heater hose query
I am installing an Old Air underdash heater/air con unit. It came with a tap that has a by-pass inbuilt. Since I am using the original de-frost leaver and cable to operate the tap it is inside the cab behind the dash. I am a little worried that when I turn the heater off there may be too much heat radiated off the heater hoses with hot water circulating thru them. One hose runs thru the upper Rh side of the firewall above the kick panel and the other side thru the top of the Lh floor, so about 1.8m of hosing. If I could get some feedback from someone who has a similar setup I would appreciate it.
TIA |
It's Better With Nitro
Re: heater hose query
Are you worried about heat exchanging in the cab? I run a Vintage Air system and here is a photo of how my hoses are routed. I do not have any issues with extra heat in the cab from the hoses to and from the evaporator.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Yes, I was concerned about heat in the cab off the bypass hoses. Thanks for sharing.
![]() ![]() ![]() Join Date: Jan 2018
Maybe use some heat wrap when installing it? You'll probably get some heat, but nothing like what gets put out when it's flowing through the heater core
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
vin63. It seems you have an external tap with no bypass hoses. My tap is inside the cabin with hoses that have hot water passing thru them constantly, but bypassing the heater when the tap is turned off..
