Old 08-02-2021, 09:14 AM   #301
57FleetsideC4
Re: My 56 build
Lots of nice fab. work. Looking great. Keep up the good work. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 08-03-2021, 12:35 PM   #302
Jason 56
Re: My 56 build
Originally Posted by 6DoF View Post
your bracket game is on point!
Thanks guys. Slowly putting pieces together. Working on mounting the shifter today.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 08-06-2021, 07:57 AM   #303
Jason 56
Re: My 56 build
Here’s the start to the shifter and a mock up of the center console. I just have to make a bracket to hold the cable on the transmission. Hopefully I won’t need to adjust/grind new detents to match up with the newer trans. Time will tell I won’t be finishing the dash until after I install the vintage air system. That won’t be shipped until October.
Old 08-17-2021, 09:31 AM   #304
Jason 56
Re: My 56 build
Shifter appears to be fine. All the shifter detents Line up with the transmission. So hopefully that will work out.
Also ordered a driveshaft. The one I had was too short. Go figure, going from a 4 speed to an 8 the driveshaft needs to be longer. So more research and I found a bill of material list for gm driveshafts. It includes everything from length, u joint size, shaft material, Oem part number, etc. I found one the right length with the correct u joints, plugged the oem number in rockauto and ordered it. $300 direct from rock auto! Here’s a link to that bill of materials page.
https://www.demandaam.com/technical-...l-of-materials
I ordered a new pinion yoke to match the 1410 u joint and I should be able to drive this thing out of the garage. I made an appointment to see if it can be aligned for August 27. Mock up is nearly complete
Old 08-18-2021, 12:59 AM   #305
Kermitt47
Kermitt47's Avatar
Re: My 56 build
Nice build and good work with the Gen V swap. I am looking at your driveshaft info and that might save a whole lot of trouble. Thanks
Kermitt's 47 truck build
Kermitt47 is offline   Reply With Quote
Old 08-18-2021, 11:12 PM   #306
Jason 56
Re: My 56 build
No problem, hope it helps
Old 08-19-2021, 12:14 AM   #307
Kermitt47
Kermitt47's Avatar
Re: My 56 build
Jason 56, are you using the Camaro SS fan with PWM control or did you find something else that fits the bill? If it is the Camaro fan, how deep is it from the rad to the back of the motor? I am looking for a compact solution that will move some air. Nice job hiding all the engine controls.
Old 08-19-2021, 09:07 AM   #308
Jason 56
Re: My 56 build
Yes, it’s a Camaro pwm fan. I’ll have to measure the total length from back of engine to core support later when I get home. The radiator/fan are about 7”. Leaves me with about an inch between fan and engine. I used a 24” double pass radiator. Both my coolant inlet and outlet are on the left side so that worked for me.
Old 08-24-2021, 11:16 PM   #309
Jason 56
Re: My 56 build
Pinion yoke arrived. Last piece of the puzzle needed to pull it out of the garage. Along with a couple trips to my local parts store for fluids etc. Now my alignment is only weather dependent. I actually drove it up and down the street, so it’s ready for the trailer in a couple days. I pulled it into the garage, put it in park, shut it off, got out and closed the door and realized what finally just happened. Couldn’t stop smiling. Great to finally have it driving! now I just have to finish everything else.
Old 08-25-2021, 10:28 AM   #310
oldman3
oldman3's Avatar
Re: My 56 build
Congrats, that first drive, no matter how far, will always remain with you...Jim
oldman3 is offline   Reply With Quote
Old 08-25-2021, 11:56 AM   #311
bosco
bosco's Avatar
Re: My 56 build
Great feeling when you can drive it out of the garage. She looks great.
bosco is offline   Reply With Quote
Old 08-25-2021, 11:59 AM   #312
dsraven
Re: My 56 build
Congrats. Looks awesome and the stance is bang on, in my opinion. Do you have a color picked out yet or does that change daily?
dsraven is online now   Reply With Quote
Old 08-25-2021, 12:07 PM   #313
Kermitt47
Kermitt47's Avatar
Re: My 56 build
Congrats! That is a Big deal to go from a pile of parts and ideas to a running, driving machine. Everything else is icing on the cake.
Old 08-26-2021, 07:42 AM   #314
6DoF
6DoF's Avatar
Re: My 56 build
NICE! that's a huge moment!
6DoF is offline   Reply With Quote
Old 08-26-2021, 11:33 PM   #315
Jason 56
Re: My 56 build
Thanks everyone. I’m hoping it doesn’t rain tomorrow. I’m putting it on the trailer to bring it to be aligned. We’ll see. It’s forecasted to rain all day.
Old 08-26-2021, 11:39 PM   #316
Jason 56
Re: My 56 build
I agree with the stance. I kept trying to level the rake and found these trucks just look better raked! As for color I’ve settled on a new infinity color. It’s called hermosa blue. It’s a midnight blue pearl. Should look really sharp.
Old 08-31-2021, 10:26 PM   #317
Jason 56
Re: My 56 build
Trailered the truck back from the alignment shop today. Everything came out great They were just going to check to see if it could be aligned and it was looking good so they just tried to see how close they could get it. Turns out it aligned perfectly and I was told that it should drive great
Old 09-10-2021, 11:20 PM   #318
Jason 56
Re: My 56 build
Installed a one piece power window kit. I need to obtain the seals to confirm the shape of my templet. Otherwise the install was easy. Hopefully they seal nicely.
Old 09-10-2021, 11:22 PM   #319
Jason 56
Re: My 56 build
Received my exhaust kit today. This is the next project.
Old 09-11-2021, 10:26 AM   #320
mrbuck
Re: My 56 build
Man, it’s really coming along ����
What one piece window kit did you use? Is it power window?
mrbuck is offline   Reply With Quote
Old 09-12-2021, 10:05 PM   #321
Jason 56
Re: My 56 build
They are made by specialty power windows. They’re made in Georgia. Little expensive, but the quality is there. Yes they are power. The only thing I don’t care for are the 80’s style window controls the kit comes with. I’ll be changing those. Here’s a link to classic parts where I bought them.
https://www.classicparts.com/1955-59...tinfo/18-766B/
Old 09-12-2021, 10:09 PM   #322
Jason 56
Re: My 56 build
Here’s a start to the crossover. I’m still waiting for my mufflers to see where everything falls.
Old 09-14-2021, 10:09 PM   #323
Jason 56
Re: My 56 build
Spent most of the day today knocking out the exhaust. Mufflers were delivered around noon and hours later… an exhaust. The kit I used was 2.5” mild steel and a pair of borla mufflers. It sounds good Here’s a bunch of pictures.
Old 09-14-2021, 10:16 PM   #324
Jason 56
Re: My 56 build
A few more pictures. I decided to have the exhaust exit the rear fender. I plan on cutting the exhaust flush with the fender and the paper ring will be chrome… maybe.
Old 09-15-2021, 09:48 AM   #325
Rickysnickers
Re: My 56 build
Looks great, and the pictures are turned the right way!! Thank you for posting!!!
Rickysnickers is online now   Reply With Quote
