04-21-2021, 05:46 PM | #26 |
Re: “Castro” my new 72 build
Mike glad to see you back. Your '72 was probably my favorite truck on here and I was really sad to see it destroyed. Will you be at C10's in the park this fall? I got tickets last year and they said they'd honor them this year after it was cancelled so we're planning on being there.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
04-21-2021, 08:58 PM | #27 | |
On the road
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
04-21-2021, 09:25 PM | #28 |
That's a sad picture. I remember the story of the wreck. Your new build looks like it will turn out pretty cool. You're off to a good start.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
04-21-2021, 10:53 PM | #29 |
On the road
Yeah it was sad. It happened in Nacogdoches not far from you. The truck did turn out good, I'm playing catch up posting the build, the truck is actually finished
04-22-2021, 06:45 AM | #30 |
Got to give you props for not beating Castro to death in the street...
04-22-2021, 09:07 AM | #31 |
On the road
Brother believe me when I say it was all I could do from doing that very thing.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 04-22-2021 at 09:40 AM. |
04-22-2021, 09:08 AM | #32 |
Proprietor of Dale's Corner
Signing in to watch! Sorry about the blue truck.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-22-2021, 10:28 AM | #33 |
Mr. Cheyenne
sad story on your blue truck, I hope you where not hurt! Seems at the speed you were going you could have been knocked around a bit (even in a modern car/truck).
I am jealous of your shop and all that room you have! My cookie cutter house I can barely park my truck in and close the door (long beds take space!). Though I guess I could be worse off an not have a garage at all LOL!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-22-2021, 10:39 AM | #34 |
On the road
Thanks I appreciate that
04-22-2021, 10:41 AM | #35 | |
On the road
04-22-2021, 10:46 AM | #36 |
On the road
On to assembly, New stuff starting to go on with all new hardware
04-22-2021, 10:48 AM | #37 |
On the road
More Progress, this QA 1 kit takes square body spindles. Too bad because at the time I had 2 sets of ECE drop spindles for a 67- 72. 72-disc brakes have the thick rotors, so I bought McGaughys square body drop spindles for the thicker rotors. Looking back now I wished I would have bought CPP modular spindles, so I could put big brakes on later if I wanted to and not have to replace the spindles.
04-22-2021, 10:51 AM | #38 |
On the road
Progress
04-22-2021, 10:53 AM | #39 |
On the road
More progress, the rear end is installed. This is a fresh 3.73 with an Eaton posi and I have a Denny’s drive shaft. I only had about a thousand miles on it when I had the wreck. I long hauled HRPT with a 3.08 and no GV OD which I installed afterwards. I still have the complete 3.08 rear end and drive shaft if I ever need or want to swap it back in.
04-22-2021, 10:55 AM | #40 |
On the road
It rolls
04-22-2021, 10:57 AM | #41 |
On the road
Getting the plumbing and wiring installed.
04-22-2021, 10:58 AM | #42 |
On the road
Engine and trans installed
04-22-2021, 11:00 AM | #43 |
On the road
Here are a couple of pics of the emergency cable clamps which you have to buy separately.
04-22-2021, 11:03 AM | #44 |
On the road
I reworked the exhaust to make it look better. It’s hard to get this job right laying on your back as when I first built it. It’s easy to get it all lined up straight with no body in the way. It’s a 3” system with Walker Ultra Flows. I cut it apart where needed, rewelded and repainted.
04-22-2021, 11:05 AM | #45 |
On the road
Almost ready for the body
04-22-2021, 11:06 AM | #46 |
On the road
I was able to reuse the cab mounts off the blue truck, they still looked like new, but I had to buy a new set for the core support.
04-22-2021, 11:08 AM | #47 |
You are making great progress which you are going to have a beautiful truck!! Keep up the great work and thanks for sharing your truck! I wish mine was that far. Do you have any extra parts to sell? Thanks
Posted via Mobile Device |
04-22-2021, 11:09 AM | #48 |
On the road
Finished up the exhaust, it’s as good as it's going to get.
04-22-2021, 11:12 AM | #49 |
On the road
I’m using a Dakota Digital dash and wanted to install cruise hooked into the GPS. Here’s where I mounted a late 90’s OBS cruise module. I also have a wide band and incorporated it into the DD dash, you can see the sensor below, later on I moved the sensor to the header, But no photos. More to come.
04-22-2021, 11:21 AM | #50 |
On the road
Thanks bro, no most parts have been used or sold already. What are you looking for?
