Old 06-25-2021, 10:50 AM   #151
CMGreen8812
Re: 1972 Chevy Crew Cab “Denali”
The amount of work and skill shown in this build is beyond impressive! Can't wait to see where this goes.
CMGreen8812 is offline   Reply With Quote
Old 06-25-2021, 04:50 PM   #152
ShortbedClayton
Thank you! Good feeling seeing others appreciate the amount of work so far…. Hoping to keep making solid progress this year..
ShortbedClayton is offline   Reply With Quote
Old 06-25-2021, 05:35 PM   #153
bcfishon
Wow !! That's nice.
bcfishon is offline   Reply With Quote
Old 06-30-2021, 07:12 AM   #154
ShortbedClayton
Got all three outer door bottoms done this week! Aftermarket stuff doesn’t fit the best had to do some modifying but overall I’m happy with the turn out.. only welded maybe 1.5” overall on the skin the rest was attached with 3M panel bond… didn’t want all the heat warpage. Those Amazon cleko fasteners are a mans best friend when doing this stuff.. we now have 4 rust free doors ready for body work…
Old 06-30-2021, 08:45 AM   #155
jjzepplin
jjzepplin's Avatar
What are these mysterious fasteners you speak of?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is online now   Reply With Quote
Old 06-30-2021, 08:51 AM   #156
ShortbedClayton
Cleko fasteners.. spring loaded clamp that you drill a hole they both panels to be bonded and insert the clip. When you relieve pressure off the tool it clamps together with spring pressure if it makes sense.. it’s basically clamps the two pieces together simply by drilling a 1/8” hole and inserting the fastener.
Old 07-05-2021, 09:12 PM   #157
ShortbedClayton
Took advantage of the 3 day weekend and tackled the bottom of the cab. My goal was to keep this looking as factory as possible. Started by setting cab vertical. Scraped off all the old undercoating and wire wheeled the entire bottom. Shot some epoxy primer on there. Seam sealed all the joints I could and sprayed the bottom with two heavy coats of “spectrum” sound deadener and moisture barrier.. came out way better than I expected… gotta let it set if 7-10 days then I’m gonna put a coat of flat black on there just to make cleaning easier when it’s on the road! Huge shout out to harbor freight for the cheap redneck paint booth. Mainly wanted to keep the undercoating stuff off everything else in garage.. hope everyone had a great Independence Day… 🇺🇸
Old 07-06-2021, 04:48 AM   #158
ShortbedClayton
Close up of the texture. Close to factory undercoating look
Old 07-07-2021, 06:02 PM   #159
May70
May70's Avatar
Any particular reason you used the spectrum stuff vs the upol equivalent? Ive seen a lot of the upol applications and they look very good.
Also did you stop the undercoating at the forward floorplan/firewall seam?
Looks great!
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 07-07-2021, 07:26 PM   #160
ShortbedClayton
Looks great!
Thank you.This was the first stuff I came across. Reasonable priced, fast shipping and made in the USA…. I’m super happy with it thus far. And yes I stopped at the floor pan firewall crimp seam.
Old 07-12-2021, 01:07 PM   #161
ShortbedClayton
Put a coat of flat black on the bottom of the cab to finish it off.. fabricated up a nice little steel dolly for moving around the shop and stuff… got the cab set down on dolly and man she rolls around anywhere now… gonna be starting on the frame this week! Making solid progress now
Old 07-12-2021, 01:39 PM   #162
May70
May70's Avatar
How did you prep the undercoating? Red scotchbrite, blow off, then wax&grease it? I’d think if you tried to wipe the cleaner off it would leave a bunch of bits n pieces on the surface.
Did the flat black smooth it out much more?
Old 07-12-2021, 02:02 PM   #163
ShortbedClayton
Scraped all undercoating off. Wire wheeled to bare metal as best I could.. wiped down with wax and grease remover twice. Sprayed epoxy primer and then seam sealed… sprayed undercoating. The flat black was to make it black looked more gray to me. I put two light coats of black on as I didn’t want it smooth looking. The textured look was what I was after…
Old 07-12-2021, 02:16 PM   #164
May70
May70's Avatar
I mean when you sprayed the flat black over the new spectrum undercoating did you have to scuff the spectrum undercoating first for the flat black to stick?
It looks great man
Old 07-12-2021, 02:45 PM   #165
ShortbedClayton
It looks great man
No I didn’t scuff anything. I followed the directions on the product and it said after 7 days up to 10 days paint could be applied. Thanks
Old 07-14-2021, 07:14 AM   #166
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! That dolly will be handy after the cab is off it too.
Ryan
1969 Chevy milk truck
Old 08-04-2021, 09:44 AM   #167
ShortbedClayton
Been busy working on the frame. Tore down the old HO52. Cleaned the gears and housing. Installed all new bearings and races. New shoes spring kits and drums. Basically everything on the wheel end… welded up some unnecessary holes on the frame. Took to work and sandblasted! Primed and painted it up this past weekend. Starting to run the brake lines and fuel lines now… next goal is motor and trans and tcase..
Old 08-04-2021, 10:11 AM   #168
landarts
landarts
Please tell me about the bag system in the rear, looks like a great idea. Also very nice work on the Crew Cab Clayton. Trying to take in as much information as possible, hoping to kick off my crew cab build in October. Again outstanding work!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-04-2021, 03:24 PM   #169
ShortbedClayton
Just mounts to the frame and a removable bottom plate to allow access to u bolts. I plan to tow more 72s home with this rig so the air bags will help with the extra weight and squatting. Further up in my thread I show more pics of the bags and mounts. Thanks for the appreciation. Look forward to following along on your build.
Old 08-10-2021, 07:30 AM   #170
ShortbedClayton
Gotta love a freshly painted and functional Hickey sidewinder! Excited for this piece to be on this rig. Should be a conversation starter for sure!
Old 08-10-2021, 01:59 PM   #171
TA_C10
TA_C10's Avatar
Well now that's cool
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 08-12-2021, 07:40 AM   #172
Dieselwrencher
Nice work getting the chassis painted and back to a roller! That winch is sweet!
Ryan
Old 08-18-2021, 05:40 AM   #173
ShortbedClayton
Seperated the transfer case from the trans for this truck. Never been inside one of these before .. disassembled, cleaned and full rebuild kit installed! I like the look of grade 8 hardware! Rebuild went smoothly. Thanks YouTube! Next is transmission rebuild..
Old 08-18-2021, 06:08 AM   #174
Dieselwrencher
That looks really nice! I've got one or two I need to real and check out.
Ryan
Old 08-18-2021, 06:42 AM   #175
ShortbedClayton
Thanks! Yeah they aren’t too bad. If you just re gasket it and seals it’s a lot cheaper to rebuild. Even with all the bearings it wasn’t bad at all tho
