Old 05-28-2021, 08:24 AM   #2151
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: What did you do to your truck today.The 3rd chapter
My brother brought me a 72 C10 Cheyenne truck to go along with mine :-D
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 05-28-2021, 09:39 AM   #2152
maverickmk
maverickmk's Avatar
Swapped over to 5 lug axles, and new wheels & tires.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 05-30-2021, 09:09 PM   #2153
Bkndsdl
Finally got around to fabbing up some temporary linkage for the Saginaw swap.
-Mike from Alabama
Why do we park on a driveway, and drive on a parkway?
Jake - '67 Short Step
Dirty Dan - '80 Short Fleet
Bkndsdl is offline   Reply With Quote
Old 06-01-2021, 03:22 PM   #2154
OregonNed
OregonNed's Avatar
Getting the differential rebuilt tomorrow, and will hopefully have pics to post. Pinion bearing is definitely bad in it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-01-2021, 03:54 PM   #2155
Davidf
Dropped in an LS...
[IMG][/IMG]
Davidf is offline   Reply With Quote
Old 06-01-2021, 06:05 PM   #2156
body bolt
My fuel gauge wasn't reading correctly and using a decade box I isolated it to the dash side. Pulled the cluster and found a nut that wasn't quite tight on the sender side of the gauge. I removed the seat to do this and also fixed the seat adjuster wire that kept coming off.
body bolt is offline   Reply With Quote
Old 06-01-2021, 06:05 PM   #2157
72c20customcamper
72c20customcamper's Avatar
Finished up one side of the 68 Golden
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-01-2021, 07:23 PM   #2158
body bolt
What are you using? I need to do my hood.
Old 06-01-2021, 07:43 PM   #2159
72c20customcamper
After I peel off the crappy repaint started with 600 and water worked up to 1500 then buffed with ultra cut compound with a rotory buffer then went to a orbital with swirl remover . Polish then wax all with Maquiars .
As I said peel
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-03-2021, 01:00 AM   #2160
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Had my drive shafts and rear end inspected. All in great shape, though they did say the oil in my rear end looked like swamp mud but otherwise no issues to be found. So just needed a new gasket (I did have a very small leak) and filled with new oil!
That was my last major section of my truck to have looked at / worked on since I got her a little over a year ago. Next week, my plan is to drive her to East Texas for the Model A 2021 Texas Tour - my brother wants me to be a chase vehicle.
Anyways, it should be a nice leisurely 300 mile drive going the back way to Kilgore via US Hwy 79.
Richard
Old 06-03-2021, 01:31 AM   #2161
Accelo
Accelo's Avatar
Worked on transmission lines. I am not good at bending lines. I see that Davidf is using the factory truck lines. Great idea. However the lines are different diameters and not sure how one can get The new lines attached to the radiator. Are adapters available? Can you use the same year truck radiator?
Accelo is offline   Reply With Quote
Old 06-03-2021, 09:39 AM   #2162
Davidf
Yes, my plan is to use the donor truck lines. But, they still need a lot of work. Have to re-shape to clear the front crossmember. Then, my assumption is that I will need to cut off some portion of the front of the line and either flare to match my aluminum radiator, or make a section of new line and join to donor lines with compression fittings (don't need flare union as pressure is not that high). Time will tell.
Old 06-03-2021, 06:08 PM   #2163
Accelo
Accelo's Avatar
In my prior life I have installed compression fittings on a 10,000 psi system.
Old 06-03-2021, 11:50 PM   #2164
cab4word67
cab4word67's Avatar
Got the truck on the hoist today, box going on tomarrow, new 6" drop is installed and the flip kit/C notch has been done. Now I need to remanufacture the tilt hinges and reinstall the drivetrain. Would like to be done by end of month
cab4word67 is offline   Reply With Quote
Old 06-04-2021, 08:21 AM   #2165
67C10Step
67C10Step's Avatar
cab,
Wow! Interesting. Did you take the 4x4 in your avatar and make it 2wd? Love the blue.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-05-2021, 03:29 AM   #2166
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Had my 255/60 17 inch Bridgestones delivered, Fed Ex contractor left like this, that will be going on my truck probably next year. Now to save for the Torque Thrusts.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-06-2021, 07:40 PM   #2167
72c20customcamper
72 died on me today in the driveway. Starter must have a dead short tried jumping the solenoid with the tester starter button . Nothing and the button got hot quick. So I have a new one on the way as it was under warranty but I’m done with DBElectric . 3 in two years on 2 different vehicles. So I ordered a Powermaster mini .
I also tried one of the M/T wheels that came off the Tacoma on the 68 . Pain in the butt sanding them to this finish by hand ,may just sand with 400 and paint them black .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-06-2021, 08:43 PM   #2168
pjmoreland
pjmoreland's Avatar
I completed several small projects today, some of which have been on my to-do list for a long time:
Replaced the output seal on my recently rebuilt 700R4. Either I damaged it or it was defective. Went with a GM seal this time.
Made a mirror image tailpipe hanger bracket for a full length exhaust system I'm planning on getting. Also installed stock hangers on both sides of the chassis in the middle of the truck
Installed a replacement hood hinge I painted yesterday. The original Hinge was bent sideways enough that the open limit stop no longer worked.
Painted and installed a set of shorty 5/16 body screws in the left inner fender brace. These screws are hard to find.
pjmoreland is online now   Reply With Quote
Old 06-06-2021, 08:58 PM   #2169
cab4word67
cab4word67's Avatar
Originally Posted by 67C10Step View Post
cab,
Thanks, no the Avitar is same truck 2 wheel drive with 5"custom lift, 3" body lift and 1 ton ft coils, ran 5" blocks in back with leafs. Ran this way 38 years. The lift started with 15 x38 ground hogs then went to Cepek FunCountrys 17x 40x 15s, ran 3 sets and last the 16x36x15s . now going down to the ground
Also there is 3 coats of purple pearl on top of that blue.
Old 06-09-2021, 03:00 PM   #2170
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Got tint and clear windshield over with tint visor!
Now I’m all set for the Texas sun and my trip up to East Texas!
Richard
Old 06-09-2021, 03:21 PM   #2171
ChevyGuyNC
ChevyGuyNC's Avatar
Washed, Clay bar, compound, polished.
Damn, she looks good! I love this truck!
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 06-09-2021, 03:24 PM   #2172
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Jealous, I'd love to have that color and yours being "Super" - it's the only one that I like (love) better than mine.
What's that other badge on your cow! Makes me wonder, what am I missing LOL
Richard
Old 06-09-2021, 03:28 PM   #2173
ChevyGuyNC
ChevyGuyNC's Avatar
What's that other badge on your cowl? Makes me wonder, what am I missing LOL
It's a dealer sticker, on both sides.
Allen Cook Chevrolet Buick. They went out of business in the late 80's. Found out they did ambulance conversions for a few years in the 60's.
Old 06-09-2021, 04:24 PM   #2174
ChevyGuyNC
ChevyGuyNC's Avatar
From Manes, I got Sport Mirrors and a new hi-beam foot switch. My foot switch was a little dodgy and sometimes I had to give it a extra tap when going to hi-beams. My Sport Mirrors, the mirror part looked darn brand new but the arms were badly pitted. No more pits! Also, now I can actually adjust them without thinking I'm going to break them off my door (they really didn't want to move).
So... today while cleaning the truck, my passenger sport mirror popped off the arm and landed on the concrete...
i remembered this post and gave Manes a call for my right hand mirror. She had one left, pulled it for me and will get it out by tomorrow. Have to love a place that answers the phone, and runs back to check stock. Very happy to give them my business. And now, like you Rich, I'll have a mirror I can adjust without thinking I'm gonna break it!
Old 06-09-2021, 04:24 PM   #2175
v8truckin
C-Notch, 2” blocks, POL brake conversion, 2.5” drop spindles, tie rod & ball joint replacement. Just a 2 day project this past wknd…boy was it a butt kicker!
v8truckin is offline   Reply With Quote
