04-25-2021, 08:02 PM | #1 |
Re: My 1970 GMC Project
Really nice progress! Your mods are well thought out
71 C10 72 K20 72 K10 Super Kirk |
04-25-2021, 08:22 PM | #2 |
Thank you. I have been on this forum for quite a while and I'm sure that most of my ideas come from something I've seen somewhere else on here. I appreciate the compliments.
04-27-2021, 12:32 AM | #3 |
Well it appears I've made a mistake with the drivers side cab corner. I hung the door tonight to check the gaps and they are all about perfect except for at the cab corner. I also noticed that my rocker line takes a dive as it nears the cab corner so it looks like I'll be doing some more slice and dice. Oh well such is life at least I am finding it now before I get to much filler in the area.
04-28-2021, 12:08 AM | #4 |
Project Splice strikes again! I should really change my thread name but I don't know how to do it. I got the door gap corrected tonight by cutting in another, yup you guessed it, SPLICE. Once I had that corrected, I moved onto the rocker issue that was bothering me. What had happened is, the cab corner was to flat at the bottom where it meets the rocker. Once I figured that out, all I had to do was.... another splice! I think it is looking much better now.
04-29-2021, 12:17 AM | #5 |
Couple steps closer tonight. I got the splice welded up and started fitting the bottom of the door to the rocker. I decided my easiest route was to weld a stiff wire to the edge so that the edge will not be as much filler which would chip out easier. I feel like getting nicer panels might have been worth it at this point but I've got too much time invested in these to scrap them now. I'm determined to make these work!
04-29-2021, 11:16 AM | #6 |
I feel your pain. I installed my lower door rockers on my 66 C10, got them looking good BUT never test fit the damn door..... well i am now needing to lower the one side 1/4", so dumb of me.
I do have re-pop doors and found that one needs a little weld rod added to the outside edge to make the gaps much better.
John 3:16 - Saved me... God Bless |
04-29-2021, 12:02 PM | #7 | |
