#2276 | |
![]() Join Date: Apr 2017
Re: What did you do to your truck today.The 3rd chapter
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
#2277 |
![]() Join Date: Nov 2019
Pulled the motor, trans and almost have the crossmember out to replace the crossmember, add power steering & power brakes.
Also looks like I will need to replace the flywheel ![]() ![]() ![]() ![]()
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
#2278 |
![]() Join Date: Aug 2019
Hope the machine shop can save that fly wheel.
#2279 |
There's no saving that, I'm going to replace it.
#2280 |
#2281 | |
PITbut
Not today, but recently. I dont know how to post videos ON the forum. How do you direct link youtube vids so they play on the site? https://www.youtube.com/watch?v=D46QO0mG-GM https://www.youtube.com/watch?v=RkwIW-4djgs https://youtu.be/Kt3vbcqMt-4
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#2282 |
O turned gen 6 valve covers from this to this. Impressed how good the stock ones can look
69 longbed 350 700r4 3.73 POSI cruiser |
#2283 |
Put the leafs and overload leaf back in the 72. Now she sits up in the rear and rides much harsher but I'm putting the hitch on tomorrow so it needed to be done
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#2284 |
Yesterday . Had the hitch fabricated all 1/4 inch square tube was able to tuck it in nice to the bumper. Just need to weld on the safety chain eyelets and wire it up
#2285 |
![]() Join Date: Nov 2014
Last visit @ paint shop. Should be coming with me next time.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#2286 |
Installed the 679 Hayden rapid cool trans cooler pretty easy on this didn’t need to take anything of other than loosen the shroud I may make a couple of brackets so it not in the rad so to speak. Also mocked up where I may put the gauges . They look good in the console but I loose the cubby hole . The oil pressure guage will be replaced with a trans fluid temp gauge
#2287 |
![]() ![]() Join Date: Jan 2005
When I bought my truck a year ago, it came with a single newer key that fit the ignition but not the door locks. I have since replaced the door locks and ignition with a set from LockDoc. Today I was chasing down a rattle in my hood, and I found a Hide-A-Key magnetic box inside it, next to the striker plate. It had a key inside it, and it works with the original door locks! I don't think this is the original key based on it having a locksmith name stamped in it (WAGNER), but I still thought it was a cool find.
#2288 |
I think that is cool. I always fear I will forget where I hide mine.
#2289 |
Got a solid start on finishing my bed wood. These six pieces have the bottoms and edges done in black sealer and three coats of gunstock color stain. Will do the clear coat when I get the edge pieces ready.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#2290 |
^^ looks great
I finished up the tow package on the 72 only thing I have to do is the gauges . Tows really well the factory temp gauge is a tad higher under power than without the trailer
#2291 |
...today I caught mine on fire... a bit of a belch from the carb..... it's ok.... I put it out quick, just a burned up air filter and a crunchy hose.... already replaced and running in less than 30 minutes
#2292 |
![]() Join Date: Jun 2018
Radiator overflow bottle/bracket/hoses installed!
I used an old windshield washer bottle so it would look like it belonged there (the yellowing old look) instead of having a brand new white bottle. I also found a black "Engine coolant only" cap to match the windshield washer bottle cap.
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
#2293 |
Plumbed in the manifold for the transmission temp sender no leaks just need to drill some holes for the mounting screws I have good continuity checked it because I had to use a little Teflon tape . Left half the fitting bare to help make a good contact . Tomorrow I’ll mount the gauges and wire it up .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-02-2021 at 07:10 PM. |
#2294 |
![]() Join Date: Dec 2012
Finally, after waiting several weeks for parts, I was able to finish rebuilding my doors. All new internals, plus new vent windows and door glass. Last hurdle was the setting tape, that was way too thin. I ended up putting that tape against the glass, and backed it with tool box liner - worked like a champ. Under the door panels I added sections of Fat Mat to reduce vibrations. What a difference! Much quieter, and no more rattle. Nice, clear glass is also a welcome upgrade.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#2295 |
One window set -
#2296 |
Finished doors
#2297 |
Well I put in the automatic transmission linkage. Twice got it working smooth then had to take it apart a third time. The hole for the linkage bushing was to small and I had to drill it out. Hope the third time is the charm
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
#2298 |
Well today I worked on getting brake fluid in the lines and find a fitting for the brake booster vacuum hose. found the fitting and got it installed and got three of the calipers bled. Broke the bleeder valve, on the last one, so now I have to order a new one. This truck is going to drive me over the edge at this rate.
#2299 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#2300 |
