#3 | |
Re: Bed/body alignment issues
I did some inspection and rust is not the cause of the misalignment. There is some rust in the front seat area near the rocker panels, but everything that supports the front corners of the bed is in good shape. I might have an easier time bringing mine into alignment because the rocker boxes have been cut out. I hadn't considered possible paint cracking issues. Where might cracks show up? If they do show up it will kind of suck, but it was last painted in 1988 and I have several common spots around the Jimmy to fix (door sills, rocker panels, front corners of bed...) that will require removing the paint anyway. I'm planning on making a plate out of 1/4" steel or some thick steel box to pickup on all the bolts.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
