Random No Start?
Been having an issue for a few years now. It happens on and off.
I have a 1969 C20 with a 350 5.7l. I'm having an issue with the truck not starting somewhat randomly. Always seems to happen after I've been driving a bit and I'll stop at a store and when I come back it doesn't start. Doesn't happen after sitting over night or after working a full shift, just when I come back to it 20 mins later. When it doesn't start, there is nothing. Lights come on, music, voltage is good. It does nothing. No clicking no nothing. I have to jump start it to get it to start and then it will start after that again just fine until another random day. Troubleshooting has been hard because I can't get it to recreate the issue at home. I have replaced the battery, starter, alternator, negative battery cable and clamp, distributor, plugs, wires, ignition switch, neutral safety switch. I've tested and cleaned grounds and wiggled wires...idk what else to do other than replace the starter and battery again. Any ideas? Thank you! |
![]() Join Date: May 2004
Re: Random No Start?
I believe someone ran into same issue a few years back.....replaced everything as you did.....anyways, the purple wire that energizes the starter solenoid had a bad connection or small break in it....when the wire was hot, the resistance was greater, so it did not make contact and nothing....then when it was cool, resistance was low enough that contact was made. Instead of jumping it, try a remote starter instead or "Jump" the starter....
Other guys on here are much smarter than me...so I'm sure they got better ideas… ![]() Also, this would get more views in the "Engine" section or pickups sections, even tho it is a suburban..... |
That's a good idea! I'll do some more testing and see if I can find anything that looks worn. Thanks you again. And I didn't notice I posted in the wrong section. This forum isn't phone friendly. Thanks again!
![]() Join Date: Aug 2019
When I was having random starter issues I wired in a test light to the purple wire on the starter. The light was in the cab so I could see if the starter solenoid was going voltage. In my case it was so I replaced the starter. Haven't had anymore no crank issues since.
Me, too. Search "starter solenoid heat sink" and you will likely find advice to relocate the starter solenoid. I'm going to do it as soon as I can get all the pieces needed.
#6 | |
The Older Generation
Also try "starter solenoid heat soak". LockDoc
Since there's an almost identical thread, I just pasted my post from the other.
There are believers in the idea that hundreds of millions of GM vehicles used the same starters and wiring and they worked, which they did, and there are those who don't. Fix the underlying issue and the solenoid will work. Typically, the underlying issue is bad wiring and/or poor connections, or worn out (resistive) switches in the circuit. Of course, a bandaid solution is easier than troubleshooting so it's popular. Yes, it's a bit of a long path from the battery to the solenoid, but I've jumped solenoids with a 20G or smaller jumper, so it doesn't draw that much. Measure voltage to the block and to the battery from the S-terminal. |
