
Though your picture is a bit out of focus I like the door edge guard. What's the black ting on the mirror? Microphone for phone?
03-11-2021, 02:38 PM | #19 | |
Re: Headliner ideas
03-11-2021, 06:39 PM | #20 | |
Re: Headliner ideas
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
03-12-2021, 12:13 AM | #21 | |
Re: Headliner ideas
Blowing up the picture it almost looks like stock rubber painted a metallic color. I doubt it is because the paint would crack off. Though I HAVE had luck painting weird stuff with high bond brush-on primer from Home Depot!
03-21-2021, 10:08 AM | #22 |
Re: Headliner ideas
I have the White Wolf Speed Shop abs plastic headliner. It's not fancy but 10x more durable than the cardboard repops and fits great.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
