Old 04-08-2019, 10:18 PM   #1
Rooster73
fuel injection
has anyone had any experience the F. I .tech fuel injection systems,and the fuel command center? I see this brand advertised more than any. thanks.
Rooster73 is offline   Reply With Quote
Old 04-08-2019, 11:22 PM   #2
Fbks_Cruiser
Fbks_Cruiser's Avatar
Re: fuel injection
The search function in the banner is the best resource in this forum. Type in Fitech, hit the 67-72chevytrucks.com button and then the google button. You will find lots of great threads on this forum discussing it.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 04-09-2019, 06:50 AM   #3
Rooster73
Re: fuel injection
thanks, I'll get on it.
Old 04-09-2019, 09:44 AM   #4
Dumblucktruck
Re: fuel injection
I’ve had a FiTech system and the first generation FCC on my bone stock 350 in my 72, for about 2 years now.Works great, not exactly plug and play but even a novice can figure it out. Cold starts are incredible and drivability is remarkable.
Dumblucktruck is offline   Reply With Quote
Old 04-09-2019, 02:36 PM   #5
Ekliptix
Ekliptix's Avatar
Re: fuel injection
holley sniper is an alternative. Bigger name, possibly better support vs FI tech. I have the Holley sniper. No complaints.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 04-09-2019, 05:53 PM   #6
scampr
Re: fuel injection
Did they effect the millage much or stayed the same?
scampr is offline   Reply With Quote
Old 04-09-2019, 06:08 PM   #7
Ekliptix
Ekliptix's Avatar
Re: fuel injection
Didn't appear to change mine much (402). That's just from my impression. I didn't do a good job of before and after for mileage documenting.
Old 07-13-2021, 07:28 PM   #8
mikecaddy500
mikecaddy500's Avatar
Re: fuel injection
Any one know of a fuel injection system that will fit in the stock (in cab) tank?
mikecaddy500 is offline   Reply With Quote
Old 07-13-2021, 07:46 PM   #9
jimijam00
Re: fuel injection
Any of them will since you don't need to go do anything with the tank at all if you don't want to. There are several different "kits" to get fuel.
jimijam00 is offline   Reply With Quote
Old 07-13-2021, 10:10 PM   #10
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Re: fuel injection
I have friend who worked in a "shop" who installed a couple early fitech FI kits, said both were problematic. No idea of the "shops" skills or problem shooting techniques so took that info with a grain of salt, however as support of what Ekliptix indicated, typically small companies don't have the engineering or customer service horsepower to support their products completely.
I do have personal experience with installation of a Holley Sniper EFI kit and have to say it was absolutely the best thing I have done to my truck from a drivability standpoint. Had numerous carbs on the truck with very poor results. The start and idle quality of the sniper is great, mileage went up from 13-14mpg to 18mpg as checked on a 2k+ mile trip. Another sniper is on my list of items for my 67 Nova build.
Whichever system you choose, do a bunch of research, have a plan, take your time, read the instructions about 20 times, and don't short cut steps or it'll likely cause you grief.
towbar is offline   Reply With Quote
Old 07-13-2021, 10:56 PM   #11
tdangle
tdangle's Avatar
Re: fuel injection
question on the fuel pump. I know electric fp like to be gravity fed. If using the in-cab tank will it supply fuel OK to the pump even if you run out of gas and refill the tank?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-14-2021, 07:57 AM   #12
Bigdav160
Bigdav160's Avatar
Re: fuel injection
I once had a '72 that I installed a TPI engine. I used an external pump under the cab.
I never had a problem with the pump siphoning fuel from the tank but it would pick up air and howl anytime under 1/4 tank of fuel.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-14-2021, 11:17 AM   #13
Big Kev-O
Big Kev-O's Avatar
Re: fuel injection
My tank is in my cab and I am running the FiTech system with a inline pump. I added a 3/8 supply line to my fuel sender, moved the stainer over to the new line and hooked the return up to the original 5/16 line. I tried using standard plumbing solder and couldn't get it to work so I used some Silvaloy brazing alloy that I normally use for HVAC. It has been working great since 2015.
I read several threads about issues with the first gen FCC. I would hope FiTech has worked out all the issues with the latest version. There customer service has been excellent for me. They have helped me over the phone & answered my emails. I broke the handheld programmer and they sent a new one free of charge.
original thread here:
http://67-72chevytrucks.com/vboard/s...=688342&page=2
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 07-14-2021, 02:12 PM   #14
Old_Gold
Old_Gold's Avatar
Re: fuel injection
I'm using the FiTech unit with a Edelbrock fuel sump fed by the mechanical fuel pump. It has been working great for me!
Jim
Old_Gold is offline   Reply With Quote
Old 07-14-2021, 02:32 PM   #15
body bolt
Re: fuel injection
A Facet 60106 will supply 4-7 PSI and lift 36", so they claim. I just ordered one. I had bought what I was led to believe a Carter P4070 but there are no markings except a different number on the box which took me to a copy-cat MIC pump. I'm sending it back. I'm going to use an Edelbrock sump to supply the higher pressure to the TBI.
body bolt is offline   Reply With Quote
Old 07-14-2021, 06:14 PM   #16
Davidf
Re: fuel injection
I modified a Tanks Inc GPA-2 pump to use in my factory in-cab tank to fuel my LS swap. Not finished yet, so don't know how well it is going to work. You have to cut a hole in the tank next to the original sending unit/pick-up.
[IMG][/IMG]
Davidf is offline   Reply With Quote
