Old 07-08-2020, 05:12 PM   #1
jimbosprint
jimbosprint's Avatar
Lightbulb Winch behind front bumper
I liked the idea of mounting a winch inside the frame behind the front bumper as I have seen some other people do to their trucks. My truck is a '72 K10, and I bought a Smittybilt X20 10000lb winch.
My first couple cardboard prototypes were poor designs that mounted to the bottom of the frame rail. My third prototype (which I ended up building) was the simplest design and mounts to the top of the frame rail. This allowed the winch to hang upside down and be mounted as high up as possible. It also allows the fairlead to come out of the middle of the bumper instead of the bottom. I just had to clock the clutch housing so that the handle was pointing forward instead of down.
jimbosprint is offline   Reply With Quote
Old 07-08-2020, 05:13 PM   #2
jimbosprint
Re: Winch behind front bumper
Since I'm a graphic designer, I used Adobe Illustrator to design the pieces of the bracket. The bracket is made of two parts because it would be too long to install inside the frame otherwise. I was able to see on the computer that it was going to fit. A friend cut the parts out on a laser at his work, and the shop that did my front axle work welded the bracket for me.
Old 07-08-2020, 05:14 PM   #3
jimbosprint
I had to move the radiator out of the way to drill two of the holes down through the core support and the top of the frame. I attached one bolt, then used a floor jack and c-clamp to hold the bracket in place to drill the other mounting holes through the frame and bracket.
Old 07-08-2020, 05:15 PM   #4
jimbosprint
I sandblasted it and painted it with satin black paint + primer.
Old 07-08-2020, 05:16 PM   #5
jimbosprint
This morning I installed and wired the winch. It was way too heavy for me to hold and put the bolts in so I got creative with a couple floor jacks. I mounted the control box where it is easy to get to on the grill center support. The controller is wired or wireless, which is a nice feature.
Old 07-08-2020, 05:17 PM   #6
jimbosprint
The winch has a synthetic rope instead of a cable, so it doesn't need big roller fairleads. I plan to get some plate bumpers made with a fairlead hole instead of cutting the flimsy reproduction bumper that is on the truck now. Total cost for material, cutting, welding, bolts, and paint was about $175.
Old 07-09-2020, 02:41 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
That’s a nice setup! Looks really clean. Any plans to sell the winch mounts in the future? I bet there’s a few around who might be interested. You’d have to pony up on your paid membership but might be a good side hustle.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 07-09-2020, 04:46 PM   #8
Yukon Jack
Yukon Jack's Avatar
Very nice!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-09-2020, 05:55 PM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks very clean. Nice job!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-10-2020, 01:31 AM   #10
jimbosprint
Thanks guys. I don't want to sell it. If anyone wants the part drawing just send me a PM.
Old 07-15-2020, 02:46 PM   #11
jimbosprint
I found a $15 bumper in town, so why wouldn't I cut a hole in it and put it on this truck?
This also gave me a chance to get a good photo of the mounting bracket.
Old 07-15-2020, 03:34 PM   #12
Ol Blue K20
Looks great.
Dale
Old 07-16-2020, 04:02 PM   #13
jimbosprint
I used some junk sockets to space the license plate away from the fairlead. There are wing nuts on the back so it is easy to flip out of the way. The winch is really hidden now.
Old 07-16-2020, 06:19 PM   #14
Ol Blue K20
Nice, I put a flip up on mine too. Perfectly legal to keep the law dogs away.
Dale
Old 07-16-2020, 06:33 PM   #15
Greasey Harley
Greasey Harley's Avatar
I like that, a lot. Well done.
Greasey Harley is offline   Reply With Quote
Old 07-18-2020, 12:07 PM   #16
dennislbrooks
dennislbrooks's Avatar
I agree, nice job.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-22-2020, 10:55 AM   #17
jaros44sr
jaros44sr's Avatar
I like it, can I buy some drawings form you? do you run tow hooks, just curious if they still mount up. great work and thanks for sharing
we dont use no stinking front plate in pa.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-22-2020, 11:47 AM   #18
Ol Blue K20
No front plate in CA is asking to be harassed by the police......
Dale
Old 08-31-2020, 11:14 AM   #19
60sIron
60sIron's Avatar
Fantastic! Strong work right there.....
60sIron is offline   Reply With Quote
Old 02-06-2021, 12:33 PM   #20
jimbosprint
I added some shackle recovery points where the factory tow hooks bolt on. No interference with the winch bracket.
I'm still thinking about how to make a skid plate to protect the winch, but until then I slapped a cheap waterproof winch cover on it.
Old 02-06-2021, 01:20 PM   #21
Ol Blue K20
Shackle mounts look good. Great idea
Dale
Old 02-06-2021, 09:47 PM   #22
memo43
memo43's Avatar
I really like the clean concept an simple approach.
My son an I have been looking at different Ideas as far as mounting a winch
He just bought an 86k20 as his first rig, and I am teaching him as we go.
He just turned 17 an really enjoys wrenching on his truck.
Memo
Memo S.
Retired US Marine
Family Man
memo43 is offline   Reply With Quote
Old 02-14-2021, 07:19 AM   #23
doubleclucker
doubleclucker's Avatar
Very Nice !
100:1 low gear!
doubleclucker is offline   Reply With Quote
Old 02-14-2021, 06:36 PM   #24
ljbear
ljbear's Avatar
Look into a Factor 55 Flatlink, pulls tight against the fairlead so none of your rope is exposed, and uses the shackles you have instead of a hook
https://factor55.com/product/flatlink/
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 04-13-2021, 11:04 PM   #25
sunnstone
Impressive work on your setup. The winch looks really sturdy. I might consider installing the same winch soon. I've been using Smittybilt products, but mostly as an accessory like nerf bars and cargo rack.
sunnstone is offline   Reply With Quote
