09-27-2021, 12:28 AM | #2451 |
Re: What did you do to your truck today.The 3rd chapter
Whats everyone using for pictures My Imbb.com just quit? and removed all my pic
Got em back site was down?? Last edited by cab4word67; 09-27-2021 at 07:59 PM. |
09-27-2021, 08:07 AM | #2452 |
Slipped everything together this weekend. Still need to install the fender braces before I tighten it all down. Rear lights need wiring and bed ground to frame. Been just under 2-1/2 years from dragging it out of a shed and now. Lots of hours and $$ spent but I think I'll have a solid runner by spring. Lots done and lots left to do.......
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
09-27-2021, 08:20 AM | #2453 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-27-2021, 08:22 AM | #2454 |
I use imgur.com
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
09-27-2021, 08:41 AM | #2455 |
Mr. Cheyenne
This weekend played with my distributor springs - set them up this time to bring in timing just a tad later and the cerve to be a bit more even. It is actually the default factory configuration. It only takes a bit to pop of/on new springs.
However, this time a little brass washer popped off that goes under one side of the spring. It took me nearly 2 hours to find that darn thing, which ended up bouncing forward of the distributor and rested under the divorced choke on the intake manifold. I really thought I wasn't going to find the darn thing! Also got a new gas cap from the parts section for 72 gas tanks, fits so much better than the repo and look tons better too. I've ordered new valve grommets and a oil cap. After spending hours looking for that brass washer with my face 3 inches from the engine, I notice oil leaks around the grommets/cover and oil cap.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-27-2021, 02:14 PM | #2456 |
Drove it like I stole it...straight to a local car show. She picked up "Best Of Show- Truck"
09-27-2021, 03:35 PM | #2457 |
I use Smugmug which is a paid professionally run image server. Basic cost is $55/year. If you're into archiving photos/vids it's a super useful platform.
1971 SWB step side: Original NM Forestry and then NM Fire truck Last edited by Carl Spangler; 09-27-2021 at 08:44 PM. |
09-27-2021, 08:00 PM | #2458 |
09-27-2021, 08:06 PM | #2459 |
Hood off and ready to install the new intake and carb
09-28-2021, 07:05 AM | #2460 | |
I use imageevent.com I think it's about $55 a year for unlimited storage. Great when you have videos to share too because they take a lot of room. I have stuff on there from 2000 |
09-28-2021, 08:48 AM | #2461 |
09-30-2021, 08:18 PM | #2462 |
Mr. Cheyenne
This wasn't actually today but I just got the photo today. My truck was used for a photo shoot at the Lady Bird Johnson Wildflower center with their staff - not sure what publiciation / social media thing they are using it for but something to do with UT Austin and LBJWC.
They really loaded up the bed with people! LOL
09-30-2021, 08:36 PM | #2463 |
Started switching over to a one piece driveshaft.
10-01-2021, 09:08 PM | #2464 |
Spent last few days installing a new set of 3.73 gears and all new bearings. seals. Modified my flip kit and gained 1-1/8" of travel before hitting the bump stops on the C notch. Then took out one more leaf spring (#4) from the set witch is giving me a smoother ride. Got some work to do on the underside of the wood floor then the fuel tank goes in and we can roll down the road again.
10-02-2021, 09:11 AM | #2465 |
Mr. Cheyenne
I been fighting a oil leak since my engine rebuild a year ago, I even asked my shop to look to see if my oil pan needed to be resealed. Like my brother told me, it's a old truck they leak and the leak isn't bad. The shop said all they could tell is it looked like oil was coming from the cap and perhaps the dipstick.
Fast forward to when I was working on my distributor springs, I saw oil coming from my grommet on the breather tube on the passenger side valve cover (goes to the carb / air filter base). So I got new grommets for both the passenger breather tube/PCV Valve, new proper 90 degree PCV Valve, and oil cap. When I had things all apart I found the Flame arrestor was so gunked up I could hardly blow air through it. Took me forever to get it cleaned out but I did (seems you really don't need to replace them, just keep them clean). Now after 50+ miles and checking the truck this morning after sitting overnight - there is ZERO oil anywhere on my oil pan, starter, flexplate cover or garage floor! Hallelujah!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 10-02-2021 at 10:20 AM. |
10-02-2021, 02:04 PM | #2466 | |
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
10-02-2021, 06:49 PM | #2467 |
At the body shop.
$15 swap meet air cleaner.
Cut chop hole saw weld Dual snorkel air cleaner
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 10-02-2021 at 06:57 PM. |
10-02-2021, 11:31 PM | #2468 |
Farm Truck - just bought it, making a 'to do' list
My Suburban needed a friend and I needed a good farm truck so now we have a new family member
10-03-2021, 07:23 PM | #2469 |
At the body shop.
Son welded it all together. Quick spray bomb
" That didnt make it any newer " " Dont antique the equipment " |
10-03-2021, 08:09 PM | #2470 |
Installed a new tailltight wiring harness along with the taillight/back-up light assembles, bulbs, and lenses. Also ordered a bunch of parts. I'm getting ready to pass inspection and get her registered!
10-03-2021, 08:38 PM | #2471 |
Fixed vibration from rear axle. Turns out pinion/yoke nut was loose so had slop there. Also, u-joint had side to side slope in yoke. So super loosey goosey connection between driveshaft and rear end. Or too noticeable at speeds up to 65 except on decel you could feel a rumble. Over 65 and the rear slider window seems to want to rattle out of the truck due to the harmonic vibration.
So, pulled yoke, replaced seal. Removed rear cover and ring/pinion/spiders seem fine. To fix the slope of the u-joint in the yoke, I could see one location tab was worn thinner than the other. So, I add weld material to the tab and used my Drexel cutoff wheel to re-machine the tab to the correct clearance. Tighten up pinion nut with impact not worrying about the crush sleeve. After reassembly, the entire u-joint/yoke assembly is super tight with not discernible play. Vibration is gone…happy days. |
10-05-2021, 03:23 PM | #2472 |
Got the bed painted, still need to spray the bed liner and undercoating.
10-05-2021, 05:21 PM | #2473 |
I LOVE that GREEN.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-05-2021, 05:21 PM | #2474 |
^^^^LOVE that green. Sparkles almost hurt your eyes in the sun.
10-05-2021, 07:40 PM | #2475 |
Yes that is a beautiful color, cant wait to see it all together
