Re: My 64 Project
Final outcome was far and away better than I could have expected. Not perfect by any means, but for never having done this before I'm very happy with it.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: My 64 Project
Thats cool!
Re: My 64 Project
A few more progress updates: got the doors painted and hung. Also got the trim back on. Then started in on the bedsides. Had a buddy that does sheet metal French in my 59 caddy tail lights.
Re: My 64 Project
Once he got done with the tail lights, I figured it still needed more, so I went ahead and swapped out the wheel arches for a set off of a 61 bel air.
Re: My 64 Project
This truck has been kicking my ass today, so instead of fighting it more, I'll make another progress post. Got the bumper finally hung, but will need to brace the brackets due to a little more play than I would prefer. Also got the tail lights installed. Need to get them wired in now. Not sure what the deal is with the pictures. Anyone know if there's a way to rotate them once attached?
Re: My 64 Project
A few other odds and ends knocked out: hit the floor with some por15 to make sure its adequately sealed up before I throw a floor mat over it. Got a set of fog lights from a coworker and mounted them up. Not sure if they'll stay or wind up going on my other 66. Also finally got some of my white walls mounted up and on the truck. Changes the whole dynamic drastically and I absolutely love it! Also got some 6x9 brackets mounted in the cab so I can have some tunes once I finally am able to start cruising.
Re: My 64 Project
Nice progress.
#8 | |
Re: My 64 Project
Re: My 64 Project
Thanks guys! It's definitely been a journey getting it this far.
Thanks! They're 235/70/15s all around. Front rubs a bit on hard corners and dips, but otherwise they work pretty well.
