Upper radiator hose question
I'm putting a vortec motor out of a 97 tahoe in my 71, I'm using the factory serpentine system too. Has anyone found an upper radiator hose that goes up over the serpentine belt and connects to the radiator? I don't really want to use one of those aluminum flex hoses.
Thanks!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
Re: Upper radiator hose question
I’m running a serpentine system from a 92 K1500 in my 72, I think they are the same. Stock 72 upper hose with a buillet specialties swivel thermostat housing, to tweak the hose routing. 10 years and 40k with zero issues.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Mar 2003
When I had a small block in my 69 I had to use a double hose. I looked for quite awhile for a single hose that wouldn't hid the fan on the alt but didn't find one. I ran this for a short time
I’m finishing the install of the same. This is mine. I purchased an prebent tube and some nice silicone elbows.
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
laying low
![]() Join Date: Mar 2001
I don't have a serp belt setup but I did use a hose from a 73 to 87 pkup on mine since I used the latter long water pump accessories. It clears the AC compressor better.
Old member
This hose is for a dodge ram truck but I cut one end off and it fits perfectly. The one picture shows what I cut off.
May not be what your looking for but it sure is better than what I had on it before. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
