Old 06-14-2021, 12:48 PM   #1101
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Let's see some finished photos when you're done!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 07-22-2021, 08:12 PM   #1102
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Been pretty busy with truck. Lot's to update on.
Paint isn't perfect, but it will do for now, it's a daily driver sooo. It's all down hill from here.
Right after I finished painting, just pushed it outside.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-22-2021, 08:15 PM   #1103
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Started to put everything back on.
The letters on hood turned out real nice. I don't like the new push on style cheap nuts they send with them so I need to figure something else out for those.
Disregard all the dirty finger prints
"It's only money".
Old 07-23-2021, 12:31 AM   #1104
Kronald_70GMC
Kronald_70GMC's Avatar
Re: TA_C10: Stage 1
Looking awesome! Very nice truck you have there.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 07-23-2021, 06:37 PM   #1105
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Came out great! Looks very uniform and of course a unique color.
Old 07-24-2021, 12:33 AM   #1106
cornerstone
cornerstone's Avatar
Re: TA_C10: Stage 1
Your panel gaps and body lines look spot on man. Potter's right, you laid the paint down nice and uniform... all the prep work paid off big! Ya know, most guys can say they did all the mechanical work on their project and a few can say they did everything except paint and interior, but not many can say they did it all. Well done on a nicely appointed full resto-mod from start to finish!
Looking forward to more pics after you get all the shiny bits back on.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-30-2021, 01:24 PM   #1107
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks guys. I can assure you the pics are a little deceiving. If I was going for show quality I would have done things a little different. But it does me just fine for a driver.
More updates:
Picked up a drill buffing wheel kit from amazon. Worked out really good. Started going to town on the trim and got everything installed. Side by Side before and after shows how they came out. Also got another LED relay for under dash fuse panel. Flashers work now Drilled and tapped my steering column lower plate for the Dakota Digital gauge switch and OBDII port for LS. And last I got my extension tube finally for washer bottle so I was able to get that completed. I'm using OE style washer pump under dash. It works as designed, but it kinda sucks for a driver, probably end up installing an aftermarket pump out in the engine bay. It takes too long to pump fluid out, which means your wipers are running dry for a while on dirty glass....
Side by side:
"It's only money".
Old 07-30-2021, 01:52 PM   #1108
SkidmoreGarage
Re: TA_C10: Stage 1
That trim is cleaning up nicely, it is going to look great. What polishing compound did you use?
SkidmoreGarage is offline   Reply With Quote
Old 08-01-2021, 01:05 PM   #1109
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks, I used Blue Magic compound. But I will say that I started out with red scotch brite, didn't work good enough needed more so I ended up going 400 sand, 600 sand, 800, 1000. Then I used these polishing wheels. It was a chore.
https://www.amazon.com/Blue-Magic-30...53699836&psc=1
"It's only money".
Old 08-01-2021, 01:08 PM   #1110
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Trim finished and on the truck. I ended up buying new grill surround trim to save time, but that stuff is like malleable clay almost it's so soft. Just putting in the clips I dented it, with just my hands forcing some of the tedious clips in there. So one day I will finish the original trim because it's much better quality. This will do for now though.
"It's only money".
Old 08-01-2021, 01:12 PM   #1111
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Ended up mounting my heater flow valve too. Been scratching paint as I drive around
Made a template, marked and drilled holes, took off the wheel and installed the screws with anti-seize(got it all over the wheel well as you can see).
"It's only money".
Old 08-01-2021, 01:16 PM   #1112
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Zip ties around the A/C hoses on vintage air unit. Kinda hard to get to all of them but I can tell this should hold them in place for long time. Getting close to putting the glove box in. Want to install a LED light somehow and the USB and AUX cables as well. Still need to figure that out. Be cool it somebody made a panel to house that stuff but I guess they are all different so....
"It's only money".
Old 08-01-2021, 01:34 PM   #1113
SkidmoreGarage
Re: TA_C10: Stage 1
Good to know about the trim. Thanks for the reply.
You might want to consider swapping those Philips head screws on the heater valve for something a little friendlier to corrosion, seeing as they live in the wheel well. Philips tend to hold the dirt and moisture in the engagement points of the driver. A bolt or Allen cap screw would probably do the trick.
Also, it just occurred to me that this is stage 1 (and you have done so much), do you already know what stage 2 will be?
Old 08-01-2021, 02:00 PM   #1114
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
LOL, stage 1....... I should have that changed. Stage 1 was supposed to be little sheet metal work and LS swap, throw it back together and drive for a while. Then fix things/upgrade as I go. When I found out the floors and rockers were rotted out and just covered up with new pieces I ended up tearing down to the frame. And it was a full on build. But. I still tried to keep cost down because I wanted it as my DD, nothing show quality just drive it. So suspension was rebuilt with stock components and several others items got rebuilt or replaced stock style. Upgrades made sense along the way though, vintage air, disc brakes up front, DD gauges, sway bars, wire harness, redesigned entire PDU and ground system.
After our house is built I would like to redo interior, and maybe go LS3 for around 500hp at crank. I've got new Detroit locker to install still. I will redo engine harness inside the truck this time. And I will repaint again too. The paint isn't perfect. Oh, the suspension could use some upgrades too. All this would be stage 2 and 3 and 4 and.......
"It's only money".
Old 08-01-2021, 02:09 PM   #1115
SkidmoreGarage
Re: TA_C10: Stage 1
Haha. I think the marketing departments have really burdened us with the concept that modifying a car can be done in "stages". As though, like a stage, they have a clear start and finish, and then they can be built upon at a later time. Anyone who has ever done the work themselves learns pretty quickly that is BS! And anyone who does it for a living rolls their eyes when they hear "stage".
I will now declare, for the benefit of all, that you have completed stage 1 and 2. The certificate will be mailed to you by the international automotive project car committee, upon your submittal of $50 for the processing fee.
Old 08-01-2021, 03:25 PM   #1116
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
"It's only money".
Old 08-02-2021, 09:28 AM   #1117
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
The front end came out great! I know what you mean about the trim - I damaged mine just sliding the clips in the channel.
As skidmore said, you've definitely completed stages 1 and 2 and probably part of 3. I too have things I'd like to do to my truck someday - engine rebuild, Holley Terminator, 5-lug conversion/wheels & tires/regear/trutrac, convert to rear coilovers, rewire the headlights, redo the hood, reclear the whole truck. But building a house is still higher on the priority list.
Have you considered tinting your windows? I think it would look good on your truck and help with the Texas heat.
Old 08-06-2021, 08:56 AM   #1118
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I took the side windows and wings when they were still apart and have them tinted. They got that tint that blocks UV and heat. When I'm driving in 105° and the sun is on one of those sides you don't feel any heat it's amazing. So I'm taking it back soon to have the back window done as well as the windshield. Windshield will get clear tint. Sides are 40% I think.
"It's only money".
Old 08-09-2021, 10:41 AM   #1119
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
A/C filled. Nice and cold. Few other pics. You can see how the crappy hood hinges don't like to stay down, when I get a chance I will be replacing those. They are brand new, but OE style.
"It's only money".
Old 08-09-2021, 10:44 AM   #1120
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Before and After shot
"It's only money".
Old 08-09-2021, 10:52 AM   #1121
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Another before and after.
"It's only money".
Old 08-09-2021, 10:52 AM   #1122
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: TA_C10: Stage 1
lookin' very nice....
rodstored-72 is offline   Reply With Quote
Old 08-09-2021, 11:40 AM   #1123
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I bet you're happy to have A/C! That bed looks extremely long in those pictures.
I just ordered new OE style hood hinges, are you telling me there's a chance they're no better than the old worn out hinges straight out of the box?
Old 08-09-2021, 07:36 PM   #1124
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I will say this. The action of them is new so they spring up and down real nice and easy compared to the old original worn out ones. But 2 things I don't like about them.
1. When you shut the hood, I have go push down the back of the hood because they pop up a little due to their action. so each side go push them down to match the cowl level. This could be an adjustment thing. If I lower the back of the hinges down it might help so they go lower, but i'm afraid if i do that it won't line up right in the front of hood....
2. While driving around, they pop back up on me, back of hood, so after a while of driving i have to push them back down again.
It's not terrible, but different hinges would alleviate this. And of course, these things are flimsy where billet or something else are stronger.
"It's only money".
Old 08-10-2021, 11:15 AM   #1125
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
I had the same experience with the ones I purchased. I ended up going with the CVF hinges because I couldn't adjust out the "pop up" in the back of the hood.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
