Old 04-02-2021, 03:38 PM   #10
Davidf
Re: LS Swap: Introduction, newbie, planning...
Originally Posted by ls1nova71 View Post
Sounds like you've got it figured out. What I did was use an evaporator out of a square body to get rid of the POA valve. Also used the low pressure sensor out of one too because most of them are adjustable, so you can fine tune the system a bit. The newer switches are all fixed.
Yes, 87 evap should fit existing housing. But, didn’t you use a more modern evap out of a late model truck and modified the housing to make it fit?
Davidf is offline   Reply With Quote
