Old 06-21-2021, 10:46 AM   #51
88Stanger
88Stanger's Avatar
Re: Performance Lacking in a 383 Build.
Well damn, sorry for the issues you have had.
I have a 383 stroker i am going to run, with Edelbrook aluminum heads (same or close to the same as you), full roller Howards Cam, Lifters and Rockers but the cam is not an RV grind i called and got a cam grind built for the 383, Muncie 4-Speed and 3:42 posi rear.
I am interested to hear what the engine builder has to say. I built my engine, but had the machine work done a respectable outfit in town and then me and my anal build mind took a week of measuring, testing, and such to build it. I fortunately have alot of the tools to test the fitments, not saying i know what i am doing, only saying that if it is bad or not right, i can only blame myself.
I wish you all the luck possible and look forward to your excitement of how "Snapping" the torque monster has!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-21-2021, 10:12 PM   #52
Ptjsk
Originally Posted by '68OrangeSunshine View Post
Is this in a Blazer [K/5] type truck? Even though GMC called them K/1500, not ''K/750''.
Or are you using Jimmy as a nickname for a GMC pickup?
4.56:1 is unusually low for a rearend on a light 1st gen suv. Most are 3.73:1 or even 3.07:1 in a half ton.
If you're talking about a 3/4 ton GMC, never mind. But 4.56:1 on a half ton Blazer is real low. And you'd do better with higher gears, like 3.73.
No, it's actually a Jimmy. It's GMC's version of the Chevy Blazer.
I placed the 410 gears in it when I restored the vehicle last year.
I'm running 33's on them, and I did install a gear vendor overdrive unit.
Pat
Ptjsk is offline   Reply With Quote
Old 06-21-2021, 10:14 PM   #53
Ptjsk
I'm hoping for information tomorrow! I'm curious to see if additional machining is going to be necessary.
Pat
Old 06-21-2021, 10:26 PM   #54
'68OrangeSunshine
'68OrangeSunshine's Avatar
Pat
OK, I get it. I thought the gearing sounded low, but with a GV/OD it makes more sense. With 4.10s your focus is off road, and a personal choice.
With three broken piston rods we know why you had no power. You were actually running a pumped-up 5 cylinder.
Better luck on your rebuild.
My '71 Jimmy is a 350/SM465/NP205/12Bolt-3.73Posi/ 33x12.50x15.
Yours is pretty.
Old 06-22-2021, 10:48 AM   #55
72c20customcamper
72c20customcamper's Avatar
Seems that more than one company is or had problems with their pistons TRW paid for the rebuild for my 66. Mine was catastrophic though 3 others had cracks around the wrist pins.
Absolutely no noise prior to damage
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-22-2021, 11:53 AM   #56
jjzepplin
jjzepplin's Avatar
Well that stinks man! I always use good Forged pistons in my rebuilds.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-24-2021, 05:45 PM   #57
Ptjsk
Well...motor needs to be bored .040 to clean up the cylinder walls.
Ordered forged SRP pistons and all new bearings. Hopefully it will run like it was supposed to when it's back together.
Old 06-24-2021, 06:03 PM   #58
jjzepplin
jjzepplin's Avatar
Sounds like a good start.
Old 06-24-2021, 08:52 PM   #59
Steeveedee
Who Changed This?
Steeveedee's Avatar
.040 over what was already bored? Do you trust your machine shop? Was it a stock bore when it was stroked? I'd hate to see you throw more money down the toilet.
~Steven
Simi Valley, CA
Old 06-24-2021, 09:14 PM   #60
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm sure that .040 includes the previous bore.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-24-2021, 10:43 PM   #61
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That's what I took it to mean also.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-24-2021, 11:41 PM   #62
Ptjsk
Yea, I should have stated that it's going to go to .040 over from stock, as it was already .030 over and he just wasn't able to save it.
This mechanic is actually very dependable, highly desirable, and very hard to get an engine in line.
Fortunately, I had an inside line.
Pat
Old 06-24-2021, 11:45 PM   #63
Ptjsk
Yours is pretty.
Thanks for the comments.
Probably highly unlikely it will see much off road use, I just want to be able to pull a car trailer, or a camp trailer periodically.
Thanks for the better luck wishes. I'm hoping for far better luck too!
Pat
Old 06-24-2021, 11:46 PM   #64
Ptjsk
Wow, that's crazy! Sorry you had to go through similar issues too!
Pat
Old 06-24-2021, 11:48 PM   #65
Ptjsk
Thanks Guys!
