Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 04-04-2021, 01:05 PM   #951
57taskforce
All about them K’s
57taskforce's Avatar
Re: What did you do today not on your truck...
Finished up around 5
Nice, I’ve got my homemade file cabinet running as we speak, alternating oak and apple. The brisket will hopefully be done this evening. 10-12 hours total at about 200-220.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-04-2021, 01:45 PM   #952
Originally Posted by 1976gmc20 View Post
Huh! Maybe I can go ahead and side the pole barn. I figured T-111 must be $100/sheet now based on 1/2" ply and OSB.
I've got to build a new floor in the 12x16 addition where we tore out the old hot tub and rotten decking. The redwood was okay but all the joists were gone. What I salvaged is all short pieces. I already figured ply/osb and 2x6's are going to run about $700! Ply is only $4 more so to heck with OSB. I hadn't thought of putting T-111 upside down for a floor...
The floor I did will only be supporting things I stuff up there. No standing/walking on this floor.
I paid a bit more than $38. It seems it's only the framing materials they have spiked the prices on. Finish grade stuff isn't so effected by the BS.
You have to wonder what a prefab building would cost now.
I have been putting off re-siding my shop. It currently has 4x8 8"oc fir siding on it. I have been thinking of going with metal siding to put an end to painting. With these high lumber prices I imagine metal has gone up as well. So I don't know.
The metal hasn't been effected from what I've seen. I stripped the shake roof off one side of the barn and put new metal on about the time I went missing, and had to buy four pieces for this project.
Concrete form. Trying to make a better transition from stone to concrete and give a better path back to the shed side the barn is moving into
Old 04-04-2021, 02:39 PM   #953
Boog
laying low
Boog's Avatar
$38 per sheet for fir is about what it was here the last time I checked. I also looked at LP Smart Siding for a little less.
I noticed the lumber yard I used to manage inventory is way down and I asked if it was intentional and was told lumber is just hard to get. They have a number of outages regularly. And that is the way of the new owners among their other companies as well even before the covid.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-04-2021, 02:53 PM   #954
Boog
laying low
Boog's Avatar
In winterizing our camper for last winter I found the fresh water pump no longer worked so I kept it in mind and now it's time to de-winterize it so today I went looking for the pump. Lands sakes alive. They hid that thing. Luckily the pump still runs so I had to track it down by sound. It's in a small hole under the cookware in a cabinet no where near plumbing fixtures. On top of that when installed they ran the four mounting screws down into the rubber mount so far the rubber closed up nearly covering the screws enough I could not get a socket on them for removal. I ended up using a dremmel tool with snake attachment and small cut off disk to cut away the rubber around those screws. It will be reinstalled better than that.
Boog
primer is finer
Old 04-04-2021, 04:51 PM   #955
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
Yeah,, mine is under the counter top behind two drawers ,,and the divider between the two drawers does not allow enough room for my shoulders to easily get in there to repair the part that froze on me,.. so I had my brother do it for me he's smaller than I am.
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 04-04-2021, 05:34 PM   #956
Boog
laying low
Boog's Avatar
You may get an idea how small an area it is to work in. I cannot get my head and hands in there at the same time.
Boog
primer is finer
Old 04-04-2021, 06:18 PM   #957
1976gmc20
They build those things from the inside out, and apparently don't care if you can ever fix or replace anything
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 04-04-2021, 06:26 PM   #958
1976gmc20
This will be a real room of some sort - which is why we finally got the hot tub cut out of there: it was almost totally wasted space because we couldn't get the parts to fix it. Probably a summer bedroom for the grandkids or something? It's just weird because the floor will have to be structurally separate from the walls. It's tempting to have a couple steps down and make the concrete slab be most of the floor ....
T-111 was about $35 a couple years ago when I was checking into it. I would need 27 sheets to go around three sides of the pole barn plus a few more for the part that's taller than eight feet.
Old 04-04-2021, 08:01 PM   #959
72c20customcamper
72c20customcamper's Avatar
My smoker I built to it's on a trailer so I can move it around . I've been using higher temps lately 275° +/- seems to be working out well .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-04-2021, 09:33 PM   #960
67C10Step
67C10Step's Avatar
Washed the 4Runner and Impala. Cleaned up my shop some and finished up closing in the last end wall over a roll up door with thin tongue and groove. Cut wood for framing bathroom mirrors. I did the first one a few weeks ago.
Hope to get back to the truck next weekend.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 04-04-2021, 10:44 PM   #961
57taskforce
All about them K’s
Looks like yours does a great job! My brisket came out perfect... 11 hours and it fell apart but was still really moist... nice smoke ring and bark.
Tyler
Old 04-04-2021, 11:10 PM   #962
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by 1slo64 View Post
Installed a woodgrain steering wheel in the 66 mustang I'm working on. Much better than the stock one, think I'm going to have to get another for my bronco.
No kidding, that looks sharp and compliments the interior.
And nice piece of meat Taskforce. Now I'm hungry again.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-05-2021, 08:24 AM   #963
72c20customcamper
Looks great .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-05-2021, 10:46 AM   #964
Boog
laying low
Boog's Avatar
Oh man. That looks good.
I went to Chili's last week and saw they had brisket on the menu so I ordered it. What a disappointment.. It was a stringy pot roast lookin very small portion laid on a thick garlic pasted slice of toast. I'm afraid they don't know what good brisket is supposed to be like. I won't order that again.
Boog
primer is finer
Old 04-05-2021, 02:08 PM   #965
Steeveedee
Who Changed This?
Steeveedee's Avatar
Grilled T-Bone (no, not that guy!) steaks for dinner. CostCo was out of lamb, which was our first choice. Well, they had the ribs, but all that fat and bone for that kind of money is out of the question.
~Steven
Simi Valley, CA
Old 04-05-2021, 03:09 PM   #966
57taskforce
All about them K’s
Yea it was really good, my wife is about 4 months pregnant... she texted me from work and said that baby has been dreaming about brisket all day long. Her and baby got there fill on leftovers at lunch. That made me laugh for some reason. I’m really picky about buying “bbq” of any kind from restaurants. Seems a lot of times there definition of smoked meat, and mine are not anywhere near in the same dictionary.
Tyler
Old 04-05-2021, 03:19 PM   #967
Boog
laying low
Boog's Avatar
I only go there because the wife likes it. Baby back ribs are all I care for there but I thought I would at least try the brisket. I asked for corn on the cobb without garlic too. Guess what, stinking garlic butter all over it. Much to my displeasure most restaurants these days think they have to cover everything in garlic butter. I absolutely hate garlic! The smell makes me sick. Some folks love it. Even Sonic has a garlic butter burger now. errrrrrrrr !
Boog
primer is finer
Old 04-05-2021, 03:25 PM   #968
67C10Step
67C10Step's Avatar
Jim - If you ever find yourself in Pine Bluff try out Simplee's BBQ. They make a sandwich called the East 49th Street sandwich that is sliced brisket on a bun with provolone cheese, and onion ring, with bread and butter pickles. I treat myself to that when I have to be there.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-05-2021, 04:10 PM   #969
1976gmc20
My 1965 C10 came with a bumper sticker (actually it was in the rear window) that said:
Eat More Lamb
50,000 Coyotes Can't Be Wrong
It was still there when I sold it
Old 04-05-2021, 04:13 PM   #970
Steeveedee
Who Changed This?
Steeveedee's Avatar
Eat More Lamb
Easy to spot the cattlemen!
~Steven
Simi Valley, CA
Old 04-05-2021, 04:49 PM   #971
LockDoc
The Older Generation
LockDoc's Avatar
I finally started removing the barn boards from the outside of the barn. I am going to work on the ends in the next couple of days. There was an old Vacuum milking machine up on a shelf so I got the skid loader out and was able to get it out from outside the building.
LockDoc
Leon
Old 04-05-2021, 06:49 PM   #972
Low Elco
Did you ever get it pulled back straight, Leon? Glad you and Momma are doing well, Can't wait to see you all again! Carrie says she has the park reserved for this year!
Low Elco is offline   Reply With Quote
Old 04-05-2021, 07:00 PM   #973
LockDoc
LockDoc's Avatar
No saving this one Chip. All of the main support posts were broken.
We are doing good.
Yep, really looking forward to the All Truck Nationals in September...
As Fats would say... "Goin' To, Kansas City, Kansas City Here I come"..
LockDoc
Leon
Old 04-06-2021, 05:24 AM   #974
It's so sad that barn got destroyed by a freak storm. Just plain bad luck. You've got quite a project ahead. Not that it hasn't been already. I wish I was near enough to come help
Old 04-06-2021, 07:56 AM   #975
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Congrats on another one on the way. We just had our 6th a month ago. I agree, once you are around people that cook really, really good BBQ, it's hard to eat at restaurants you haven't ate it at before. I love a good brisket, burnt ends, shoot, it all!
Ryan
1969 Chevy milk truck
