Old 03-24-2021, 06:30 PM   #1
saddletramp
72 c-20
Hey Guys Ive got a 72 C-20 stock 350 regular Exhaust no headers i bought a 3 row aluminum radiator last year i wasn't thinking clearly that day should have gotten a 4 row 180 thermostat its a daily Driver my temperature at times gets 190 ,195 in traffic regular engine fan how much coolness am i going to gain if i get a 4 row is it worth the money and time ?? Thanks Saddletramp
saddletramp is offline   Reply With Quote
Old 03-24-2021, 06:33 PM   #2
kwmech
Re: 72 c-20
That 3 row alum radiator should be plenty for a stock-ish 350. 190-195 is not hot. 220+ is hot
Get a clutch fan assembly if you are running just a flex solid fan
Assuming you have a shroud
Old 03-24-2021, 07:14 PM   #3
BigBird05
Re: 72 c-20
You didn't say what deg thermostat you are running.
BigBird05 is offline   Reply With Quote
Old 03-24-2021, 07:15 PM   #4
BigBird05
Re: 72 c-20
My bad I missed it the first time.
Old 03-24-2021, 07:28 PM   #5
saddletramp
Re: 72 c-20
Hi guys Thanks for the help whats a good brand clutch fan and where to get it ?? Thanks again Guys
Old 03-25-2021, 10:04 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 c-20
I agree, there is nothing wrong with your temperatures. I don't start worrying until mine reaches 210º.
LockDoc
Leon
Old 03-25-2021, 11:16 AM   #7
pjmoreland
pjmoreland's Avatar
Re: 72 c-20
Based on recommendations I found from searching the forum, I bought the following fan and clutch from Summit Racing.
DER-17118
https://www.summitracing.com/parts/DER-17118
HDA-2705
https://www.summitracing.com/parts/HDA-2705
I also bought a set of mounting studs from the Help! section at Napa. I think it was Dorman part number 23733.
pjmoreland is offline   Reply With Quote
Old 03-25-2021, 01:41 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 72 c-20
Hayden #2747 (got mine at NAPA) is an excellent heavy-duty clutch. Pair that with a 7-blade (6 blade will work too) 18" diameter fan. And as noted, a fan shroud.
Hayden's site clearly explains the differences between Standard, Heavy-duty, and Severe-duty clutches. https://www.haydenauto.com/en/produc...-types/thermal
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-25-2021, 03:41 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 72 c-20
As noted above, 190-195 is not hot. That said, if you find yourself shopping for a new radiator, a heavy-duty 2-row aluminum is probably a better choice than a 4-row.
Check this thread http://67-72chevytrucks.com/vboard/s...d.php?t=817699
- Mike -
RIP El Jay
Old 03-25-2021, 05:04 PM   #10
saddletramp
Re: 72 c-20
Thank you always good information appreciate you Guys Great site
Old 03-26-2021, 12:09 PM   #11
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 c-20
My C-20 has a 3 row full aluminium tig welded radiator with normal 5 blade Chevy fan and shroud. Make sure the air is going through the radiator and not around it. Block off all area's of air going around the radiator and force it through the radiator. You can see the foam that I put around mine to seal it off.
My C-20 runs a 195* thermastat and it does good. If you don't have AC there is no need for a clutch fan. The motor fan should work just fine. Don't ever use a flex fan though.
In fact mine runs a little cold in the winter time.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-26-2021, 07:39 PM   #12
BlazerBill
Re: 72 c-20
Oh there is my 69 OLDS air cleaner.��
BlazerBill is offline   Reply With Quote
Old 03-26-2021, 08:57 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 72 c-20
A clutch fan will take less HP, and provides a racing edge. Not much, just a little. True, not really necessary without A/C. It's like using the 2-1/2" FI Corvette alternator pulley. The difference is most noticeable on small engines, but another trick to use when drag racing. A little here, a little there.
I was having a problem with my truck running hot, a problem that this truck has had the entire time that my PiL owned it. I'm talking 260º pulling hills, and idling. I put in a severe duty clutch, and that helped, but the high-flow thermostat got put in after noticing (when replacing the stock radiator) that there wasn't a whole lot of flow. New water pump previously, etc. This truck has run hot for so long that my wife didn't even know/remember that it had A/C, because it never got used, especially when towing the travel trailer, back when her father was still alive.
~Steven
Simi Valley, CA
