08-14-2021, 03:25 AM | #10 |
Re: 1962 GMC dually front end swaps?
The square body trucks had 454s I would think if you ran those same springs and such it'd handle the weight the best?
The 454 V8 is 685lbs 305D V6 is 735lbs, So I'd think after the swap over just run the big block coil spring set should ok?? I am sure the front sags a bit anyway so it'd sit about the same as it does now so no difference would even be noticed Mike Last edited by GMC-V6; 08-14-2021 at 02:58 PM. |
