Old 01-20-2021, 05:35 PM   #51
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Tinkering on the 72 jimmy, may have hurt the engine...Thoughts?
Originally Posted by DeadheadNM View Post
Check. Beers on me guys
Let me guess, Leinenkugel?
New dash, steering wheel and tach installed. Still chasing some wiring issues. Never ends.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-21-2021, 10:53 AM   #52
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Have case, will travel...
Old 03-10-2021, 03:25 PM   #53
too much stuff
Roadtrip!
After sitting for awhile, i finally got back to getting the interior back together. Wipers now work, all the heat/fan setting work correctly, turn signals, and the under dash lights are good again. Amazing how much time goes into a small area...
Next up is rear brakes, brake lights and figure why the fuel gauge isn't working.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-10-2021, 04:02 PM   #54
best view
Just keep at it spring will be here in 3 months
best view is online now   Reply With Quote
Old 03-10-2021, 04:10 PM   #55
too much stuff
Roadtrip!
Hopefully in 3 months... Haha. Hopefully my 69 will be coming home from the body shop by then so i need the garage stall back.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-10-2021, 08:44 PM   #56
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking good, I understand the time involved with the little things. Keep plugging away and it miraculously gets done.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-11-2021, 03:04 AM   #57
K5Fan
I don't know how "Ya'll" live in those cold places. We complain about 40 degree weather here.
Chris.
K5Fan is offline   Reply With Quote
Old 03-11-2021, 07:33 AM   #58
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice progress. I’m hoping to wake my trucks up from hibernation this weekend.
Old 03-11-2021, 09:53 PM   #59
David623
Curious is that an original color? I just got mine back on the road.
https://67-72chevytrucks.com/vboard/...1&d=1615513743
David623 is offline   Reply With Quote
Old 03-21-2021, 09:45 AM   #60
too much stuff
Roadtrip!
It has had a repaint, but i think it is close to original color.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-21-2021, 09:55 AM   #61
too much stuff
Roadtrip!
Tackled the rear brakes yesterday... Sorry i didn't get pics so you will have to use your imagination. I think i know why the brakes didn't feel right.
Started on the driver side. Wife was stepping on the brake pedal and i could hear things moving inside the drum but i could still rotate the tire. Pulled the drum, star adjuster is in backwards and wedged into the spring. That explains alot.
Go to the pass side, wife steps on the pedal, i can hear things moving but can still rotate the tire. Pulled the drum and shook my head... Somehow they put the ebrake bracket on the outside of the shoe between the adjuster bracket. I think at that point they put the springs in wherever they fit and hoped for the best. The adjuster bracket was over a 1/2" away from even touching the star wheel!
On the bright side, the brakes were in decent shape.
Test drive soon...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-21-2021, 03:56 PM   #62
K5Fan
Did you get the fuel gauge working?
Old 03-21-2021, 06:23 PM   #63
too much stuff
Roadtrip!
Didn't investigate that yet. I did get the brake lights working today however. That isn't much fun pulling that switch...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-21-2021, 09:07 PM   #64
72 Super
72 Super's Avatar
We never know what we are getting with these old vehicles. Making good progress Eric.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 03-22-2021, 07:02 PM   #65
K5Fan
From what I can see in the photos, the gauge is now reading "E". If it stays there even with fuel in it, my guess would be the sending unit. If the gauge was sitting at the 3 o'clock position and stays there, that would be indicative of a connection issue. As you know, these fuel gauges are KIND OF LIKE an ohmmeter. They are different but my 70 sending unit is set from 90 ohms at Full, and zero or close to zero at Empty.
Might be time to drop the fuel cell, unless someone else knows a better way. Let me know what happens!
Chris.
Old 03-22-2021, 09:21 PM   #66
too much stuff
Roadtrip!
Put insurance on it today and took it for a cruise. Brakes work great now. Get back home, tire goes flat. May have to replace all of them due to age. One step forward, 2....HMMMM i have a set of rally wheels with like new 31x10.5x15s...
Ray
Thanks ray.
Chris.
We did have the tank out to clean the old gas out. It is an aftermarket tank i think and we tried to retrofit a different sender. I wasn't there when it went back together however.
Thanks for the tip.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-10-2021, 08:41 PM   #67
too much stuff
Roadtrip!
Another update. The tires that still looked like new are so aged i don't dare run them on the road. I dug out a set of rally wheels with a nice set of 31x10.5x15 tires. Well... the rally wheels just didn't do it for me. I had a set of 15x8 stock wheels i was saving for something. I guess this is something. Gave them a quick scuff and squirt and here is the end result. I think i will end up keeping the caps on.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-10-2021, 09:32 PM   #68
Ol Blue K20
I like it......a lot! It's looking great!
Dale
Old 04-11-2021, 04:59 AM   #69
jjzepplin
jjzepplin's Avatar
Oh yeah! the stockers are very nice looking for sure. How wide are those?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-11-2021, 09:07 AM   #70
too much stuff
Roadtrip!
Thanks, i am liking it more all the time.
15 x 8
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
