03-20-2021, 04:51 PM | #1 |
67 L6 no spark...
Truck has sat outside (and covered) for a couple months to include one solid week of below-freezing weather. I’ve checked and cleaned the points, checked the condenser using the analog meter technique - I haven’t checked the actual capacitance yet - the distributor cap and rotor looked rather worn on the contact points, so I’ve got those items ordered - should get them Monday.
Am I missing anything?
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense Last edited by jabborabbo; 03-20-2021 at 05:04 PM. |
03-20-2021, 10:14 PM | #2 |
Re: 67 L6 no spark...
hows the yellow wire from the starter to coil
03-20-2021, 10:37 PM | #3 |
I will suggest run a (real) copper penny.
Yes a penny Thru the points. This will clean the contacts. Try it . its a free This will put new copper on the points and let you know if it is just the points. Your going to replace them anyway .
03-21-2021, 12:33 AM | #4 |
From the coil its good - Ill check the starter end....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
03-21-2021, 12:34 AM | #5 |
Ill do that! Thanks!
03-21-2021, 07:21 PM | #6 |
Checked yellow wire (okay) and cleaned points with penny...then noticed the vacuum advance arm was out of its slot...I don’t know if that happened during my working on the dizzy or if some ice gremlins did it during the big freeze...anyhoo the truck cranks and runs (although it’s missing and coughing just a little bit - replacing points, condenser, dizzy cap and rotor should clear that up if I get everything adjusted right....
It’s back safe in the garage! I’m happy!
03-21-2021, 07:29 PM | #7 |
Tell us about the plugs... Gap? Color?
If they're the simple copper tip [not platinum or splitfires etc.] you can dress them with an ignition file, cleaning up any oxidation, and regap. .035'' for Points. A Dwell/Tach/Volt Meter is indispensible for tuning non-electronic ignitions.
03-21-2021, 08:41 PM | #8 | |
03-21-2021, 08:45 PM | #9 |
03-21-2021, 11:06 PM | #10 |
Ive seriously considered (and still am considering) buying an HEI dizzy, but Im a bit OCD regarding originality plus I enjoy tinkering.
03-22-2021, 06:52 AM | #11 |
Have you tested both the primary and secondary windings of the coil to confirm the coil is good?
03-22-2021, 09:13 AM | #12 |
With an ohmmeter, yes - coil is good.
