#276 | |
Re: My 66 Service Truck Build Thread
Dana 60 with Truck Arm mounts. I'm jealous. I have the Eaton in my 65 C20 you can't do anything with.
65 C20 292 4spd 4:56 Eaton HO52 |
#277 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I think the Eaton I had in it before was 4:56
#278 |
Rebuilt my first carburetor a couple weeks ago.
The one on my 66 acted weird. The truck would backfire when I hit the gas, it would also bog. Put the rebuilt one on it today. Man does it run nice.
#279 |
Any idea the width difference between the two?
#280 |
I'll guess 3/4 inch wider each side for the 14-bolt. 1-1/2" total.
That's what I think I've read. You might find an answer in one of these two threads: http://67-72chevytrucks.com/vboard/s...d.php?t=550878 http://67-72chevytrucks.com/vboard/s...highlight=Bolt
#281 |
Installed a barden bumper and mocked up the tailgate.
#282 |
Been having trouble with it running rough and backfiring when I rev it up.
Idles really nice though. I've swapped out the distributor, I've checked the timing, and I've swapped the carb to the fitech from my 65, and still acts exactly the same. . Next I'm going to check if the timing chain hasn't skipped a tooth.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 04-01-2021 at 09:20 PM. |
#283 |
![]() ![]() ![]() Join Date: Jan 2018
You've probably already checked, but I did a stupid thing twice on my truck. First time was when I first changed the plug wires. I had two wire right next to each other on the cap switched. Idled fine but couldn't drive it over 1500 rpm because of it backfiring a ton. Second time that happend was after the engine swap and putting an HEI dizzy in. Swapped two plug wires again and had a heck of a time figuring it out because I was certain that I had wired it correctly
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#284 | |
#285 |
Moved it into our other barn.
I'm going to tinker on the motor some more and see if I can get it to run nice. It's no fun reaching over to access the motor. Maybe I'll build some scaffolding around the front ![]() I don't mind on my 65 because it's a lot lower.
#286 |
Okay, digging in to this backfiring again. I want to sell it or trade it for an old StarCraft boat.
Taking it back down to my house today and will pull off the front clip so I can get access to everything and step through everything again. Not even going to bother with the carb at this time. The Edelbrock runs great on my 65. I even tried my fitech. I've switched distributors. Still the same issue. I'll start with cranking it up to TDC on the compression stroke and see where the distributor points to. Then probably pull the timing cover to make sure it hasn't skipped a tooth. After that, I'll pull the valve covers and make sure all the valves fully open and close.
#287 |
Engine is still a clean engine.
#288 |
Always good to see no sludge when you open one up
#289 |
The 60-66 GMC/Pontiac guy....
Weak valve springs can cause backfire
Just sayin'
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#290 |
Did a compression test. #6 is about 10 psi less than the others.
I squirt some oil in there and it's still the same. Sounds to me like a valve issue with #6. . I put all new plugs and wires on as my last check for the back fire issue. But it makes no sense to dump money into gm Goodwrench heads, so I'll either pull them and try some lapping or buy a nicer set.
#291 |
With the new plugs and wires it fired right up. Dialed in the timing and very smooth running. I revved it up to about 1500 and not an issue.
I'll probably check the compression again on #6 to see if running it for awhile changed anything. The motor had been sitting for awhile without running.
#292 |
Installed a Carter P4070 inline electric fuel pump as a primer pump.
I was looking for an electronic pump to prime my edelbrock 1406 carb so i wouldn't have to crank and crank just to fill the bowls before it would start. Turn it on just long enough to fill the bowls. Start the motor and turn it off. Works great.
#293 |
So the new plugs and wires fixed the backfire issue completely, yes?
Sounds like your starter is going to be happier too
#294 |
Yes, runs great now.
#295 |
Good deal! Glad you were able to figure it out
#296 |
#297 |
If any of you have been following this thread and my 65 thread, you'll know that I change directions a lot.
I have had my 65 back for I think 10 years now and I still haven't got all the upgrades I wanted to do to it done. So, my latest direction is to move my 65 cab and front clip over to this 66. The 66 already has power steering, power disc brakes, a 14 bolt, and a low mileage 350. The whole downside to the 66 is how bad of shape the cab was in. That is my goal for this weekend. I'll load up some pictures a little later.
#298 |
Got 65 my cab off my 62 frame and on to the 66 frame.
From this point forward I'll be posting in my 65 thread any further progress.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-18-2022 at 07:28 PM. |
