#3276 |
Re: PO has me PO'd
#3277 |
Re: PO has me PO'd
![]() Don't lose roll pin or wave washer as they don't come in the package
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-07-2021 at 12:48 PM. |
#3278 |
Re: PO has me PO'd
Now you did it big time,jinx
![]() But, 70 degrees in the shop
#3279 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: PO has me PO'd
Looks real pretty though. It’s -19 here right now.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#3280 |
Re: PO has me PO'd
Started a jig to support window frame
#3281 |
Re: PO has me PO'd
thats my record temperture for fishing in NY for steelhead
Time to start up snowblower
#3282 |
![]() Join Date: Nov 2012
Re: PO has me PO'd
Did someone mention steelhead?And cold, nay I say Oregon
#3283 |
Re: PO has me PO'd
Thats a great looking fishing hole, enjoy
#3284 |
Re: PO has me PO'd
![]() The other day I was looking thru the classifieds and came across a thread for parts needed for wind windows, followed the link to car and truck site They had the division bar in shock, ordered the part and was happy with what I received, but, I didn't read the note which mentioned the original felt channel that was not included Ordered that part and was even more pleased with parts Originally what was supplied was a sticky thin piece of felt, which may have worked, but was the wrong thickness for the glass, so if you order the division bar, don't cheap out. Buy the felt with it as recommended in the notes The bead on the division bar is exact replica Now, I have to drill all the holes for the rivets
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2021 at 11:23 AM. |
#3285 |
Re: PO has me PO'd
Drilling new holes in division bar, stainless steel ,so make sure to use a cutting fluid, or you may work harden material
![]() ![]() Using old division bar as a template
#3286 |
Re: PO has me PO'd
![]() Been working on my aftermarket doors, couldn't get the gaps right, so I tried something extreme, I jacked the body up, about 1 inch and got the gap you see. Now just have makeup a body mount to fit
#3287 |
Re: PO has me PO'd
1 inch seems like alot to shim a body mount
#3288 |
Re: PO has me PO'd
Well actually the original mount is 1/2” and the space to get the door lined up is 1/2”, so considering age of truck maybe the rubber mount is shot. Don’t know what size they should be
Thanks for the input
#3289 |
Re: PO has me PO'd
Picked up a new helmet from yes welder, about 60 dollars, needed one for awhile
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-22-2021 at 12:00 PM. Reason: New pic |
#3290 |
Re: PO has me PO'd
New tool 300 watt American beauty soldering Iron
Don't want to use bondo, just lead ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-04-2021 at 09:29 AM. |
#3291 |
Re: PO has me PO'd
Correct thickness to get my door gaps, oem on right side
#3292 |
Re: PO has me PO'd
Gaps look workable
#3293 |
Re: PO has me PO'd
![]() Started to grind down welds to see if leading works waiting on tinning butter to arrive from eastwood
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-14-2021 at 09:34 AM. |
#3294 |
Re: PO has me PO'd
[url=https://flic.kr/p/2mrk3Px]
![]() Working on my weatherstripping ,making sure my door closes right, I put down 1 layer of cement, dry to the touch, then add 1 more wet and clamp in place Once you get it started its easy to turn inside out or backwards to apply glue
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-16-2021 at 01:27 PM. |
#3295 |
Re: PO has me PO'd
#3296 |
Re: PO has me PO'd
![]() Don't know where this gap came from, nor how to fix
#3297 |
Re: PO has me PO'd
#3298 |
Re: PO has me PO'd
#3299 |
Re: PO has me PO'd
Computers are out for safety
#3300 |
Re: PO has me PO'd
